Why is there a limit of 8 lightgroups?
juangea
Post by juangea » Fri May 08, 2020 2:02 pm
That's it, simple question :)
Thanks!
Re: Why is there a limit of 8 lightgroups?
Post by Dade » Fri May 08, 2020 4:30 pm
Mostly because of GPUs/OpenCL, I must have a finite number there.
Post by B.Y.O.B. » Fri May 08, 2020 4:43 pm
Technically there's only a limit if you use an OpenCL engine, the CPU engines have no limit.
But in the Blender addon I'm always using the limit of 8 to make my life easier.
juangea
Post by juangea » Sat May 09, 2020 10:04 am
Ok, so it's a GPU limitation, understood :)
(I don't think it's a big problem, and I'm with you regarding making your life easier hahaha)
Post by B.Y.O.B. » Sat May 09, 2020 10:54 am
We could use a higher number if requested.
@Dade, I guess this would not raise memory consumption when the max. number of light groups is not actually used, right?
Post by Dade » Sat May 09, 2020 11:11 am
Yup, it would increase the size of the SampleResult structure, there is a SampleResult structure for each thread and there are hundred of thousands of GPU threads.
Post by B.Y.O.B. » Sat May 09, 2020 11:34 am
Oh, so my statement was wrong, it would have an impact even if no lightgroups are used at all.
Post by Dade » Sat May 09, 2020 11:57 am
Yes, GPU structures must have a fixed size or it would require conditional compilation (i.e. kernel re-compilation). There are other options (i.e. store the values in a dedicated buffer, not inside the SampleResult structure) but are complex.
