Moving from classic LuxRender
lighting_freak
Re: Moving from classic LuxRender
Post by lighting_freak » Fri Oct 05, 2018 12:00 pm
It is using the old LuxRender API, not the new LuxCore API.
Of course, I didn't meant that it is usable without any work. My thoughts were reworking the existing GUI to be compatible to new API.
Isn't it easier to do it that way?
But, let's face the current issues on network rendering first.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Fri Oct 05, 2018 3:51 pm
lighting_freak wrote:
Fri Oct 05, 2018 10:32 am
Well, not so many files after stopping the job, propably caused by the error.
They should be all: a .seed, a .md5 and a .flm for each rendering node.
lighting_freak
Post by lighting_freak » Fri Oct 05, 2018 7:19 pm
If those files are all, where do I find the result? The *.flm file can't be watched and there is no regular graphical format like *.jpg or png.
In the Console window an imge file name is mentioned, but this file doesn`t exist.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Fri Oct 05, 2018 10:10 pm
BR
You can merge them and/or trigger the output .png/.jpg/etc. with luxcoremerge: https://wiki.luxcorerender.org/Pyluxcoretool_merge (check https://wiki.luxcorerender.org/Pyluxcor ... ine_output).
lighting_freak
Post by lighting_freak » Sat Oct 06, 2018 9:25 am
Ive tested this command line, with this error:
C:\>C:\Users\Martin\Downloads\luxcorerender-v2.1alpha4-win64-opencl\pyluxcoretoo
l.exe C:\Users\Martin\Desktop\Job\Subsurface_Scattering_LuxCore\00001-netrenderi
ng\RenderFarmNodeThread-192.168.188.23_18018-1.flm C:\Users\Martin\Desktop\Job\S
ubsurface_Scattering_LuxCore\00001-netrendering\RenderFarmNodeThread-192.168.188
.23_18018-3.flm -o C:\Users\Martin\Desktop\Job\Subsurface_Scattering_LuxCore\000
  File "pyluxcoretool.py", line 76, in <module>
TypeError: Unknown command to execute: C:\Users\Martin\Desktop\Job\Subsurface_Sc
attering_LuxCore\00001-netrendering\RenderFarmNodeThread-192.168.188.23_18018-1.
flm
[3676] Failed to execute script pyluxcoretool
Another test was using quotes for the path and files:
l merge "C:\Users\Martin\Desktop\Job\Subsurface_Scattering_LuxCore\00001-netrend
ering\RenderFarmNodeThread-192.168.188.23_18018-3.flm" "C:\Users\Martin\Desktop\
Job\Subsurface_Scattering_LuxCore\00001-netrendering\RenderFarmNodeThread-192.16
8.188.25_18018-2.flm" -o "C:\Users\Martin\Desktop\Job\Subsurface_Scattering_LuxC
ore\00001.png"
[MainThread][2018-10-06 11:19:26,384] LuxCore 2.1alpha4
[MainThread][2018-10-06 11:19:26,384] Processing the base Film: C:\Users\Martin\
Desktop\Job\Subsurface_Scattering_LuxCore\00001-netrendering\RenderFarmNodeThrea
  File "pyluxcoretool.py", line 62, in <module>
  File "C:\Users\Martin\AppData\Local\Temp\_MEI24202\pyluxcoretools.zip\pyluxcor
etools\pyluxcoremerge\cmd.py", line 143, in main
etools\pyluxcoremerge\cmd.py", line 112, in LuxCoreMerge
etools\pyluxcoremerge\cmd.py", line 45, in LoadFilm
RuntimeError: requested integer size exceeds type size: 2
[6840] Failed to execute script pyluxcoretool
Both lines lead to some type of error.
Thanks for all of your support.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
acasta69
Post by acasta69 » Tue Oct 09, 2018 8:26 pm
This error should be fixed. You can get new pyluxcore / pyluxcoretools here:
https://www.dropbox.com/s/kou57ml7ki5z4 ... e.zip?dl=0
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
lighting_freak
Post by lighting_freak » Wed Oct 10, 2018 2:09 pm
first test was succesful... Two nodes were interacting and in the end a result file is written.
I`ll continue my tests.
Thank you for quick solutions and updates.
BR.
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Wed Oct 10, 2018 4:08 pm
Can you check if the dead-lock is still a problem (on Windows) or not ? It is not yet clear to me if we have a problem there or not.
lighting_freak
Post by lighting_freak » Fri Oct 12, 2018 8:30 am
I ran several tests. This dead-lock issue didn`t appear anymore. It sems to be resolved (at least for the moment).
One more issue appeared while network rendering. After click on "Finish job" this messages appear:
The scene I`ve exported came from this thread:
http://forums.luxcorerender.org/viewtopic.php?f=4&t=657
This is my exported file:
glasscubeluxcore_LuxCore.zip
(56.32 KiB) Downloaded 43 times
My first guess was that it may be due to *.exr format as output, but it happens with *.png as well.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Fri Oct 12, 2018 10:12 am
Your .bcf works fine here. Your error happens during the compilation of an basic image pipeline OpenCL kernel. You should get the same error at any point your try to update the screen, save the output (with network rendering but also in Blender or LuxCoreUI). Have you tried ? Does it always happen ?
It may be a specific (driver) problem of the Quadro 2000M you are using for this test :idea:
