Hey,
i am a ArchViz guy using Cycles for 3 years. Now i want to try out LuxCore.
My Problem is the shadow on the wall behind the bed. The shadow is much brighter
and looks more fake in LuxCore, how can i fix that?
And another question. Is the Disney-Shader the best option to get the most realistic results?
LuxCore
Cycles
New to LuxCore and Shadow Problem
Re: New to LuxCore and Shadow Problem
Hard to say what's going on there without the scene.
- If the walls have no thickness, try adding some (e.g. with solidify modifier)
- Or maybe you're using PhotonGI, and there is some leak in the cache?
Can you post your render settings and wether you use any caches?
Thank you, it was the thickness of the walls.
