Technically there's only a limit if you use an OpenCL engine, the CPU engines have no limit.
But in the Blender addon I'm always using the limit of 8 to make my life easier.
We could use a higher number if requested.
@Dade, I guess this would not raise memory consumption when the max. number of light groups is not actually used, right?
B.Y.O.B. wrote: Sat May 09, 2020 10:54 am
Yup, it would increase the size of the SampleResult structure, there is a SampleResult structure for each thread and there are hundred of thousands of GPU threads.
B.Y.O.B. wrote: Sat May 09, 2020 11:34 am
Oh, so my statement was wrong, it would have an impact even if no lightgroups are used at all.
Yes, GPU structures must have a fixed size or it would require conditional compilation (i.e. kernel re-compilation). There are other options (i.e. store the values in a dedicated buffer, not inside the SampleResult structure) but are complex.
