Viewport render crash on GPU Cuda
Re: Viewport render crash on GPU Cuda
Post by Sharlybg » Mon Sep 07, 2020 1:00 pm
In theory this may even work but: every pending RenderSession will keep a full copy of the scene in ram. You can just keep resizing the view port and the memory usage will increase and increase
Can this have an impact on viewport responssivness ?
Post by Dade » Mon Sep 07, 2020 1:06 pm
You can very easily run out of (CPU) memory and start to swap (i.e. bigger is the scene and less copies you will need to run out of memory).
kk34
Post by kk34 » Tue Sep 08, 2020 10:18 am
I got those errors with the last build....Win10/Ryzen/1070
Error: MBVHKernel OpenCL program compilation error
Error: MBVHKernel CUDA program compilation error
Post by Dade » Tue Sep 08, 2020 11:11 am
Can you post the console output ?
kk34
Post by kk34 » Tue Sep 08, 2020 8:14 pm
Updated to the last build aviable 2hrs ago...And no more Errors.
Just regular crash from the viewport when switching from preview to solid.
Post by Dade » Tue Sep 08, 2020 10:08 pm
Yes, I fixed the MBVH error.
