Oh, I see, BlendLuxCore is using an hold properties name "path.photongi.indirect.glossinessusagethreshold" while the correct name is "path.photongi.glossinessusagethreshold" because the threshold is used for caustic cache too in PGI, not only for indirect cache.Dade wrote: ↑Sun May 10, 2020 11:08 amHave you disabled persistent cache ? Otherwise the cache is not re-computed.mischterlampe wrote: ↑Sun May 10, 2020 10:57 am Sorry, but I don't get it. Please exlude the light tracing issue here (I disabled it for this test) and just focus on the indirect cache.
This means, if I rise the threshold, more and more materials should become black. But noting happens. If I rise the threshold to 0.9, which means almost every material should be not in the cache, doesn't exclude the materials, the debug image looks the same like the threshold of 0.05. I lowered the threshold to 0.001, but the result was the same. So changing the threshold of the indirect cache doesn't do anything.
The flickerfree animation challenge
Re: The flickerfree animation challenge
First problem solved
I fixed this in the addon.Dade wrote: ↑Sun May 10, 2020 11:19 am Oh, I see, BlendLuxCore is using an hold properties name "path.photongi.indirect.glossinessusagethreshold" while the correct name is "path.photongi.glossinessusagethreshold" because the threshold is used for caustic cache too in PGI, not only for indirect cache.
The sun is at scale 4. With scale 1 and clamping off, caustics are stronger.mischterlampe wrote: ↑Thu May 07, 2020 10:54 am Nonetheless, the caustics of the glass bottle are very weak
This is Ryzen 3900x equivalent to 1 hour Border render
Can you try to render the animation with the latest built (when it is ready, in a couple of hours) and disabling the HDR light source (i.e. with only the sun light source) ?
I may have spotted the chain of events that is the source of the problem.
I have now rendered the scene with latest build and HDRI, sky or no background: everything flickers.
But worse is the speed loss: feels like 10 times slower and therefore looks noisier. Instead I have another suggestion.
By default it should be on auto, like the previous version after issue#312 fix which was rather stable with good light, only not in difficult circumstances like Danish Mood with HDRI.
But there would be an advanced setting similar to how clamping is implemented: the auto setting is already shown as a suggestion.
This would make animations possible even with moving glass bodies, as long as the lights are not animated.
Also we could use a BiDir render to gauge the correct brightness (somehow light tracing never matched BiDir results).
And no further development time would be wasted on this topic, the old speed advantage would be back too.
Of course this would also mean adjustable caustic brightness which is biased, but so what?
BTW here is a render with LuxCore v2.2, somehow nearly no flicker:
Why not introduce a manual setting for the average luminance?Dade wrote: ↑Sun May 10, 2020 10:59 am Knowing the average luminance of the image to render is the only Metropolis requirement but it is not a trivial one: it must be know before doing the rendering (i.e. requires the crystal ball). If the estimation is wrong the result will be brighter/darker than the correct solution.
I also rendered with the latest version 41da08d
and I get flickering, too.
https://streamable.com/wsu0yd
World Setting has no light, just one sun, 4k samples.
I asked to render without HDRepilectrolytics wrote: ↑Mon May 11, 2020 8:08 pm I have now rendered the scene with latest build and HDRI
Eh ? Do you know in advance the luminance of an image yet to render ?epilectrolytics wrote: ↑Mon May 11, 2020 8:08 pm Why not introduce a manual setting for the average luminance?
Please quote correctly:Dade wrote: ↑Mon May 11, 2020 8:25 pmI asked to render without HDRepilectrolytics wrote: ↑Mon May 11, 2020 8:08 pm I have now rendered the scene with latest build and HDRI
So I rendered it three times, including sun only, from which the GIF is made.epilectrolytics wrote: ↑Mon May 11, 2020 8:08 pm I have now rendered the scene with latest build and HDRI, sky or no background
After rendering first with auto setting the calculated luminance would be saved and shown in the UI (similar to suggested clamping value in BlendLuxCore). If it looks ok I switch to manual and use the saved value persistently for all further renderings such as of an animation.Dade wrote: ↑Mon May 11, 2020 8:25 pmEh ? Do you know in advance the luminance of an image yet to render ?epilectrolytics wrote: ↑Mon May 11, 2020 8:08 pm Why not introduce a manual setting for the average luminance?
Luminance is not constant across different frames.epilectrolytics wrote: ↑Mon May 11, 2020 8:46 pm After rendering first with auto setting the calculated luminance would be saved and shown in the UI (similar to suggested clamping value in BlendLuxCore).
