Hi, I did some ramp materials textures for procedural walls (solid modifier) but Luxcore don't read this kind of cycles nodes. It's a way to re-do it in a Luxcore material?
Captures:
mapping & cycles materials w/ Luxcore
Re: mapping & cycles materials w/ Luxcore
In theory all the nodes in your setups have an equivalent in LuxCore, but not all of them were implemented in the Cycles node reader yet.
You will have to recreate the setup with LuxCore nodes like this:
Thanks! Very nice.
I tried uvProject Modifier (with a rotate null, or 2,). Can be fancy for parametric objects (modifier, Sv) with uvWrap and uv offset (array modifier). I like to use cycles/eevee materials to simplify my workflow
