Ah, got it, thanks. I'd assumed the default value (1.5) would take effect.
Follow up question: What's the physical meaning of kr and kt? I assume kr is a multiplier that acts on the specular-reflection component (which is determined by IORs)? And kt acts on the non-reflected remainder? Just want to make sure I understand the physical basis. (I can also check the source code if this isn't documented elsewhere .)
jon wrote: ↑Wed Aug 26, 2020 12:20 am
They are the specular reflection and transmission scale factors. You can set both to (1.0, 1.0, 1.0) for a perfect specular transmission/reflection without any kind of attenuation.
