Page 1 of 6
Performance issues
Posted: Fri Aug 28, 2020 2:08 am
by phoenixart
When I have the viewport shading in rendered mode active, navigating around becomes quite sluggish. I've been able to get some minor improvement by locking the camera to view, previewing only the camera bounds area, and excluding the rest of the viewport area. Unfortunately, that's not enough as I still cannot exactly move around in the viewport without causing a continuous delay in the operations I'm doing.
A similar issue occurs when I tweak any parameter, from materials to lights, render settings, and so on.
On top of that, when I switch to shading rendered mode or I render an image, my PC fans kick in quite bad, something I'm not experiencing with other render engines or software (Cycles, C4D, Redshift)
I wonder if this is to be expected or there's some particular hardware related known bug.
This is my configuration:
Threadripper 1950 x
64 GB Ram
NVME 500 GB Toshiba + SSD 2 TB Samsung
Dual GeForce 1080ti (drivers 452.06)
Re: Performance issues
Posted: Fri Aug 28, 2020 12:17 pm
It is hard to make any comment without knowing the scene complexity, the rendering resolution, CPU or GPU rendering, etc. A video and posting test scene could help.
Posted: Fri Aug 28, 2020 9:19 pm
by phoenixart
Thanks, Dade
Unfortunately, this is happening regardless of the scene's complexity.
A simple cube and the default light already causes the issue.
I'll try to post a video later.
Posted: Fri Aug 28, 2020 10:56 pm
by phoenixart
Here's a very basic example showing LuxCore and Cycles
LuxCore
https://drive.google.com/file/d/1KbRYRK ... sp=sharing
Cycles
https://drive.google.com/file/d/1FE5p9d ... sp=sharing
Both video have been recorded with the same conditions, meaning the same apps running in the background (mostly OS services/utilities).
Posted: Sat Aug 29, 2020 10:53 am
Weird, this horizontal division is something I've never seen before.
Posted: Sat Aug 29, 2020 1:10 pm
B.Y.O.B. wrote: ↑Sat Aug 29, 2020 10:53 am
They are the GPUs tiles, he has 2xGPU.
Posted: Sat Aug 29, 2020 2:35 pm
Ah, right, I didn't remember that RTPathOCL can use multiple GPUs.
@phoenixart: Does the behaviour get better when using only one GPU?
Or when switching to CPU only?
It might be related to this issue:
https://github.com/LuxCoreRender/BlendL ... issues/527
Posted: Sat Aug 29, 2020 3:50 pm
Posted: Sat Aug 29, 2020 4:19 pm
That's only about final render though, and the Blender API for final render framebuffer transfer. Viewport renders copy directly to bgl.Buffer.
So it might be unrelated to previous problems.
Posted: Sat Aug 29, 2020 6:33 pm
by phoenixart
I tried with CPU only and the split-screen effect is gone. The performance hasn't improved much, though
The same happens using 1 GPU only, no split-screen, and performance is just about the same.
Here's a screen capture
https://drive.google.com/file/d/1u7wDf5 ... sp=sharing
