LuxCoreUI config error
Posted: Wed Jul 29, 2020 5:02 am
by chafouin
I wanted to try the new chromatic aberration in LuxCoreUI as it's not in BlendLuxCore yet, and I'm getting this error when trying to load the LuxCore scene I saved from Blender:
RenderConfig loading error:
bad lexical cast: source type value could not be interpreted as target
Re: LuxCoreUI config error
Posted: Wed Jul 29, 2020 8:56 am
This usually means some locale mismatch, using commas in one program and dots in another as decimal points.
By the way, non-uniform chromatic aberration is now supported in the addon.
Posted: Fri Aug 07, 2020 11:25 am
by CodeHD
I've just encountered the same issue.
It looks to me as if the mateiral/volume ids in the scene files have comma separation at the 1000's locations, i.e., like "1,600,508" instead of "1600508".
If I compare to old scene files, I see the latter case.
Posted: Fri Aug 07, 2020 3:41 pm
It is this problem:
https://github.com/LuxCoreRender/LuxCore/issues/390
Try to change this setting:
https://github.com/LuxCoreRender/LuxCor ... -639427290
Blender apparently breaks C locale settings when you set English (i.e it starts to print numbers with "," separator for thousands).
Posted: Fri Aug 07, 2020 6:30 pm
by CodeHD
Indeed, that setting affects it.
Unfortunately, it just changes the separator to a dot instead of comma :/
Posted: Thu Aug 13, 2020 7:35 am
by Martini
I am being affected by this issue also (it makes exporting scenes to the standalone application unusable). Would it be possible to avoid completely using locale settings when exporting? I don't see a reason why you'd want to apply any locale to numeric IDs and such.
Posted: Thu Aug 13, 2020 11:08 am
Martini wrote: ↑Thu Aug 13, 2020 7:35 am
You can export in binary format to work around the problem.
The problem is that Blender seems to change a global C setting (i.e. the C locale) and this has as side effect to break LuxCore output. If I fix the C locale, I'm likely to fix LuxCore output but to break Blender. So I'm must find a work around. All the concept of the C locale solution is well know to be pretty much broken and a bad idea.
