Motion blur not working
Please do someone know where is the object motion blur check box is in Blendluxcore ? i don't remenber where to find it.
Re: BlendLuxCore Development
Working fine here with v2.3. I'll check v2.4 next.
In the future, please just open a bug report, it will tell you all the things to include in your report, like the LuxCore version you're using.
https://github.com/LuxCoreRender/BlendL ... .md&title=
Ok i will test the last blendluxcore 2.4 build. by the way i didn't even though about a bug (just a wrong setting from my side).B.Y.O.B. wrote: ↑Fri May 01, 2020 2:00 pmWorking fine here with latest v2.4 sources.
It also works with latest v2.4 here.
should i download the lastest CUDA / Opencl Luxcorerenderer builds . i fear the mess and bug arround it i'am rendering an animation
If you need a stable build, then of course you should stick to the latest stable version (v2.3 in this case).
Latest builds should only be used for testing, not for any serious work.
Sure but there is also the fact that i get my feet in 2.4 because of some new feature/Bug fix i require and now 2.4 build seem a bit messy. but here we go i will jump in the board
Work fine with 2.4 Cuda/Opencl. just remenber i can have both build on same system and switch between them. a real pleasure
