AttributeError: 'LuxCoreScene' object has no attribute 'opencl'
acasta69
Re: AttributeError: 'LuxCoreScene' object has no attribute 'opencl'
Post by acasta69 »
FarbigeWelt wrote: Wed Jun 24, 2020 12:25 pm Delete all kernel cache files ( :?: where are these located on a Windows 10 Pro :?: )
Cached kernel locations should be as follows on Windows (I have the Home edition, but I think it does not matter for this file location):
LuxCore 2.3:
C:\Users\<username>\AppData\Local\Temp\kernel_cache
For v2.4 there are two locations:
C:\Users\<username>\AppData\Local\Temp\cuda_kernel_cache
C:\Users\<username>\AppData\Local\Temp\ocl_kernel_cache
FarbigeWelt wrote: Wed Jun 24, 2020 12:25 pm Does anyone have other / further suggestions :?:
Maybe double-check the GPU driver installation - re-installing might be a good idea.
Re: Stops @'[BVHKernel] Compiling kernels' and crashes
Post by FarbigeWelt »
OS: Microsoft Windows 10 Pro (64 bit)
version: 10.0.19041 Build 19041
Blender 2.83: (new installation, on another drive than previous, de-installed version)
-branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f771, type: Release
LuxCoreRender v2.4alpha0:
-BlendLuxCore/commit/00113b59944fef495114d3723e2f7b379a156a6e
-LuxCore/commit/6f9716533448f70096355131946eb702a4a20784
New installed graphic card driver:
driver: AMD Radeon Software Adrenalin 2020 Edition 20.5.1 Driver Version 20.10 (Windows Driver Store Version 27.20.1017.1011)
renderer: 'AMD Radeon RX 5700 XT'
vendor: 'ATI Technologies Inc.'
version: '4.5.13596 Core Profile Context 20.5.1 27.20.1023.1001'
LuxMark 3.1 benchmarks as ever, 'openCL GPU' all three test scenes, with both cards)
CPU device capabilities: SSE2 SSE3 SSE41 AVX AVX2
Platform Profile:	FULL_PROFILE
Platform Extensions:	cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
Number of devices:	2
Device(s): #0 / #1
-Device Name: gfx1010
-Device Board Name: AMD Radeon RX 5700 XT
-Device Vendor: Advanced Micro Devices, Inc.
-Device OpenCL C Version: OpenCL C 2.0
-Device Profile: FULL_PROFILE
-Device Version: OpenCL 2.0 AMD-APP (3075.13)
-Device Extensions: cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_liquid_flash cl_amd_copy_buffer_p2p cl_amd_planar_yuv
-Device Max clock frequency (MHz): 1755
-Device Max compute units: 20
-Device Max work group size: 256
Softwareversion		2020.0610.0030.923
Treiberversion		20.10.23.01-200610a-356490C-
			RadeonProEnterprise
Anbieter		Advanced Micro Devices, Inc.
2D-Treiberversion	8.1.1.1634
Direct3D' Version	9.14.10.01443
OpenGL' Version		26.20.11000.13596
AMD			10.0.1.12
Vulkan'" Driver Version	2.0.137
Vulkan'" API Version	1.2.133
Windows-Version	Windows 10 (64 bit)
Engine CPU renders perfectly as expected the default cube scene
C:\Users\Michael>"E:\Program Files\Blender Foundation\Blender 2.83\blender.exe"
Read prefs: C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.83\config\userpref.blend
found bundled python: E:\Program Files\Blender Foundation\Blender 2.83\2.83\python
BlendLuxCore 2.4alpha0 registered (with pyluxcore 2.4alpha0)
[Engine/Final] Rendering layer "View Layer"
[Exporter] Creating session
[SDL][1268.954] Camera type: perspective
[SDL][1268.954] Camera position: Point[7.35889, -6.92579, 4.95831]
[SDL][1268.954] Camera target: Point[6.70733, -6.31162, 4.51304]
[SDL][1268.954] Camera clipping plane disabled
[SDL][1268.954] Material definition: Material2375206263640
[SDL][1268.954] Scene objects count: 1
[SDL][1268.954] Light definition: 2375207414312
[SDL][1268.954] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][1268.969] Configuration:
[LuxCore][1268.969]   path.pathdepth.total = 7
[LuxCore][1268.969]   path.pathdepth.diffuse = 5
[LuxCore][1268.969]   path.pathdepth.glossy = 5
[LuxCore][1268.969]   path.pathdepth.specular = 6
[LuxCore][1268.969]   path.hybridbackforward.enable = 0
[LuxCore][1268.969]   path.hybridbackforward.partition = 0.80000000000000004
[LuxCore][1268.969]   path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][1268.969]   film.noiseestimation.warmup = 8
[LuxCore][1268.969]   film.noiseestimation.step = 32
[LuxCore][1268.969]   sampler.sobol.adaptive.strength = 0.89999997615814209
[LuxCore][1268.969]   sampler.sobol.bucketsize = 16
[LuxCore][1268.969]   sampler.sobol.tilesize = 16
[LuxCore][1268.969]   sampler.sobol.supersampling = 1
[LuxCore][1268.969]   sampler.sobol.overlapping = 1
[LuxCore][1268.969]   renderengine.type = "PATHCPU"
[LuxCore][1268.969]   sampler.type = "SOBOL"
[LuxCore][1268.969]   film.width = 960
[LuxCore][1268.969]   film.height = 540
[LuxCore][1268.969]   film.filter.type = "BLACKMANHARRIS"
[LuxCore][1268.969]   film.filter.width = 1.5
[LuxCore][1268.969]   lightstrategy.type = "LOG_POWER"
[LuxCore][1268.969]   scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][1268.969]   scene.epsilon.max = 0.10000000149011612
[LuxCore][1268.969]   film.opencl.enable = 0
[LuxCore][1268.969]   path.forceblackbackground.enable = 0
[LuxCore][1268.969]   renderengine.seed = 1
[LuxCore][1268.969]   film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][1268.969]   film.outputs.0.index = 0
[LuxCore][1268.969]   film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][1268.985]   film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][1268.985]   film.outputs.1.index = 1
[LuxCore][1268.985]   film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
[LuxCore][1268.985]   film.imagepipelines.001.0.type = "NOP"
[LuxCore][1268.985]   film.imagepipelines.001.1.type = "TONEMAP_LINEAR"
[LuxCore][1268.985]   film.imagepipelines.001.1.scale = 1
[LuxCore][1268.985]   film.imagepipelines.001.radiancescales.0.enabled = 1
[LuxCore][1268.985]   film.imagepipelines.001.radiancescales.0.globalscale = 1
[LuxCore][1268.985]   film.imagepipelines.001.radiancescales.0.rgbscale = 1 1 1
[LuxCore][1268.985]   film.imagepipelines.001.2.type = "GAMMA_CORRECTION"
[LuxCore][1268.985]   film.imagepipelines.001.2.value = 2.2000000000000002
[LuxCore][1268.985]   film.noiseestimation.index = 1
[LuxCore][1268.985]   film.imagepipelines.000.0.type = "NOP"
[LuxCore][1268.985]   film.imagepipelines.000.1.type = "TONEMAP_LINEAR"
[LuxCore][1268.985]   film.imagepipelines.000.1.scale = 1
[LuxCore][1268.985]   film.imagepipelines.000.radiancescales.0.enabled = 1
[LuxCore][1268.985]   film.imagepipelines.000.radiancescales.0.globalscale = 1
[LuxCore][1268.985]   film.imagepipelines.000.radiancescales.0.rgbscale = 1 1 1
[LuxCore][1268.985]   batch.haltspp = 128
[LuxCore][1268.985]   batch.halttime = 0
[LuxCore][1268.985] File Name Resolver Configuration:
Export took 0.0 s
[LuxCore][1268.985] Film resolution: 960x540
[SDL][1268.985] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][1268.985] Image pipeline: film.imagepipelines.000
[SDL][1268.985] Image pipeline step 0: NOP
[SDL][1268.985] Image pipeline step 1: TONEMAP_LINEAR
[SDL][1268.985] Image pipeline: film.imagepipelines.001
[SDL][1268.985] Image pipeline step 2: GAMMA_CORRECTION
[SDL][1268.985] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[SDL][1268.985] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_1.png]
[LuxRays][1268.985] OpenCL support: enabled
[LuxRays][1268.985] OpenCL Platform 0: AMD Accelerated Parallel Processing
[LuxRays][1268.985] CUDA support: enabled
[LuxRays][1268.985] Device 0 name: Native
[LuxRays][1268.985] Device 0 type: NATIVE_THREAD
[LuxRays][1268.985] Device 0 compute units: 1
[LuxRays][1268.985] Device 0 preferred float vector width: 4
[LuxRays][1268.985] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][1269.000] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][1269.000] Device 0 has out of core memory support: 0
[LuxRays][1269.000] Device 1 name: gfx1010
[LuxRays][1269.000] Device 1 type: OPENCL_GPU
[LuxRays][1269.000] Device 1 compute units: 20
[LuxRays][1269.000] Device 1 preferred float vector width: 1
[LuxRays][1269.000] Device 1 max allocable memory: 8176MBytes
[LuxRays][1269.000] Device 1 max allocable memory block size: 6732MBytes
[LuxRays][1269.000] Device 1 has out of core memory support: 0
[LuxRays][1269.000] Device 2 name: gfx1010
[LuxRays][1269.000] Device 2 type: OPENCL_GPU
[LuxRays][1269.000] Device 2 compute units: 20
[LuxRays][1269.000] Device 2 preferred float vector width: 1
[LuxRays][1269.000] Device 2 max allocable memory: 8176MBytes
[LuxRays][1269.000] Device 2 max allocable memory block size: 6732MBytes
[LuxRays][1269.000] Device 2 has out of core memory support: 0
[LuxRays][1269.000] Creating 8 intersection device(s)
[LuxRays][1269.000] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][1269.000] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxCore][1269.000] Configuring 8 CPU render threads
[LuxRays][1269.000] Preprocessing DataSet
[LuxRays][1269.000] Total vertex count: 24
[LuxRays][1269.000] Total triangle count: 12
[LuxRays][1269.000] Preprocessing DataSet done
[LuxRays][1269.000] Adding DataSet accelerator: EMBREE
[LuxRays][1269.000] EmbreeAccel build time: 0ms
Session started in 0.0 s
Recommended clamp value: 0.6914191269371595
[LuxCore][1276.500] Noise estimation: first pass
[LuxCore][1284.000] Noise estimation: Error mean = 0.00220231
[LuxCore][1294.422] Noise estimation: Error mean = 0.00126868
[LuxCore][1304.547] Samples per pixel 100%, rendering done.
[Engine/Final] Finished rendering layer "View Layer"
Engine GPU is not able to render the default cube scene on my dual amd rx 5700 xt (gfx1010) system.
The openCL kernel compilation [BVHKernel] crashes Blender immediately.
[SDL][1367.250] Camera type: perspective
[SDL][1367.250] Camera position: Point[7.35889, -6.92579, 4.95831]
[SDL][1367.250] Camera target: Point[6.70733, -6.31162, 4.51304]
[SDL][1367.250] Camera clipping plane disabled
[SDL][1367.250] Material definition: Material2375206263640
[SDL][1367.250] Scene objects count: 1
[SDL][1367.250] Light definition: 2375207414312
[SDL][1367.250] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][1367.266] Configuration:
[LuxCore][1367.266]   path.pathdepth.total = 7
[LuxCore][1367.266]   path.pathdepth.diffuse = 5
[LuxCore][1367.266]   path.pathdepth.glossy = 5
[LuxCore][1367.266]   path.pathdepth.specular = 6
[LuxCore][1367.266]   path.hybridbackforward.enable = 0
[LuxCore][1367.266]   path.hybridbackforward.partition = 0
[LuxCore][1367.266]   path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][1367.266]   opencl.cpu.use = 0
[LuxCore][1367.266]   opencl.gpu.use = 1
[LuxCore][1367.266]   opencl.devices.select = "11"
[LuxCore][1367.266]   film.noiseestimation.warmup = 8
[LuxCore][1367.266]   film.noiseestimation.step = 32
[LuxCore][1367.266]   sampler.sobol.adaptive.strength = 0.89999997615814209
[LuxCore][1367.266]   sampler.sobol.bucketsize = 16
[LuxCore][1367.266]   sampler.sobol.tilesize = 16
[LuxCore][1367.266]   sampler.sobol.supersampling = 1
[LuxCore][1367.266]   sampler.sobol.overlapping = 1
[LuxCore][1367.266]   renderengine.type = "PATHOCL"
[LuxCore][1367.266]   sampler.type = "SOBOL"
[LuxCore][1367.266]   film.width = 960
[LuxCore][1367.266]   film.height = 540
[LuxCore][1367.266]   film.filter.type = "BLACKMANHARRIS"
[LuxCore][1367.266]   film.filter.width = 1.5
[LuxCore][1367.266]   lightstrategy.type = "LOG_POWER"
[LuxCore][1367.266]   scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][1367.266]   scene.epsilon.max = 0.10000000149011612
[LuxCore][1367.266]   film.opencl.enable = 0
[LuxCore][1367.266]   path.forceblackbackground.enable = 0
[LuxCore][1367.266]   renderengine.seed = 1
[LuxCore][1367.266]   film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][1367.266]   film.outputs.0.index = 0
[LuxCore][1367.266]   film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][1367.282]   film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][1367.282]   film.outputs.1.index = 1
[LuxCore][1367.282]   film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
[LuxCore][1367.282]   film.imagepipelines.001.0.type = "NOP"
[LuxCore][1367.282]   film.imagepipelines.001.1.type = "TONEMAP_LINEAR"
[LuxCore][1367.282]   film.imagepipelines.001.1.scale = 1
[LuxCore][1367.282]   film.imagepipelines.001.radiancescales.0.enabled = 1
[LuxCore][1367.282]   film.imagepipelines.001.radiancescales.0.globalscale = 1
[LuxCore][1367.282]   film.imagepipelines.001.radiancescales.0.rgbscale = 1 1 1
[LuxCore][1367.282]   film.imagepipelines.001.2.type = "GAMMA_CORRECTION"
[LuxCore][1367.282]   film.imagepipelines.001.2.value = 2.2000000000000002
[LuxCore][1367.282]   film.noiseestimation.index = 1
[LuxCore][1367.282]   film.imagepipelines.000.0.type = "NOP"
[LuxCore][1367.282]   film.imagepipelines.000.1.type = "TONEMAP_LINEAR"
[LuxCore][1367.282]   film.imagepipelines.000.1.scale = 1
[LuxCore][1367.282]   film.imagepipelines.000.radiancescales.0.enabled = 1
[LuxCore][1367.282]   film.imagepipelines.000.radiancescales.0.globalscale = 1
[LuxCore][1367.282]   film.imagepipelines.000.radiancescales.0.rgbscale = 1 1 1
[LuxCore][1367.282]   batch.haltspp = 128
[LuxCore][1367.282]   batch.halttime = 0
[LuxCore][1367.282] File Name Resolver Configuration:
Export took 0.0 s
Step: 0/2
Creating kernel cache entry with configuration properties:
And scene properties:
[SDL][1367.282] Define ImageMap: image.png
[SDL][1367.282] Camera type: perspective
[SDL][1367.282] Camera position: Point[1, 6, 3]
[SDL][1367.282] Camera target: Point[0, 0, 0.5]
[SDL][1367.282] Camera clipping plane disabled
[SDL][1367.282] Light definition: infinite_light
[SDL][1367.282] Material definition: matte_mat
[SDL][1367.282] Scene objects count: 1
[SDL][1367.282] Texture definition: constfloat3_tex
[SDL][1367.282] Material definition: constfloat3_tmat
[SDL][1367.297] Scene objects count: 1
[LuxCore][1367.297] Configuration:
[LuxCore][1367.297]   renderengine.type = "PATHOCL"
[LuxCore][1367.297]   sampler.type = "SOBOL"
[LuxCore][1367.297]   scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][1367.297]   scene.epsilon.max = 0.10000000149011612
[LuxCore][1367.297]   opencl.devices.select = "11"
[LuxCore][1367.297]   film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][1367.297]   film.outputs.1.filename = "image.png"
[LuxCore][1367.297] File Name Resolver Configuration:
[LuxCore][1367.297] Film resolution: 640x640
[SDL][1367.297] Film output definition: RGB_IMAGEPIPELINE [image.png]
[LuxRays][1367.297] OpenCL support: enabled
[LuxRays][1367.297] OpenCL Platform 0: AMD Accelerated Parallel Processing
[LuxRays][1367.297] CUDA support: enabled
[LuxRays][1367.297] Device 0 name: Native
[LuxRays][1367.297] Device 0 type: NATIVE_THREAD
[LuxRays][1367.297] Device 0 compute units: 1
[LuxRays][1367.297] Device 0 preferred float vector width: 4
[LuxRays][1367.297] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][1367.297] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][1367.297] Device 0 has out of core memory support: 0
[LuxRays][1367.297] Device 1 name: gfx1010
[LuxRays][1367.297] Device 1 type: OPENCL_GPU
[LuxRays][1367.297] Device 1 compute units: 20
[LuxRays][1367.297] Device 1 preferred float vector width: 1
[LuxRays][1367.297] Device 1 max allocable memory: 8176MBytes
[LuxRays][1367.297] Device 1 max allocable memory block size: 6732MBytes
[LuxRays][1367.297] Device 1 has out of core memory support: 0
[LuxRays][1367.297] Device 2 name: gfx1010
[LuxRays][1367.297] Device 2 type: OPENCL_GPU
[LuxRays][1367.297] Device 2 compute units: 20
[LuxRays][1367.297] Device 2 preferred float vector width: 1
[LuxRays][1367.297] Device 2 max allocable memory: 8176MBytes
[LuxRays][1367.297] Device 2 max allocable memory block size: 6732MBytes
[LuxRays][1367.297] Device 2 has out of core memory support: 0
[LuxRays][1367.297] Creating 10 intersection device(s)
[LuxRays][1367.313] Allocating intersection device 0: gfx1010 (Type = OPENCL_GPU)
[LuxRays][1367.313] Allocating intersection device 1: gfx1010 (Type = OPENCL_GPU)
[LuxRays][1367.313] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 8: Native (Type = NATIVE_THREAD)
[LuxRays][1367.313] Allocating intersection device 9: Native (Type = NATIVE_THREAD)
[LuxCore][1367.313] CUDA devices used:
[LuxCore][1367.313] OpenCL devices used:
[LuxCore][1367.313] [gfx1010 OpenCLIntersect]
[LuxCore][1367.313]   Device OpenCL version: OpenCL 2.0 AMD-APP (3075.13)
[LuxCore][1367.313] Native devices used: 8
[LuxCore][1367.313] Configuring 2 OpenCL render threads
[LuxCore][1367.313] Configuring 8 native render threads
[LuxRays][1367.313] Preprocessing DataSet
[LuxRays][1367.313] Total vertex count: 48
[LuxRays][1367.313] Total triangle count: 24
[LuxRays][1367.313] Preprocessing DataSet done
[LuxRays][1367.313] Adding DataSet accelerator: BVH
[LuxRays][1367.313] BVH Dataset preprocessing time: 0ms
[LuxRays][1367.313] BVH builder: EMBREE_BINNED_SAH
[LuxRays][1367.313] BVH build hierarchy time: 0ms
[LuxRays][1367.313] BVH total build time: 0ms
[LuxRays][1367.313] Total BVH memory usage: 1Kbytes
[LuxRays][1367.313] Adding DataSet accelerator: EMBREE
[LuxRays][1367.313] EmbreeAccel build time: 0ms
[LuxRays][1368.360] [Device gfx1010 OpenCLIntersect] BVH mesh vertices buffer size: 576bytes
[LuxRays][1368.360] [Device gfx1010 OpenCLIntersect] BVH nodes buffer size: 1248bytes
[LuxRays][1368.360] [BVHKernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_WINDOWS -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][1368.360] [BVHKernel] Compiling kernels
MacBook Air with M1
Try the very latest (after e8ce8fd96cd4d25794b76398b486318c71925be0 commit), does still happen ?
With pyluxcore 2.4beta1 .. OpenCL render threads .. Finished rendering layer
Dade wrote: Fri Jun 26, 2020 11:37 am Try the very latest (after e8ce8fd96cd4d25794b76398b486318c71925be0 commit), does still happen ?
No. A least not for the default cube scene.
Kernel compilation succeed.
Rendering succeed.
Thank you for your support and work, Dade :!:
LuxCoreRender
BlendLuxCore: commit/960d9337dff3233258606845f1fe55967ed032b9
LuxCore: commit/2393bc8f337310e648af2df2376fe39c3b6b02ad
Log
[LuxCore][925.969] Configuring 2 OpenCL render threads
BlendLuxCore 2.4alpha0 registered (with pyluxcore 2.4beta1)
[SDL][925.891] Camera type: perspective
[SDL][925.891] Camera position: Point[7.35889, -6.92579, 4.95831]
[SDL][925.891] Camera target: Point[6.70733, -6.31162, 4.51304]
[SDL][925.891] Camera clipping plane disabled
[SDL][925.891] Material definition: Material2904862938120
[SDL][925.891] Scene objects count: 1
[SDL][925.891] Light definition: 2904862325416
[SDL][925.891] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][925.907] Configuration:
[LuxCore][925.907]   path.pathdepth.total = 7
[LuxCore][925.907]   path.pathdepth.diffuse = 5
[LuxCore][925.907]   path.pathdepth.glossy = 5
[LuxCore][925.907]   path.pathdepth.specular = 6
[LuxCore][925.907]   path.hybridbackforward.enable = 0
[LuxCore][925.907]   path.hybridbackforward.partition = 0
[LuxCore][925.907]   path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][925.907]   opencl.cpu.use = 0
[LuxCore][925.907]   opencl.gpu.use = 1
[LuxCore][925.907]   opencl.devices.select = "11"
[LuxCore][925.907]   film.noiseestimation.warmup = 8
[LuxCore][925.907]   film.noiseestimation.step = 32
[LuxCore][925.907]   sampler.sobol.adaptive.strength = 0.89999997615814209
[LuxCore][925.907]   sampler.sobol.bucketsize = 16
[LuxCore][925.907]   sampler.sobol.tilesize = 16
[LuxCore][925.907]   sampler.sobol.supersampling = 1
[LuxCore][925.907]   sampler.sobol.overlapping = 1
[LuxCore][925.907]   renderengine.type = "PATHOCL"
[LuxCore][925.907]   sampler.type = "SOBOL"
[LuxCore][925.907]   film.width = 1920
[LuxCore][925.907]   film.height = 1080
[LuxCore][925.907]   film.filter.type = "BLACKMANHARRIS"
[LuxCore][925.907]   film.filter.width = 1.5
[LuxCore][925.907]   lightstrategy.type = "LOG_POWER"
[LuxCore][925.907]   scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][925.907]   scene.epsilon.max = 0.10000000149011612
[LuxCore][925.907]   film.opencl.enable = 0
[LuxCore][925.907]   path.forceblackbackground.enable = 0
[LuxCore][925.907]   renderengine.seed = 1
[LuxCore][925.907]   film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][925.907]   film.outputs.0.index = 0
[LuxCore][925.907]   film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][925.907]   film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][925.907]   film.outputs.1.index = 1
[LuxCore][925.907]   film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
[LuxCore][925.907]   film.imagepipelines.001.0.type = "NOP"
[LuxCore][925.907]   film.imagepipelines.001.1.type = "TONEMAP_LINEAR"
[LuxCore][925.907]   film.imagepipelines.001.1.scale = 1
[LuxCore][925.907]   film.imagepipelines.001.radiancescales.0.enabled = 1
[LuxCore][925.907]   film.imagepipelines.001.radiancescales.0.globalscale = 1
[LuxCore][925.907]   film.imagepipelines.001.radiancescales.0.rgbscale = 1 1 1
[LuxCore][925.907]   film.imagepipelines.001.2.type = "GAMMA_CORRECTION"
[LuxCore][925.907]   film.imagepipelines.001.2.value = 2.2000000000000002
[LuxCore][925.907]   film.noiseestimation.index = 1
[LuxCore][925.907]   film.imagepipelines.000.0.type = "NOP"
[LuxCore][925.907]   film.imagepipelines.000.1.type = "TONEMAP_LINEAR"
[LuxCore][925.907]   film.imagepipelines.000.1.scale = 1
[LuxCore][925.907]   film.imagepipelines.000.radiancescales.0.enabled = 1
[LuxCore][925.907]   film.imagepipelines.000.radiancescales.0.globalscale = 1
[LuxCore][925.922]   film.imagepipelines.000.radiancescales.0.rgbscale = 1 1 1
[LuxCore][925.922]   batch.haltthreshold = 0.0390625
[LuxCore][925.922]   batch.haltthreshold.warmup = 64
[LuxCore][925.922]   batch.haltthreshold.step = 64
[LuxCore][925.922]   batch.haltthreshold.filter.enable = 1
[LuxCore][925.922]   batch.haltthreshold.stoprendering.enable = 1
[LuxCore][925.922]   batch.haltspp = 256
[LuxCore][925.922]   batch.halttime = 0
[LuxCore][925.922] File Name Resolver Configuration:
Export took 0.0 s
[LuxCore][925.922] Film resolution: 1920x1080
[SDL][925.922] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][925.922] Image pipeline: film.imagepipelines.000
[SDL][925.922] Image pipeline step 0: NOP
[SDL][925.922] Image pipeline step 1: TONEMAP_LINEAR
[SDL][925.922] Image pipeline: film.imagepipelines.001
[SDL][925.922] Image pipeline step 2: GAMMA_CORRECTION
[SDL][925.922] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[SDL][925.922] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_1.png]
[LuxRays][925.954] OpenCL support: enabled
[LuxRays][925.954] OpenCL Platform 0: AMD Accelerated Parallel Processing
[LuxRays][925.954] CUDA support: enabled
[LuxRays][925.954] Device 0 name: Native
[LuxRays][925.954] Device 0 type: NATIVE_THREAD
[LuxRays][925.954] Device 0 compute units: 1
[LuxRays][925.954] Device 0 preferred float vector width: 4
[LuxRays][925.954] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][925.954] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][925.969] Device 0 has out of core memory support: 0
[LuxRays][925.969] Device 1 name: gfx1010
[LuxRays][925.969] Device 1 type: OPENCL_GPU
[LuxRays][925.969] Device 1 compute units: 20
[LuxRays][925.969] Device 1 preferred float vector width: 1
[LuxRays][925.969] Device 1 max allocable memory: 8176MBytes
[LuxRays][925.969] Device 1 max allocable memory block size: 6732MBytes
[LuxRays][925.969] Device 1 has out of core memory support: 0
[LuxRays][925.969] Device 2 name: gfx1010
[LuxRays][925.969] Device 2 type: OPENCL_GPU
[LuxRays][925.969] Device 2 compute units: 20
[LuxRays][925.969] Device 2 preferred float vector width: 1
[LuxRays][925.969] Device 2 max allocable memory: 8176MBytes
[LuxRays][925.969] Device 2 max allocable memory block size: 6732MBytes
[LuxRays][925.969] Device 2 has out of core memory support: 0
[LuxRays][925.969] Creating 10 intersection device(s)
[LuxRays][925.969] Allocating intersection device 0: gfx1010 (Type = OPENCL_GPU)
[LuxRays][925.969] Allocating intersection device 1: gfx1010 (Type = OPENCL_GPU)
[LuxRays][925.969] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 8: Native (Type = NATIVE_THREAD)
[LuxRays][925.969] Allocating intersection device 9: Native (Type = NATIVE_THREAD)
[LuxCore][925.969] CUDA devices used:
[LuxCore][925.969] OpenCL devices used:
[LuxCore][925.969] [gfx1010 OpenCLIntersect]
[LuxCore][925.969]   Device OpenCL version: OpenCL 2.0 AMD-APP (3075.13)
[LuxCore][925.969] Native devices used: 8
[LuxCore][925.969] Configuring 8 native render threads
[LuxRays][925.969] Preprocessing DataSet
[LuxRays][925.969] Total vertex count: 24
[LuxRays][925.969] Total triangle count: 12
[LuxRays][925.969] Preprocessing DataSet done
[LuxRays][925.969] Adding DataSet accelerator: BVH
[LuxRays][925.985] BVH Dataset preprocessing time: 15ms
[LuxRays][925.985] BVH builder: EMBREE_BINNED_SAH
[LuxRays][925.985] BVH build hierarchy time: 0ms
[LuxRays][925.985] BVH total build time: 15ms
[LuxRays][925.985] Total BVH memory usage: 0Kbytes
[LuxRays][925.985] Adding DataSet accelerator: EMBREE
[LuxRays][925.985] Total vertex count: 24
[LuxRays][925.985] Total triangle count: 12
[LuxRays][925.985] EmbreeAccel build time: 0ms
[LuxRays][925.985] [Device gfx1010 OpenCLIntersect] BVH mesh vertices buffer size: 288bytes
[LuxRays][925.985] [Device gfx1010 OpenCLIntersect] BVH nodes buffer size: 608bytes
[LuxRays][925.985] [BVHKernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_WINDOWS -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][925.985] [BVHKernel] Compiling kernels
[LuxRays][925.985] [BVHKernel] Program cached
[LuxRays][926.000] [Device gfx1010 OpenCLIntersect] BVH mesh vertices buffer size: 288bytes
[LuxRays][926.000] [Device gfx1010 OpenCLIntersect] BVH nodes buffer size: 608bytes
[LuxRays][926.000] [BVHKernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_WINDOWS -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][926.000] [BVHKernel] Compiling kernels
[LuxRays][926.000] [BVHKernel] Program cached
[LuxCore][926.063] [PathOCLRenderEngine] OpenCL task count: 262144
[LuxCore][926.063] [PathOCLBaseRenderEngine] OpenCL max. page memory size: 6893568Kbytes
[LuxCore][926.063] Compile Geometry
[LuxCore][926.063] Scene geometry compilation time: 0ms
[LuxCore][926.063] Compile 1 Textures
[LuxCore][926.063] Texture evaluation ops count: 3
[LuxCore][926.063] Texture evaluation max. stack size: 3
[LuxCore][926.063] Textures compilation time: 0ms
[LuxCore][926.079] Compile 1 Materials
[LuxCore][926.079] Material evaluation ops count: 7
[LuxCore][926.079] Material evaluation max. stack size: 8
[LuxCore][926.079] Material compilation time: 0ms
[LuxCore][926.079] Compile Lights
[LuxCore][926.079] Lights compilation time: 0ms
[LuxCore][926.079] Compile ImageMaps
[LuxCore][926.079] Image maps page(s) count: 0
[LuxCore][926.079] Image maps compilation time: 0ms
[LuxCore][926.079] Always enabled OpenCL code:
[LuxCore][926.079] Compile Geometry
[LuxCore][926.079] Scene geometry compilation time: 0ms
[LuxCore][926.079] Compile 1 Textures
[LuxCore][926.079] Texture evaluation ops count: 3
[LuxCore][926.079] Texture evaluation max. stack size: 3
[LuxCore][926.079] Textures compilation time: 0ms
[LuxCore][926.079] Starting 2 OpenCL render threads
[LuxRays][926.125] [Device gfx1010 OpenCLIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 32400Kbytes
[LuxRays][926.125] [Device gfx1010 OpenCLIntersect] NOISE buffer size: 8100Kbytes
[LuxRays][926.157] [Device gfx1010 OpenCLIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 32400Kbytes
[LuxRays][926.157] [Device gfx1010 OpenCLIntersect] Camera buffer size: 5468bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Normals buffer size: 288bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] UVs buffer size: 192bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Triangle normals buffer size: 144bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Vertices buffer size: 288bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Triangles buffer size: 144bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Mesh description buffer size: 312bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Textures buffer size: 296bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Texture evaluation ops buffer size: 24bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Texture evaluation stacks buffer size: 3072Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Materials buffer size: 224bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Material evaluation ops buffer size: 84bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Material evaluation stacks buffer size: 8192Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Scene objects buffer size: 24bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Lights buffer size: 664bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Env. light indices buffer size: 4bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Light offsets (Part I) buffer size: 4bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Env. light distributions buffer size: 1028Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] LightsDistribution buffer size: 24bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] InfiniteLightSourcesDistribution buffer size: 24bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] Ray buffer size: 12288Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] RayHit buffer size: 5120Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] GPUTaskConfiguration buffer size: 288bytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] GPUTask buffer size: 169984Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] GPUTaskDirectLight buffer size: 15360Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] GPUTaskState buffer size: 100352Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] GPUTask Stats buffer size: 1024Kbytes
[LuxRays][926.172] [Device gfx1010 OpenCLIntersect] SamplerSharedData buffer size: 8109Kbytes
[LuxCore][926.188] [PathOCLBaseRenderThread::0] Size of a Sample: 40bytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] Sample buffer size: 10240Kbytes
[LuxCore][926.188] [PathOCLBaseRenderThread::0] Size of a SampleData: 8bytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] SampleData buffer size: 2048Kbytes
[LuxCore][926.188] [PathOCLBaseRenderThread::0] Size of a SampleResult: 304bytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] Sample buffer size: 77824Kbytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] PathInfo buffer size: 27648Kbytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] DirectLightVolumeInfo buffer size: 11264Kbytes
[LuxRays][926.188] [Device gfx1010 OpenCLIntersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][926.188] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxRays][926.188] [PathOCL kernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXCORE_AMD_OPENCL -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_WINDOWS -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][926.188] [PathOCL kernel] Compiling kernels
[LuxRays][926.235] [PathOCL kernel] Program cached
[LuxCore][926.235] [PathOCLBaseRenderThread::0] Compiling Film_Clear Kernel
[LuxCore][926.235] [PathOCLBaseRenderThread::0] Compiling InitSeed Kernel
[LuxCore][926.235] [PathOCLBaseRenderThread::0] Compiling Init Kernel
[LuxCore][926.235] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][926.235] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][926.250] [PathOCLBaseRenderThread::0] AdvancePaths_MK_* workgroup size: 32
[LuxCore][926.250] [PathOCLBaseRenderThread::0] Kernels compilation time: 62ms
[LuxRays][926.282] [Device gfx1010 OpenCLIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 32400Kbytes
[LuxRays][926.282] [Device gfx1010 OpenCLIntersect] NOISE buffer size: 8100Kbytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 32400Kbytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Camera buffer size: 5468bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Normals buffer size: 288bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] UVs buffer size: 192bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Triangle normals buffer size: 144bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Vertices buffer size: 288bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Triangles buffer size: 144bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Mesh description buffer size: 312bytes
[LuxRays][926.329] [Device gfx1010 OpenCLIntersect] Textures buffer size: 296bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Texture evaluation ops buffer size: 24bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Texture evaluation stacks buffer size: 3072Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Materials buffer size: 224bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Material evaluation ops buffer size: 84bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Material evaluation stacks buffer size: 8192Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Scene objects buffer size: 24bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Lights buffer size: 664bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Env. light indices buffer size: 4bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Light offsets (Part I) buffer size: 4bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Env. light distributions buffer size: 1028Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] LightsDistribution buffer size: 24bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] InfiniteLightSourcesDistribution buffer size: 24bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Ray buffer size: 12288Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] RayHit buffer size: 5120Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] GPUTaskConfiguration buffer size: 288bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] GPUTask buffer size: 169984Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] GPUTaskDirectLight buffer size: 15360Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] GPUTaskState buffer size: 100352Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] GPUTask Stats buffer size: 1024Kbytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] SamplerSharedData buffer size: 8109Kbytes
[LuxCore][926.344] [PathOCLBaseRenderThread::1] Size of a Sample: 40bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Sample buffer size: 10240Kbytes
[LuxCore][926.344] [PathOCLBaseRenderThread::1] Size of a SampleData: 8bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] SampleData buffer size: 2048Kbytes
[LuxCore][926.344] [PathOCLBaseRenderThread::1] Size of a SampleResult: 304bytes
[LuxRays][926.344] [Device gfx1010 OpenCLIntersect] Sample buffer size: 77824Kbytes
[LuxRays][926.360] [Device gfx1010 OpenCLIntersect] PathInfo buffer size: 27648Kbytes
[LuxRays][926.360] [Device gfx1010 OpenCLIntersect] DirectLightVolumeInfo buffer size: 11264Kbytes
[LuxRays][926.360] [Device gfx1010 OpenCLIntersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][926.360] [PathOCLBaseRenderThread::1] Compiling kernels
[LuxRays][926.360] [PathOCL kernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXCORE_AMD_OPENCL -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_WINDOWS -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][926.360] [PathOCL kernel] Compiling kernels
[LuxRays][926.407] [PathOCL kernel] Program cached
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling Film_Clear Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling InitSeed Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling Init Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][926.407] [PathOCLBaseRenderThread::1] AdvancePaths_MK_* workgroup size: 32
[LuxCore][926.407] [PathOCLBaseRenderThread::1] Kernels compilation time: 47ms
[LuxCore][926.422] Starting 8 native render threads
Session started in 0.6 s
Recommended clamp value: 0.6896252720675955
[LuxCore][929.875] Noise estimation: first pass
[LuxCore][931.485] Convergence test first pass
[LuxCore][933.954] Noise estimation: Error mean = 0.00265189
[LuxCore][937.657] Noise estimation: Error mean = 0.00162377
[LuxCore][940.079] Convergence test: ToDo Pixels = 0, Max. Error = 0.0363556 [9.30704/256]
[LuxCore][940.079] Convergence 100%, rendering done.
MacBook Air with M1
