Viewport render crash on GPU Cuda
Re: Viewport render crash on GPU Cuda
In theory this may even work but: every pending RenderSession will keep a full copy of the scene in ram. You can just keep resizing the view port and the memory usage will increase and increase
Can this have an impact on viewport responssivness ?
Sharlybg wrote: Mon Sep 07, 2020 1:00 pm
You can very easily run out of (CPU) memory and start to swap (i.e. bigger is the scene and less copies you will need to run out of memory).
kk34
Post by kk34 »
I got those errors with the last build....Win10/Ryzen/1070
Error: MBVHKernel OpenCL program compilation error
Error: MBVHKernel CUDA program compilation error
kk34 wrote: Tue Sep 08, 2020 10:18 am I got those errors with the last build....Win10/Ryzen/1070
Can you post the console output ?
kk34
Post by kk34 »
Updated to the last build aviable 2hrs ago...And no more Errors.
Just regular crash from the viewport when switching from preview to solid.
kk34 wrote: Tue Sep 08, 2020 8:14 pm Updated to the last build aviable 2hrs ago...And no more Errors.
Yes, I fixed the MBVH error.
nrnadig
Post by nrnadig »
Hello team,
i have query , i not able to render using GUP(NVIDIA Q600). THE FOLLOWING ERROR IS DISPLAYING.
pathocl kernel opencl program compilation error.
REGARDS
NRYBN
KITCHEN.blend
(3.15 MiB) Downloaded 209 times
nrnadig wrote: Sat May 01, 2021 7:39 am i have query , i not able to render using GUP(NVIDIA Q600). THE FOLLOWING ERROR IS DISPLAYING.
The NVIDIA Q600 is a Fermi GPU, it is very old: I think it was released about 10 years ago. The driver doesn't support a CUDA version recent enough to be able to run LuxCoreRender.
I'm afraid you can run only CPU rendering and you can not use the GPU.
