Optix error on old GTX card
mib2berlin
Post by mib2berlin » Tue Jul 28, 2020 2:27 pm
Hi, I get an Optix error on my GTX 760 card using latest Luxcore 2.5.
[LuxRays][464.884] Device 2 name: GeForce GTX 760
[LuxRays][464.884] Device 2 type: CUDA_GPU
[LuxRays][464.884] Device 2 compute units: 192
[LuxRays][464.884] Device 2 preferred float vector width: 1
[LuxRays][464.885] Device 2 max allocable memory: 4034MBytes
[LuxRays][464.885] Device 2 max allocable memory block size: 17592186044415MBytes
[LuxRays][464.885] Device 2 has out of core memory support: 1
[LuxRays][464.885] Creating 5 intersection device(s)
[LuxRays][464.885] Allocating intersection device 0: GeForce GTX 760 (Type = CUDA_GPU)
[LuxRays][464.904] [Optix][4][KNOBS] All knobs on default.
[LuxRays][464.904] [Optix][2][ERROR] Error creating RTX context
  File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/base.py", line 86, in render_final
    final.render(self, depsgraph)
  File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/final.py", line 48, in render
    _render_layer(engine, depsgraph, statistics, layer)
  File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/final.py", line 60, in _render_layer
    engine.session = engine.exporter.create_session(depsgraph, engine=engine, view_layer=view_layer)
  File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/export/__init__.py", line 215, in create_session
    pyluxcore.KernelCacheFill(config_props_copy)
RuntimeError: Optix error (code: 7051, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 155): OPTIX_ERROR_INVALID_DEVICE_CONTEXT
ERROR: Optix error (code: 7051, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 155): OPTIX_ERROR_INVALID_DEVICE_CONTEXT
Info: Compiling CUDA kernels (just once, takes a few minutes)
I checked Cuda in LuxBlend.
The card is not supported in Cuda 11 as far as I know.
I think about to buy a new card anyway but want to know if it cant work, then I stay at Luxcore 2.4.
Thanks, mib
Re: Optix error on old GTX card
Post by Dade » Tue Jul 28, 2020 3:00 pm
Yes, it is not supported by Optix but it will work with CUDA: I just need to add a check to disable Optix if the device is not supported.
Post by Dade » Tue Jul 28, 2020 3:37 pm
The next build should work on CUDA devices not supported by Optix.
mib2berlin
Post by mib2berlin » Tue Jul 28, 2020 4:34 pm
Thank you very much.
Cheers, mib
mib2berlin
Post by mib2berlin » Sat Aug 01, 2020 8:07 pm
Hi @Dade , got some time to test 2.5 again but error again but different to the first one.
CUDA driver API error CUDA_ERROR_INVALID_PTX (code: 218, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/utils/cuda.cpp, line: 200):
a PTX JIT compilation failed
Cuda enabled, Optix disabled in user prefs, default scene.
May you can look in to if you find the time.
Cheers, mib
Post by Dade » Sat Aug 01, 2020 8:59 pm
NVRTC (CUDA 10 run time compiler) is included with LuxCore and I guess you are running with a pre-CUDA 10 driver. It can not understand the code (i.e. PTX) compiled by LuxCore.
Just update your GPU driver and you should be fine.
P.S. the other options may be to replace the NVRTC DLLs included in LuxCore with a CUDA version compatible with your driver but it is more complex and it may be required only if your GPU is not supported anymore by NVIDIA.
mib2berlin
Post by mib2berlin » Sat Aug 01, 2020 9:08 pm
Sorry, forgot to add the driver version, it is 450.57.
The GTX 760 is 7 Years old, I have to buy a new one anyway, Cuda 11 does not support it anymore.
Cheers, mib
