when I try to take render it takes forever for my computer to take its render
biperiden
Post by biperiden »
Hi guys, I need your suggest about my render problem. I created a scene, inside of the scene i have just simple plane and glass bottle also i used Hdri map and all setup is basic. when I try to take render it takes forever for my computer to take its render and it shows that remaining time is unknown. the version of the Blender 2.83. I would be more than happy, if you help me out for this issue.
Re: Blend Luxcore not so responsive during rendering
biperiden wrote: Thu Jul 02, 2020 9:19 pm Hi guys, I need your suggest about my render problem. I created a scene, inside of the scene i have just simple plane and glass bottle also i used Hdri map and all setup is basic. when I try to take render it takes forever for my computer to take its render and it shows that remaining time is unknown. the version of the Blender 2.83. I would be more than happy, if you help me out for this issue.
This is likely to be the first and only-once GPU kernel compilation, it takes about 90secs on a fast CPU, what GPU/CPU do you have ?
Theo_Gottwald
Re: when I try to take render it takes forever for my computer to take its render
Post by Theo_Gottwald »
Rendering Images with very high resolution like 10000x8000 Luxrender is very unresponsive. Also compared with other renderers.
If i would be a programmer, i would say "It needs some DoEvents()" somewhere.
In short: The higher the resolution the longer you have to wait bevor you can change the size of the render-window or scroll in and out.
It does NOT need any dedicated test-scene. Is like that with ANY Scene. Just render it with a very high resolution.
I am right now rendering in Tiled-Mode.Its not responsive.
