Oscar9531 wrote: ↑Thu Apr 16, 2020 11:12 am
Right now Im testing the interior scene I have to solve the problem in the best way I can
ELC.zip
Set Env. Light Caching Quality to 1.0. This should help.
Just a short render test:
Env. Light Caching_CPU, clamp 0.1, 256 samples, 0.75x, env. light q. 1.0.png
Yes, but OP had more severe problem initially.
This "quality" setting has no effect on the MIS+strong clamping issue. At best you hope to get more cache entries to hide them if the problem isnt too strong.
And secondary env. Cache has some crazy limitations when it comes to animated objects and heavy obstructions for lights. At some point samples might become too sparse in a dense scene and artifacting can appear and wont go away.
I really think caching should be reserved for GI and both environment and large amount of lights need other ways of optimization, something more stable, without preprocess and without unresolvable issues(cause yeah, direct light caching can cause some headaches too).
lacilaci wrote: ↑Wed Apr 15, 2020 6:26 am
Try using higher clamping values... These spots tend to show up mainly with low clamping.
There are also cases where they show up no matter what (dense structures etc) and then there is no help.... But in your case it does look more like a clamping related issue
Thanks again Laci, I think now I know how to deal with it hahaha
Great, render looks nice but now there is another issue to solve...
Try disabling "use cache" on your flooring material. You should still get good performance but floor won't reflect strong indirect light cache spots.
Unfortunately, indirect light cache isnt clamped at all, so when cache stores very strong light, it can be reflected on materials.
lacilaci wrote: ↑Mon Apr 20, 2020 8:03 pm
Now I get a light on the beam, I could only get rid of it by disabling the indirect light cache, it is not so annoying, so I can leave it like that for now hahaha but I will be testing it later to see how to solve it
