Hello Luxcore team!
Let me say fisrt that I'm absolutelly amazed by your work that you are doing. I switched from C4D+ Octane to Blender 2.8 like 6 months ago and now I discovered Luxcore! Really impressive work!
My question goes to possiblity of using Cycles nodes with its shaders, if you see it real to use them all in the close future or you think that there will be some limitations.
Basically I use Chocofur models and lot of them were made with old pre-principled shaders. So I'm in the cross point, whether to wait or start to adapt them to Luxcore render.
Many thanks!!
Ondrej
Cycles shader support
Re: Cycles shader support
I will probably add support for more Cycles nodes in the coming months, but it is unlikely that we will support all of them.
You can see which nodes are supported here: https://github.com/LuxCoreRender/BlendL ... issues/272
