PyLuxCore Tool Error ( v2.4, all scenes)
gecko
Post by gecko »
Hoping I've just configured something poorly, but I just updated from LuxCoreRender 2.3 to 2.4 and completed my first scene in 2.4. It renders fine inside Blender (2.83), but when I exported it to do a full res network render the scene won't load properly in PyLuxCoreTool. I confirmed the same behavior with the default scene (ok, it's my slightly modified default scene, see below). Problem occurs on both a local node as well as network nodes in PyLuxCoreTool.
Here's the Node error:
[Thread-5][2020-08-28 12:51:35,587] [SDL][57438.093] Texture definition: 2937060048344Color
[Thread-5][2020-08-28 12:51:35,587] [SDL][57438.093] Volume definition: 2933295757544
[Thread-5][2020-08-28 12:51:35,588] bad lexical cast: source type value could not be interpreted as target
  File "C:\Users\xxxx\AppData\Local\Temp\_MEI230882\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmnode.py", line 168, in __HandleConnection
    config = pyluxcore.RenderConfig(renderConfigFile)
RuntimeError: bad lexical cast: source type value could not be interpreted as target
[Thread-5][2020-08-28 12:51:35,645] Connection done: ('192.168.200.46', 61519)
And here's the Console error:
[RenderFarmNodeThread-192.168.200.194:18018][2020-08-28 12:51:50,645] Sending seed: 5
[RenderFarmNodeThread-192.168.200.194:18018][2020-08-28 12:51:50,646] Waiting for node rendering start
[RenderFarmNodeThread-192.168.200.218:18018][2020-08-28 12:51:56,924] Unable to receive a line
  File "C:\Users\xxxx\AppData\Local\Temp\_MEI189762\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 423, in NodeThread
    result = socketutils.RecvLine(nodeSocket)
  File "C:\Users\xxxx\AppData\Local\Temp\_MEI189762\pyluxcoretools.zip\pyluxcoretools\utils\socket.py", line 44, in RecvLine
    raise RuntimeError("Unable to receive a line")
RuntimeError: Unable to receive a line
[RenderFarmNodeThread-192.168.200.218:18018][2020-08-28 12:51:56,928] Node thread done
Any ideas? I'm running a Win10 build in all cases. "Default" scene details are:
- UV image-mapped glossy texture on default cube.
- HDRI world light instead of a lamp to light the scene.
- Transparent default air volume
- BiDir engine with Metropolis sampler
- Camera tonemapping set to Camera Settings
- 16bit 4k image output size
Re: PyLuxCore Tool Error ( v2.4, all scenes)
gecko wrote: Fri Aug 28, 2020 5:23 pm Any ideas?
It is a problem with localization output (i.e. for instance it is printing "." as ",") in your exported scene (https://github.com/LuxCoreRender/LuxCore/issues/390). I assume you are using a no-US locale. As workaround, just export the scene in binary format instead of text format.
gecko
Post by gecko »
Hmm, localization does not appear to be the issue. First, I'm US-based and had US-English selected in Blender. Second, I was already exporting the binary (I've never managed to get text export to work). But just to make sure, I deleted all of the exported files, changed my Blender preferences to "Automatic" instead of English, and tried again with a clean binary export. I'm still getting the same error.
gecko wrote: Fri Aug 28, 2020 7:40 pm Hmm, localization does not appear to be the issue. First, I'm US-based and had US-English selected in Blender. Second, I was already exporting the binary (I've never managed to get text export to work). But just to make sure, I deleted all of the exported files, changed my Blender preferences to "Automatic" instead of English, and tried again with a clean binary export. I'm still getting the same error.
Try to install a v2.5 automatic build (viewtopic.php?f=9&t=736) and post both the .blend file and the .bcf file so I can check what is going on.
gecko
Post by gecko »
Dade wrote: Fri Aug 28, 2020 9:10 pm Try to install a v2.5 automatic build (viewtopic.php?f=9&t=736) and post both the .blend file and the .bcf file so I can check what is going on.
Thanks for looking in to this. See files below (I did confirm exact same issue in the 2.5 automatic build when trying to load in pyluxcoretool).
.blend file: https://drive.google.com/file/d/1-BjdNT ... sp=sharing
.bcf file: https://drive.google.com/file/d/1kFrC0U ... sp=sharing
By the way, just out of curiosity... why is the bcf file for a simple cube so huge? I recently realized that half the time I spend getting an external render started is read/write time for the bcf (I keep all my project files on NAS, so the bottleneck becomes quite noticeable with my typical 2-3GB files!).
gecko
Post by gecko »
Any other ideas here? It's killing me trying to render a production scene in Blender internal :/
Is it worth trying to port the scene back to Blender 2.82 and LuxCoreRender 2.3 (or trying to use LuxCore 2.3 in Blender 2.83?)? Sounds like it's asking for trouble, but I don't know what else to do if I can't even export my scene to render.
You didn't packed any of the required images in your .blend file (you have many .png and a HDR referenced by the file):
I assume the .bcf file is so large because it includes them while your .blend file doesn't.
Can you use just the default scene ? Is your default scene broken ?
gecko
Post by gecko »
I overwrite the Blender default scene so it's already set up for my normal workflow when I start a new project... but missing image files shouldn't prevent the bcf from loading and trying to render.
Anyway, here I've attempted to recreate the actual default scene as close as I can get it by memory. At least shouldn't be any missing dependencies. And indeed the .bcf is much smaller - I didn't realize the images were being embedded directly, thanks for the explanation.
.blend: https://drive.google.com/file/d/1hqYqQP ... sp=sharing
.bcf: https://drive.google.com/file/d/1kFrC0U ... sp=sharing
gecko
Post by gecko »
Sorry to bump again, but this is really a mess for me not being able to export a scene for rendering. I've now tried on 3 different computers, 2 of these a fresh install of Blender 2.83 and BlendLuxCore 2.4 (or 2.5). Always on Win10. I can't load the resulting BCF in pyluxcoretool in any of these scenarios (export and load on same computer, export on one computer and load on another, etc). In all cases I can render inside Blender just fine.
I'd be happy to make a bug report if this is actually a bug (just need someone to confirm that I'm not crazy). Or if it's a Blender issue I'd be happy just to have a workaround.
Your .blend works fine here, where your PyLuxCore Tool come from ?
