Hello guys!
My first post here. I hope you all are doing well.
I can see that an image sequence can be used as a texture in the material nodes of BlendLuxCore, although it is not being refreshed in real time.
Unfortunately I can't find that option applied to lights - only single images are available
Is it possible to use image sequence as a light texture?
If not directly - is there a workaround via python scripting?
Using Image Sequence or Video file as a light texture
Re: Using Image Sequence or Video file as a light texture
You can use a plane object with emissive black matte material.
An area light is the same internally.
