clBuildProgram
Posted: Fri Apr 10, 2020 5:38 pm
by arescet
Hi all,
i'm having an issue with OCL+path, it gives me an error saying "clBuildProgram".
my scene renders as expected with CPU+path so i don't know what is going on.
i thought it's the VRAM, but the scene is less than 2GB, my GPU has 6GB.
- Memory.PNG (7.04 KiB) Viewed 5666 times
Re: clBuildProgram
Posted: Fri Apr 10, 2020 5:54 pm
2gb file size doesn't translate in GPU memory occupency linearly and tend to increase a lot.
Do you have some large high resolution textures ?
Can you update your GPU driver it help sometime.
Maybe a dev could be sharper answering here.
Re: clBuildProgram
Posted: Fri Apr 10, 2020 7:37 pm
arescet wrote: ↑Fri Apr 10, 2020 5:38 pm
I need to see the full log message, it should be in Blender console.
Re: clBuildProgram
Posted: Fri Apr 10, 2020 9:18 pm
by arescet
Hi guys, thanks for your quick responses.
Sharlybg wrote: ↑Fri Apr 10, 2020 5:54 pm
no textures at all were used here, only the default material with a sky system linked to a sun lamp.
i will give the driver update a try, do you go for studio or game driver? or it doesn't matter?
my current driver is Nvidia studio driver ver 442.19 (02/03/20)
Re: clBuildProgram
Posted: Fri Apr 10, 2020 9:23 pm
by arescet
Dade wrote: ↑Fri Apr 10, 2020 7:37 pm
I'm getting this message when pasting the whole thing:
Your message contains 121365 characters.
The maximum number of allowed characters is 60000.
so here's the end part of it after all the BVH stuff, apologies if this is no help.
[LuxRays][66.250] Total BVH memory usage: 0Kbytes
[LuxRays][66.250] Building Multilevel Bounding Volume Hierarchy root tree
[LuxRays][66.250] MBVH root tree builder: EMBREE_BINNED_SAH
[LuxRays][66.250] MBVH build time: 18516ms
[LuxRays][66.250] Total Multilevel BVH memory usage: 2967471Kbytes
[LuxRays][66.250] Adding DataSet accelerator: EMBREE
[LuxRays][66.250] Total vertex count: 37072199
[LuxRays][66.250] Total triangle count: 63751084
[LuxRays][70.016] EmbreeAccel build time: 3766ms
[LuxRays][70.391] [Device GeForce GTX 1660 Ti Intersect] MBVH mesh vertices buffer size: 431805Kbytes
[LuxRays][71.641] [Device GeForce GTX 1660 Ti Intersect] MBVH nodes buffer size: 1572864Kbytes
[LuxRays][72.625] [Device GeForce GTX 1660 Ti Intersect] MBVH nodes buffer size: 1394607Kbytes
[LuxRays][73.203] [Device GeForce GTX 1660 Ti Intersect] MBVH leaf transformations buffer size: 6400bytes
[LuxRays][73.234] [OpenCL device::GeForce GTX 1660 Ti Intersect] MBVH compilation error:
<kernel>:1320:20: error: use of undeclared identifier 'MBVH_NODES_PAGE_SIZE'
if (*nodeIndex >= MBVH_NODES_PAGE_SIZE) {
<kernel>:1619:37: warning: initializing '__global BVHArrayNode *restrict __attribute__((address_space(16776963)))' with an expression of type 'const __global BVHArrayNode *restrict __attribute__((address_space(16776963)))' discards qualifiers
__global BVHArrayNode* restrict stopaccelNodePage = accelNodePages[currentPage];
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\base.py", line 82, in render_final
final.render(self, depsgraph)
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 49, in render
_render_layer(engine, depsgraph, statistics, layer)
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 73, in _render_layer
engine.session.Start()
RuntimeError: clBuildProgram
ERROR: clBuildProgram
[LuxRays][73.234] WARNING: there is a memory leak in LuxRays HardwareDevice GeForce GTX 1660 Ti Intersect: 3480866680bytes
Re: clBuildProgram
Posted: Fri Apr 10, 2020 10:41 pm
by arescet
guess i'll cut the whole thing to post here
Read prefs: C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\config\userpref.blend
found bundled python: D:\Program Files\Blender Foundation\Blender 2.82\2.82\python
Registered Carver
register
BlendLuxCore 2.4alpha0 registered (with pyluxcore 2.4alpha0)
Updating OpenCL device list
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
Read blend: D:\Users\user\Desktop\array.blend
[Engine/Final] Rendering layer "View Layer"
[Exporter] Creating session
[SDL][19.734] Camera type: perspective
[SDL][19.734] Camera position: Point[-0.307042, -0.0290527, 24]
[SDL][19.734] Camera target: Point[-0.307042, -0.0290527, 23]
[SDL][19.734] Camera clipping plane disabled
WARNING: No material defined
[SDL][47.500] Material definition: __CLAY__
[SDL][47.500] Scene objects count: 474
[SDL][47.500] Light definition: 2589291066088
[SDL][47.500] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][47.531] Configuration:
[LuxCore][47.531] path.pathdepth.total = 7
[LuxCore][47.531] path.pathdepth.diffuse = 7
[LuxCore][47.531] path.pathdepth.glossy = 7
[LuxCore][47.531] path.pathdepth.specular = 6
[LuxCore][47.531] path.hybridbackforward.enable = 0
[LuxCore][47.531] path.hybridbackforward.partition = 0
[LuxCore][47.531] path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][47.531] opencl.cpu.use = 0
[LuxCore][47.531] opencl.gpu.use = 1
[LuxCore][47.531] opencl.devices.select = "1"
[LuxCore][47.531] film.noiseestimation.warmup = 8
[LuxCore][47.547] film.noiseestimation.step = 32
[LuxCore][47.547] sampler.sobol.adaptive.strength = 0.89999997615814209
[LuxCore][47.547] sampler.random.adaptive.strength = 0.89999997615814209
[LuxCore][47.547] sampler.metropolis.largesteprate = 0.40000000000000002
[LuxCore][47.547] sampler.metropolis.maxconsecutivereject = 512
[LuxCore][47.547] sampler.metropolis.imagemutationrate = 0.10000000000000001
[LuxCore][47.547] renderengine.type = "PATHOCL"
[LuxCore][47.547] sampler.type = "SOBOL"
[LuxCore][47.562] film.width = 1920
[LuxCore][47.562] film.height = 1080
[LuxCore][47.562] film.filter.type = "NONE"
[LuxCore][47.562] film.filter.width = 1.5
[LuxCore][47.562] lightstrategy.type = "LOG_POWER"
[LuxCore][47.562] scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][47.562] scene.epsilon.max = 0.10000000149011612
[LuxCore][47.578] film.opencl.enable = 1
[LuxCore][47.578] film.opencl.device = 0
[LuxCore][47.578] path.forceblackbackground.enable = 0
[LuxCore][47.578] renderengine.seed = 1
[LuxCore][47.578] film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][47.578] film.outputs.0.index = 0
[LuxCore][47.578] film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][47.578] film.outputs.1.type = "ALBEDO"
[LuxCore][47.578] film.outputs.1.filename = "ALBEDO.exr"
[LuxCore][47.578] film.outputs.2.type = "AVG_SHADING_NORMAL"
[LuxCore][47.578] film.outputs.2.filename = "AVG_SHADING_NORMAL.exr"
[LuxCore][47.578] film.outputs.3.type = "RGB_IMAGEPIPELINE"
[LuxCore][47.578] film.outputs.3.index = 1
[LuxCore][47.578] film.outputs.3.filename = "RGB_IMAGEPIPELINE_1.png"
[LuxCore][47.578] film.outputs.4.type = "RGB_IMAGEPIPELINE"
[LuxCore][47.578] film.outputs.4.index = 2
[LuxCore][47.594] film.outputs.4.filename = "RGB_IMAGEPIPELINE_2.png"
[LuxCore][47.594] film.imagepipelines.1.0.type = "INTEL_OIDN"
[LuxCore][47.594] film.imagepipelines.1.0.oidnmemory = 6000
[LuxCore][47.594] film.imagepipelines.1.1.type = "NOP"
[LuxCore][47.594] film.imagepipelines.1.2.type = "TONEMAP_LINEAR"
[LuxCore][47.594] film.imagepipelines.1.2.scale = 1
[LuxCore][47.594] film.imagepipelines.1.radiancescales.0.enabled = 1
[LuxCore][47.594] film.imagepipelines.1.radiancescales.0.globalscale = 1
[LuxCore][47.594] film.imagepipelines.1.radiancescales.0.rgbscale = 1 1 1
[LuxCore][47.594] film.imagepipelines.2.0.type = "NOP"
[LuxCore][47.594] film.imagepipelines.2.1.type = "TONEMAP_LINEAR"
[LuxCore][47.594] film.imagepipelines.2.1.scale = 1
[LuxCore][47.594] film.imagepipelines.2.radiancescales.0.enabled = 1
[LuxCore][47.594] film.imagepipelines.2.radiancescales.0.globalscale = 1
[LuxCore][47.594] film.imagepipelines.2.radiancescales.0.rgbscale = 1 1 1
[LuxCore][47.594] film.imagepipelines.2.2.type = "GAMMA_CORRECTION"
[LuxCore][47.594] film.imagepipelines.2.2.value = 2.2000000000000002
[LuxCore][47.609] film.noiseestimation.index = 2
[LuxCore][47.609] film.imagepipelines.0.0.type = "NOP"
[LuxCore][47.609] film.imagepipelines.0.1.type = "TONEMAP_LINEAR"
[LuxCore][47.609] film.imagepipelines.0.1.scale = 1
[LuxCore][47.609] film.imagepipelines.0.radiancescales.0.enabled = 1
[LuxCore][47.609] film.imagepipelines.0.radiancescales.0.globalscale = 1
[LuxCore][47.609] film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
[LuxCore][47.609] batch.haltspp = 0
[LuxCore][47.609] batch.halttime = 0
[LuxCore][47.609] File Name Resolver Configuration:
Export took 27.9 s
[LuxCore][47.609] Film resolution: 1920x1080
[SDL][47.609] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][47.609] Image pipeline: film.imagepipelines.0
[SDL][47.625] Image pipeline step 0: NOP
[SDL][47.625] Image pipeline step 1: TONEMAP_LINEAR
[SDL][47.625] Image pipeline: film.imagepipelines.1
[SDL][47.625] Image pipeline step 0: INTEL_OIDN
[SDL][47.625] Image pipeline step 1: NOP
[SDL][47.625] Image pipeline step 2: TONEMAP_LINEAR
[SDL][47.625] Image pipeline: film.imagepipelines.2
[SDL][47.625] Image pipeline step 2: GAMMA_CORRECTION
[SDL][47.625] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[SDL][47.625] Film output definition: ALBEDO [ALBEDO.exr]
[SDL][47.625] Film output definition: AVG_SHADING_NORMAL [AVG_SHADING_NORMAL.exr]
[SDL][47.625] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_1.png]
[SDL][47.625] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_2.png]
[LuxRays][47.641] OpenCL Platform 0: NVIDIA Corporation
[LuxRays][47.641] Device 0 name: Native
[LuxRays][47.641] Device 0 type: NATIVE_THREAD
[LuxRays][47.656] Device 0 compute units: 1
[LuxRays][47.656] Device 0 preferred float vector width: 4
[LuxRays][47.656] Device 0 max allocable memory: 0MBytes
[LuxRays][47.656] Device 0 max allocable memory block size: 0MBytes
[LuxRays][47.656] Device 1 name: GeForce GTX 1660 Ti
[LuxRays][47.656] Device 1 type: OPENCL_GPU
[LuxRays][47.656] Device 1 compute units: 24
[LuxRays][47.656] Device 1 preferred float vector width: 1
[LuxRays][47.656] Device 1 max allocable memory: 6144MBytes
[LuxRays][47.656] Device 1 max allocable memory block size: 1536MBytes
[LuxRays][47.656] Creating 33 intersection device(s)
[LuxRays][47.656] Allocating intersection device 0: GeForce GTX 1660 Ti (Type = OPENCL_GPU)
[LuxRays][47.672] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 8: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 9: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 10: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 11: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 12: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 13: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 14: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 15: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 16: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 17: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 18: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 19: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 20: Native (Type = NATIVE_THREAD)
[LuxRays][47.672] Allocating intersection device 21: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 22: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 23: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 24: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 25: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 26: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 27: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 28: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 29: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 30: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 31: Native (Type = NATIVE_THREAD)
[LuxRays][47.687] Allocating intersection device 32: Native (Type = NATIVE_THREAD)
[LuxCore][47.687] OpenCL devices used:
[LuxCore][47.687] [GeForce GTX 1660 Ti Intersect]
[LuxCore][47.687] Device OpenCL version: OpenCL 1.2 CUDA
[LuxCore][47.687] Native devices used: 32
[LuxCore][47.687] Configuring 1 OpenCL render threads
[LuxCore][47.687] Configuring 32 native render threads
[LuxRays][47.687] Preprocessing DataSet
[LuxRays][47.687] Total vertex count: 37072199
[LuxRays][47.687] Total triangle count: 63751084
[LuxRays][47.734] Preprocessing DataSet done
[LuxRays][47.734] Adding DataSet accelerator: MBVH
[LuxRays][47.734] Total vertex count: 37072199
[LuxRays][47.734] Total triangle count: 63751084
[LuxRays][47.734] Building Multilevel Bounding Volume Hierarchy: 474 leafs
[LuxRays][47.750] BVH Dataset preprocessing time: 16ms
[LuxRays][47.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.750] BVH build hierarchy time: 0ms
[LuxRays][47.750] BVH total build time: 16ms
[LuxRays][47.750] Total BVH memory usage: 99Kbytes
[LuxRays][47.750] BVH Dataset preprocessing time: 0ms
[LuxRays][47.750] BVH total build time: 0ms
[LuxRays][47.750] Total BVH memory usage: 164Kbytes
[LuxRays][47.766] BVH build hierarchy time: 16ms
[LuxRays][47.766] BVH total build time: 16ms
[LuxRays][47.766] Total BVH memory usage: 1965Kbytes
[LuxRays][47.766] BVH Dataset preprocessing time: 0ms
[LuxRays][47.766] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.781] BVH build hierarchy time: 15ms
[LuxRays][47.781] BVH total build time: 15ms
[LuxRays][47.781] Total BVH memory usage: 1969Kbytes
[LuxRays][47.781] BVH Dataset preprocessing time: 0ms
[LuxRays][47.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.781] BVH build hierarchy time: 0ms
[LuxRays][47.781] BVH total build time: 0ms
[LuxRays][47.781] Total BVH memory usage: 1Kbytes
[LuxRays][47.797] BVH build hierarchy time: 15ms
[LuxRays][47.797] BVH total build time: 15ms
[LuxRays][47.797] Total BVH memory usage: 1Kbytes
[LuxRays][47.797] BVH Dataset preprocessing time: 0ms
[LuxRays][47.797] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.797] BVH build hierarchy time: 0ms
[LuxRays][47.797] BVH total build time: 0ms
[LuxRays][47.797] Total BVH memory usage: 17Kbytes
[LuxRays][47.797] Total BVH memory usage: 123Kbytes
[LuxRays][47.812] BVH build hierarchy time: 15ms
[LuxRays][47.812] BVH total build time: 15ms
[LuxRays][47.812] Total BVH memory usage: 1403Kbytes
[LuxRays][47.812] BVH Dataset preprocessing time: 0ms
[LuxRays][47.812] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.812] BVH build hierarchy time: 0ms
[LuxRays][47.812] BVH total build time: 0ms
[LuxRays][47.812] Total BVH memory usage: 15Kbytes
[LuxRays][47.812] Total BVH memory usage: 14Kbytes
[LuxRays][47.828] BVH Dataset preprocessing time: 16ms
[LuxRays][47.828] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.828] BVH build hierarchy time: 0ms
[LuxRays][47.828] BVH total build time: 16ms
[LuxRays][47.828] Total BVH memory usage: 109Kbytes
[LuxRays][47.828] BVH Dataset preprocessing time: 0ms
[LuxRays][47.828] BVH total build time: 0ms
[LuxRays][47.828] Total BVH memory usage: 139Kbytes
[LuxRays][47.844] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.844] BVH build hierarchy time: 0ms
[LuxRays][47.844] BVH total build time: 16ms
[LuxRays][47.844] Total BVH memory usage: 1Kbytes
[LuxRays][47.844] BVH Dataset preprocessing time: 0ms
[LuxRays][47.844] BVH total build time: 0ms
[LuxRays][47.844] Total BVH memory usage: 263Kbytes
[LuxRays][47.859] BVH build hierarchy time: 14ms
[LuxRays][47.859] BVH total build time: 14ms
[LuxRays][47.859] Total BVH memory usage: 89Kbytes
[LuxRays][47.859] BVH Dataset preprocessing time: 0ms
[LuxRays][47.859] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.875] BVH build hierarchy time: 16ms
[LuxRays][47.875] BVH total build time: 16ms
[LuxRays][47.875] Total BVH memory usage: 3487Kbytes
[LuxRays][47.891] BVH Dataset preprocessing time: 0ms
[LuxRays][47.891] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.891] BVH build hierarchy time: 0ms
[LuxRays][47.891] BVH total build time: 0ms
[LuxRays][47.891] Total BVH memory usage: 1089Kbytes
[LuxRays][47.906] BVH build hierarchy time: 15ms
[LuxRays][47.906] BVH total build time: 15ms
[LuxRays][47.906] Total BVH memory usage: 828Kbytes
[LuxRays][47.906] BVH Dataset preprocessing time: 0ms
[LuxRays][47.906] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.906] BVH build hierarchy time: 0ms
[LuxRays][47.906] BVH total build time: 0ms
[LuxRays][47.906] Total BVH memory usage: 391Kbytes
[LuxRays][47.906] Total BVH memory usage: 392Kbytes
[LuxRays][47.922] BVH build hierarchy time: 15ms
[LuxRays][47.922] BVH total build time: 15ms
[LuxRays][47.922] Total BVH memory usage: 392Kbytes
[LuxRays][47.922] BVH Dataset preprocessing time: 0ms
[LuxRays][47.922] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.922] BVH build hierarchy time: 0ms
[LuxRays][47.922] BVH total build time: 0ms
[LuxRays][47.937] BVH build hierarchy time: 15ms
[LuxRays][47.937] BVH total build time: 15ms
[LuxRays][47.937] Total BVH memory usage: 2217Kbytes
[LuxRays][47.937] BVH Dataset preprocessing time: 0ms
[LuxRays][47.937] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.953] BVH build hierarchy time: 16ms
[LuxRays][47.953] BVH total build time: 16ms
[LuxRays][47.953] Total BVH memory usage: 2227Kbytes
[LuxRays][47.969] BVH Dataset preprocessing time: 0ms
[LuxRays][47.969] BVH builder: EMBREE_BINNED_SAH
[LuxRays][47.984] BVH build hierarchy time: 14ms
[LuxRays][47.984] BVH total build time: 14ms
[LuxRays][47.984] Total BVH memory usage: 2220Kbytes
[LuxRays][47.984] BVH Dataset preprocessing time: 0ms
[LuxRays][47.984] BVH builder: EMBREE_BINNED_SAH
[LuxRays][48.000] BVH build hierarchy time: 16ms
[LuxRays][48.000] BVH total build time: 16ms
[LuxRays][48.000] Total BVH memory usage: 2222Kbytes
[LuxRays][48.016] BVH Dataset preprocessing time: 16ms
[LuxRays][48.016] BVH builder: EMBREE_BINNED_SAH
[LuxRays][48.094] BVH build hierarchy time: 78ms
[LuxRays][48.094] BVH total build time: 94ms
[LuxRays][48.094] Total BVH memory usage: 16258Kbytes
[LuxRays][48.109] BVH Dataset preprocessing time: 0ms
[LuxRays][48.109] BVH builder: EMBREE_BINNED_SAH
[LuxRays][48.109] BVH build hierarchy time: 0ms
[LuxRays][48.109] BVH total build time: 0ms
[LuxRays][48.109] Total BVH memory usage: 164Kbytes
[LuxRays][48.156] BVH Dataset preprocessing time: 47ms
[LuxRays][48.156] BVH builder: EMBREE_BINNED_SAH
[LuxRays][48.500] BVH build hierarchy time: 343ms
[LuxRays][48.500] BVH total build time: 391ms
[LuxRays][48.500] Total BVH memory usage: 71244Kbytes
[LuxRays][48.578] BVH Dataset preprocessing time: 62ms
[LuxRays][48.578] BVH builder: EMBREE_BINNED_SAH
[LuxRays][48.969] BVH build hierarchy time: 391ms
[LuxRays][48.969] BVH total build time: 453ms
[LuxRays][48.969] Total BVH memory usage: 81286Kbytes
[LuxRays][49.062] BVH Dataset preprocessing time: 78ms
[LuxRays][49.062] BVH builder: EMBREE_BINNED_SAH
[LuxRays][49.578] BVH build hierarchy time: 516ms
[LuxRays][49.578] BVH total build time: 594ms
[LuxRays][49.578] Total BVH memory usage: 108720Kbytes
[LuxRays][49.703] BVH Dataset preprocessing time: 108ms
[LuxRays][49.703] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.391] BVH build hierarchy time: 687ms
[LuxRays][50.391] BVH total build time: 796ms
[LuxRays][50.391] Total BVH memory usage: 142196Kbytes
[LuxRays][50.406] Building BVH for MBVH leaf: 45/474
[LuxRays][50.406] BVH Dataset preprocessing time: 0ms
[LuxRays][50.406] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.422] BVH build hierarchy time: 15ms
[LuxRays][50.422] BVH total build time: 15ms
[LuxRays][50.422] Total BVH memory usage: 765Kbytes
[LuxRays][50.422] BVH Dataset preprocessing time: 0ms
[LuxRays][50.422] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.422] BVH build hierarchy time: 0ms
[LuxRays][50.422] BVH total build time: 0ms
[LuxRays][50.422] Total BVH memory usage: 766Kbytes
[LuxRays][50.437] BVH build hierarchy time: 15ms
[LuxRays][50.437] BVH total build time: 15ms
[LuxRays][50.437] Total BVH memory usage: 766Kbytes
[LuxRays][50.437] BVH Dataset preprocessing time: 0ms
[LuxRays][50.437] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.437] BVH build hierarchy time: 0ms
[LuxRays][50.437] BVH total build time: 0ms
[LuxRays][50.437] Total BVH memory usage: 765Kbytes
[LuxRays][50.453] BVH Dataset preprocessing time: 16ms
[LuxRays][50.453] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.500] BVH build hierarchy time: 46ms
[LuxRays][50.500] BVH total build time: 62ms
[LuxRays][50.500] Total BVH memory usage: 11272Kbytes
[LuxRays][50.516] BVH Dataset preprocessing time: 0ms
[LuxRays][50.516] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.547] BVH build hierarchy time: 30ms
[LuxRays][50.547] BVH total build time: 30ms
[LuxRays][50.547] Total BVH memory usage: 5835Kbytes
[LuxRays][50.562] BVH Dataset preprocessing time: 15ms
[LuxRays][50.562] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.594] BVH build hierarchy time: 32ms
[LuxRays][50.594] BVH total build time: 47ms
[LuxRays][50.594] Total BVH memory usage: 5940Kbytes
[LuxRays][50.594] BVH Dataset preprocessing time: 0ms
[LuxRays][50.594] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.625] BVH build hierarchy time: 30ms
[LuxRays][50.625] BVH total build time: 30ms
[LuxRays][50.625] Total BVH memory usage: 5922Kbytes
[LuxRays][50.625] BVH Dataset preprocessing time: 0ms
[LuxRays][50.625] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.656] BVH build hierarchy time: 31ms
[LuxRays][50.656] BVH total build time: 31ms
[LuxRays][50.656] Total BVH memory usage: 5832Kbytes
[LuxRays][50.672] BVH Dataset preprocessing time: 0ms
[LuxRays][50.672] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.687] BVH build hierarchy time: 15ms
[LuxRays][50.687] BVH total build time: 15ms
[LuxRays][50.687] Total BVH memory usage: 2618Kbytes
[LuxRays][50.687] BVH Dataset preprocessing time: 0ms
[LuxRays][50.687] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.703] BVH build hierarchy time: 16ms
[LuxRays][50.703] BVH total build time: 16ms
[LuxRays][50.703] Total BVH memory usage: 2628Kbytes
[LuxRays][50.734] BVH Dataset preprocessing time: 30ms
[LuxRays][50.734] BVH builder: EMBREE_BINNED_SAH
[LuxRays][50.984] BVH build hierarchy time: 250ms
[LuxRays][50.984] BVH total build time: 280ms
[LuxRays][50.984] Total BVH memory usage: 46468Kbytes
[LuxRays][50.984] BVH Dataset preprocessing time: 0ms
[LuxRays][50.984] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.016] BVH build hierarchy time: 32ms
[LuxRays][51.016] BVH total build time: 32ms
[LuxRays][51.016] Total BVH memory usage: 4846Kbytes
[LuxRays][51.016] BVH Dataset preprocessing time: 0ms
[LuxRays][51.016] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.031] BVH build hierarchy time: 15ms
[LuxRays][51.031] BVH total build time: 15ms
[LuxRays][51.031] Total BVH memory usage: 101Kbytes
[LuxRays][51.031] BVH Dataset preprocessing time: 0ms
[LuxRays][51.031] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.031] BVH build hierarchy time: 0ms
[LuxRays][51.031] BVH total build time: 0ms
[LuxRays][51.047] BVH build hierarchy time: 15ms
[LuxRays][51.047] BVH total build time: 15ms
[LuxRays][51.047] Total BVH memory usage: 101Kbytes
[LuxRays][51.047] BVH Dataset preprocessing time: 0ms
[LuxRays][51.047] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.047] BVH build hierarchy time: 0ms
[LuxRays][51.047] BVH total build time: 0ms
[LuxRays][51.062] Total BVH memory usage: 100Kbytes
[LuxRays][51.062] BVH Dataset preprocessing time: 0ms
[LuxRays][51.062] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.062] BVH build hierarchy time: 0ms
[LuxRays][51.062] BVH total build time: 0ms
[LuxRays][51.062] Total BVH memory usage: 101Kbytes
[LuxRays][51.141] BVH build hierarchy time: 78ms
[LuxRays][51.141] BVH total build time: 78ms
[LuxRays][51.141] Total BVH memory usage: 12670Kbytes
[LuxRays][51.141] BVH Dataset preprocessing time: 0ms
[LuxRays][51.141] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.141] BVH build hierarchy time: 0ms
[LuxRays][51.141] BVH total build time: 0ms
[LuxRays][51.141] Total BVH memory usage: 74Kbytes
[LuxRays][51.156] BVH Dataset preprocessing time: 15ms
[LuxRays][51.156] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.219] BVH build hierarchy time: 62ms
[LuxRays][51.219] BVH total build time: 78ms
[LuxRays][51.219] Total BVH memory usage: 12670Kbytes
[LuxRays][51.234] BVH Dataset preprocessing time: 14ms
[LuxRays][51.234] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.297] BVH build hierarchy time: 62ms
[LuxRays][51.297] BVH total build time: 77ms
[LuxRays][51.297] Total BVH memory usage: 12670Kbytes
[LuxRays][51.312] BVH Dataset preprocessing time: 15ms
[LuxRays][51.312] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.375] BVH build hierarchy time: 62ms
[LuxRays][51.375] BVH total build time: 78ms
[LuxRays][51.375] Total BVH memory usage: 12670Kbytes
[LuxRays][51.391] BVH Dataset preprocessing time: 16ms
[LuxRays][51.391] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.391] BVH build hierarchy time: 0ms
[LuxRays][51.391] BVH total build time: 16ms
[LuxRays][51.391] Total BVH memory usage: 101Kbytes
[LuxRays][51.391] BVH Dataset preprocessing time: 0ms
[LuxRays][51.391] BVH total build time: 0ms
[LuxRays][51.406] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.406] BVH build hierarchy time: 0ms
[LuxRays][51.406] BVH total build time: 15ms
[LuxRays][51.406] Total BVH memory usage: 101Kbytes
[LuxRays][51.406] BVH Dataset preprocessing time: 0ms
[LuxRays][51.406] BVH total build time: 0ms
[LuxRays][51.422] BVH Dataset preprocessing time: 0ms
[LuxRays][51.422] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.422] BVH build hierarchy time: 0ms
[LuxRays][51.422] BVH total build time: 0ms
[LuxRays][51.422] Total BVH memory usage: 100Kbytes
[LuxRays][51.422] Total BVH memory usage: 101Kbytes
[LuxRays][51.437] Total BVH memory usage: 101Kbytes
[LuxRays][51.437] BVH Dataset preprocessing time: 0ms
[LuxRays][51.437] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.437] BVH build hierarchy time: 0ms
[LuxRays][51.437] BVH total build time: 0ms
[LuxRays][51.437] Total BVH memory usage: 115Kbytes
[LuxRays][51.453] Total BVH memory usage: 101Kbytes
[LuxRays][51.453] BVH Dataset preprocessing time: 0ms
[LuxRays][51.453] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.469] BVH build hierarchy time: 16ms
[LuxRays][51.469] BVH total build time: 16ms
[LuxRays][51.469] Total BVH memory usage: 4258Kbytes
[LuxRays][51.469] BVH Dataset preprocessing time: 0ms
[LuxRays][51.469] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.484] BVH build hierarchy time: 14ms
[LuxRays][51.484] BVH total build time: 14ms
[LuxRays][51.484] Total BVH memory usage: 97Kbytes
[LuxRays][51.484] BVH Dataset preprocessing time: 0ms
[LuxRays][51.484] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.484] BVH build hierarchy time: 0ms
[LuxRays][51.484] BVH total build time: 0ms
[LuxRays][51.484] Total BVH memory usage: 167Kbytes
[LuxRays][51.500] BVH build hierarchy time: 16ms
[LuxRays][51.500] BVH total build time: 16ms
[LuxRays][51.500] Total BVH memory usage: 1996Kbytes
[LuxRays][51.500] BVH Dataset preprocessing time: 0ms
[LuxRays][51.500] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.516] BVH build hierarchy time: 16ms
[LuxRays][51.516] BVH total build time: 16ms
[LuxRays][51.516] Total BVH memory usage: 1999Kbytes
[LuxRays][51.516] BVH Dataset preprocessing time: 0ms
[LuxRays][51.516] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.516] BVH build hierarchy time: 0ms
[LuxRays][51.516] BVH total build time: 0ms
[LuxRays][51.516] Total BVH memory usage: 1Kbytes
[LuxRays][51.516] Total BVH memory usage: 17Kbytes
[LuxRays][51.531] BVH Dataset preprocessing time: 0ms
[LuxRays][51.531] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.531] BVH build hierarchy time: 0ms
[LuxRays][51.531] BVH total build time: 0ms
[LuxRays][51.531] Total BVH memory usage: 123Kbytes
[LuxRays][51.531] Total BVH memory usage: 1401Kbytes
[LuxRays][51.547] BVH build hierarchy time: 15ms
[LuxRays][51.547] BVH total build time: 15ms
[LuxRays][51.547] Total BVH memory usage: 14Kbytes
[LuxRays][51.547] BVH Dataset preprocessing time: 0ms
[LuxRays][51.547] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.547] BVH build hierarchy time: 0ms
[LuxRays][51.547] BVH total build time: 0ms
[LuxRays][51.547] Total BVH memory usage: 110Kbytes
[LuxRays][51.547] Total BVH memory usage: 139Kbytes
[LuxRays][51.562] BVH build hierarchy time: 15ms
[LuxRays][51.562] BVH total build time: 15ms
[LuxRays][51.562] Total BVH memory usage: 251Kbytes
[LuxRays][51.562] BVH Dataset preprocessing time: 0ms
[LuxRays][51.562] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.562] BVH build hierarchy time: 0ms
[LuxRays][51.562] BVH total build time: 0ms
[LuxRays][51.562] Total BVH memory usage: 92Kbytes
[LuxRays][51.578] BVH build hierarchy time: 16ms
[LuxRays][51.578] BVH total build time: 16ms
[LuxRays][51.578] Total BVH memory usage: 3478Kbytes
[LuxRays][51.594] BVH Dataset preprocessing time: 0ms
[LuxRays][51.594] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.594] BVH build hierarchy time: 0ms
[LuxRays][51.594] BVH total build time: 0ms
[LuxRays][51.594] Total BVH memory usage: 1077Kbytes
[LuxRays][51.594] Total BVH memory usage: 390Kbytes
[LuxRays][51.609] BVH build hierarchy time: 14ms
[LuxRays][51.609] BVH total build time: 14ms
[LuxRays][51.609] Total BVH memory usage: 389Kbytes
[LuxRays][51.609] BVH Dataset preprocessing time: 0ms
[LuxRays][51.609] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.609] BVH build hierarchy time: 0ms
[LuxRays][51.609] BVH total build time: 0ms
[LuxRays][51.609] Total BVH memory usage: 390Kbytes
[LuxRays][51.625] BVH Dataset preprocessing time: 0ms
[LuxRays][51.625] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.641] BVH build hierarchy time: 16ms
[LuxRays][51.641] BVH total build time: 16ms
[LuxRays][51.641] Total BVH memory usage: 2210Kbytes
[LuxRays][51.641] BVH Dataset preprocessing time: 0ms
[LuxRays][51.641] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.656] BVH build hierarchy time: 15ms
[LuxRays][51.656] BVH total build time: 15ms
[LuxRays][51.656] Total BVH memory usage: 2218Kbytes
[LuxRays][51.656] BVH Dataset preprocessing time: 0ms
[LuxRays][51.656] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.672] BVH build hierarchy time: 15ms
[LuxRays][51.672] BVH total build time: 15ms
[LuxRays][51.672] Total BVH memory usage: 2216Kbytes
[LuxRays][51.672] BVH Dataset preprocessing time: 0ms
[LuxRays][51.672] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.687] BVH build hierarchy time: 15ms
[LuxRays][51.687] BVH total build time: 15ms
[LuxRays][51.687] Total BVH memory usage: 2213Kbytes
[LuxRays][51.687] BVH Dataset preprocessing time: 0ms
[LuxRays][51.687] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.781] BVH build hierarchy time: 94ms
[LuxRays][51.781] BVH total build time: 94ms
[LuxRays][51.781] Total BVH memory usage: 16218Kbytes
[LuxRays][51.781] BVH Dataset preprocessing time: 0ms
[LuxRays][51.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][51.797] BVH build hierarchy time: 15ms
[LuxRays][51.797] BVH total build time: 15ms
[LuxRays][51.797] Total BVH memory usage: 165Kbytes
[LuxRays][51.844] BVH Dataset preprocessing time: 47ms
[LuxRays][51.844] BVH builder: EMBREE_BINNED_SAH
[LuxRays][52.203] BVH build hierarchy time: 358ms
[LuxRays][52.203] BVH total build time: 406ms
[LuxRays][52.203] Total BVH memory usage: 71322Kbytes
[LuxRays][52.266] BVH Dataset preprocessing time: 46ms
[LuxRays][52.266] BVH builder: EMBREE_BINNED_SAH
[LuxRays][52.672] BVH build hierarchy time: 405ms
[LuxRays][52.672] BVH total build time: 452ms
[LuxRays][52.672] Total BVH memory usage: 81076Kbytes
[LuxRays][52.672] Building BVH for MBVH leaf: 136/474
[LuxRays][52.750] BVH Dataset preprocessing time: 78ms
[LuxRays][52.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][53.281] BVH build hierarchy time: 531ms
[LuxRays][53.281] BVH total build time: 609ms
[LuxRays][53.281] Total BVH memory usage: 108580Kbytes
[LuxRays][53.391] BVH Dataset preprocessing time: 94ms
[LuxRays][53.391] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.078] BVH build hierarchy time: 687ms
[LuxRays][54.078] BVH total build time: 781ms
[LuxRays][54.078] Total BVH memory usage: 142308Kbytes
[LuxRays][54.094] BVH Dataset preprocessing time: 0ms
[LuxRays][54.094] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.094] BVH build hierarchy time: 0ms
[LuxRays][54.094] BVH total build time: 0ms
[LuxRays][54.094] Total BVH memory usage: 766Kbytes
[LuxRays][54.109] BVH Dataset preprocessing time: 14ms
[LuxRays][54.109] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.109] BVH build hierarchy time: 0ms
[LuxRays][54.109] BVH total build time: 14ms
[LuxRays][54.109] Total BVH memory usage: 766Kbytes
[LuxRays][54.109] BVH Dataset preprocessing time: 0ms
[LuxRays][54.109] BVH total build time: 0ms
[LuxRays][54.109] Total BVH memory usage: 763Kbytes
[LuxRays][54.125] BVH build hierarchy time: 16ms
[LuxRays][54.125] BVH total build time: 16ms
[LuxRays][54.125] Total BVH memory usage: 767Kbytes
[LuxRays][54.125] BVH Dataset preprocessing time: 0ms
[LuxRays][54.125] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.187] BVH build hierarchy time: 62ms
[LuxRays][54.187] BVH total build time: 62ms
[LuxRays][54.187] Total BVH memory usage: 11240Kbytes
[LuxRays][54.203] BVH Dataset preprocessing time: 16ms
[LuxRays][54.203] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.234] BVH build hierarchy time: 30ms
[LuxRays][54.234] BVH total build time: 46ms
[LuxRays][54.234] Total BVH memory usage: 5818Kbytes
[LuxRays][54.234] BVH Dataset preprocessing time: 0ms
[LuxRays][54.234] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.266] BVH build hierarchy time: 32ms
[LuxRays][54.266] BVH total build time: 32ms
[LuxRays][54.266] Total BVH memory usage: 5948Kbytes
[LuxRays][54.266] BVH Dataset preprocessing time: 0ms
[LuxRays][54.266] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.297] BVH build hierarchy time: 30ms
[LuxRays][54.297] BVH total build time: 30ms
[LuxRays][54.312] Total BVH memory usage: 5913Kbytes
[LuxRays][54.312] BVH Dataset preprocessing time: 0ms
[LuxRays][54.312] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.344] BVH build hierarchy time: 32ms
[LuxRays][54.344] BVH total build time: 32ms
[LuxRays][54.344] Total BVH memory usage: 5813Kbytes
[LuxRays][54.344] BVH Dataset preprocessing time: 0ms
[LuxRays][54.344] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.359] BVH build hierarchy time: 14ms
[LuxRays][54.359] BVH total build time: 14ms
[LuxRays][54.359] Total BVH memory usage: 2635Kbytes
[LuxRays][54.359] BVH Dataset preprocessing time: 0ms
[LuxRays][54.359] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.375] BVH build hierarchy time: 16ms
[LuxRays][54.375] BVH total build time: 16ms
[LuxRays][54.375] Total BVH memory usage: 2628Kbytes
[LuxRays][54.406] BVH Dataset preprocessing time: 31ms
[LuxRays][54.406] BVH builder: EMBREE_BINNED_SAH
Re: clBuildProgram
Posted: Fri Apr 10, 2020 10:44 pm
by arescet
[LuxRays][54.672] BVH build hierarchy time: 265ms
[LuxRays][54.672] BVH total build time: 296ms
[LuxRays][54.672] Total BVH memory usage: 46419Kbytes
[LuxRays][54.687] Building BVH for MBVH leaf: 150/474
[LuxRays][54.687] BVH Dataset preprocessing time: 0ms
[LuxRays][54.687] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.703] BVH build hierarchy time: 16ms
[LuxRays][54.703] BVH total build time: 16ms
[LuxRays][54.719] Total BVH memory usage: 4818Kbytes
[LuxRays][54.719] BVH Dataset preprocessing time: 0ms
[LuxRays][54.719] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.719] BVH build hierarchy time: 0ms
[LuxRays][54.719] BVH total build time: 0ms
[LuxRays][54.719] Total BVH memory usage: 101Kbytes
[LuxRays][54.734] BVH total build time: 14ms
[LuxRays][54.734] Total BVH memory usage: 100Kbytes
[LuxRays][54.734] BVH Dataset preprocessing time: 0ms
[LuxRays][54.734] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.734] BVH build hierarchy time: 0ms
[LuxRays][54.734] BVH total build time: 0ms
[LuxRays][54.734] Total BVH memory usage: 101Kbytes
[LuxRays][54.750] BVH Dataset preprocessing time: 0ms
[LuxRays][54.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.750] BVH build hierarchy time: 0ms
[LuxRays][54.750] BVH total build time: 0ms
[LuxRays][54.750] Total BVH memory usage: 100Kbytes
[LuxRays][54.828] BVH build hierarchy time: 78ms
[LuxRays][54.828] BVH total build time: 78ms
[LuxRays][54.828] Total BVH memory usage: 12656Kbytes
[LuxRays][54.828] BVH Dataset preprocessing time: 0ms
[LuxRays][54.828] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.906] BVH build hierarchy time: 78ms
[LuxRays][54.906] BVH total build time: 78ms
[LuxRays][54.906] Total BVH memory usage: 12657Kbytes
[LuxRays][54.922] BVH Dataset preprocessing time: 15ms
[LuxRays][54.922] BVH builder: EMBREE_BINNED_SAH
[LuxRays][54.984] BVH build hierarchy time: 62ms
[LuxRays][54.984] BVH total build time: 77ms
[LuxRays][54.984] Total BVH memory usage: 12656Kbytes
[LuxRays][55.000] BVH Dataset preprocessing time: 16ms
[LuxRays][55.000] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.062] BVH build hierarchy time: 62ms
[LuxRays][55.062] BVH total build time: 78ms
[LuxRays][55.062] Total BVH memory usage: 12657Kbytes
[LuxRays][55.062] BVH Dataset preprocessing time: 0ms
[LuxRays][55.062] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.062] BVH build hierarchy time: 0ms
[LuxRays][55.062] BVH total build time: 0ms
[LuxRays][55.062] Total BVH memory usage: 101Kbytes
[LuxRays][55.078] BVH Dataset preprocessing time: 0ms
[LuxRays][55.078] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.078] BVH build hierarchy time: 0ms
[LuxRays][55.078] BVH total build time: 0ms
[LuxRays][55.078] Total BVH memory usage: 101Kbytes
[LuxRays][55.078] Total BVH memory usage: 100Kbytes
[LuxRays][55.094] BVH total build time: 16ms
[LuxRays][55.094] Total BVH memory usage: 101Kbytes
[LuxRays][55.094] BVH Dataset preprocessing time: 0ms
[LuxRays][55.094] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.094] BVH build hierarchy time: 0ms
[LuxRays][55.094] BVH total build time: 0ms
[LuxRays][55.109] BVH Dataset preprocessing time: 0ms
[LuxRays][55.109] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.109] BVH build hierarchy time: 0ms
[LuxRays][55.109] BVH total build time: 0ms
[LuxRays][55.109] Total BVH memory usage: 101Kbytes
[LuxRays][55.109] Total BVH memory usage: 100Kbytes
[LuxRays][55.125] BVH Dataset preprocessing time: 0ms
[LuxRays][55.125] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.125] BVH build hierarchy time: 0ms
[LuxRays][55.125] BVH total build time: 0ms
[LuxRays][55.125] Total BVH memory usage: 101Kbytes
[LuxRays][55.156] BVH build hierarchy time: 31ms
[LuxRays][55.156] BVH total build time: 31ms
[LuxRays][55.156] Total BVH memory usage: 4248Kbytes
[LuxRays][55.156] BVH Dataset preprocessing time: 0ms
[LuxRays][55.156] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.156] BVH build hierarchy time: 0ms
[LuxRays][55.156] BVH total build time: 0ms
[LuxRays][55.156] Total BVH memory usage: 98Kbytes
[LuxRays][55.172] BVH build hierarchy time: 15ms
[LuxRays][55.172] BVH total build time: 15ms
[LuxRays][55.172] Total BVH memory usage: 164Kbytes
[LuxRays][55.172] BVH Dataset preprocessing time: 0ms
[LuxRays][55.172] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.187] BVH build hierarchy time: 15ms
[LuxRays][55.187] BVH total build time: 15ms
[LuxRays][55.187] Total BVH memory usage: 1961Kbytes
[LuxRays][55.187] BVH Dataset preprocessing time: 0ms
[LuxRays][55.187] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.187] BVH build hierarchy time: 0ms
[LuxRays][55.187] BVH total build time: 0ms
[LuxRays][55.187] Total BVH memory usage: 1964Kbytes
[LuxRays][55.203] BVH build hierarchy time: 16ms
[LuxRays][55.203] BVH total build time: 16ms
[LuxRays][55.203] Total BVH memory usage: 1Kbytes
[LuxRays][55.203] BVH Dataset preprocessing time: 0ms
[LuxRays][55.203] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.203] BVH build hierarchy time: 0ms
[LuxRays][55.203] BVH total build time: 0ms
[LuxRays][55.203] Total BVH memory usage: 17Kbytes
[LuxRays][55.203] Total BVH memory usage: 123Kbytes
[LuxRays][55.219] BVH build hierarchy time: 16ms
[LuxRays][55.219] BVH total build time: 16ms
[LuxRays][55.219] Total BVH memory usage: 1404Kbytes
[LuxRays][55.219] BVH Dataset preprocessing time: 0ms
[LuxRays][55.219] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.219] BVH build hierarchy time: 0ms
[LuxRays][55.219] BVH total build time: 0ms
[LuxRays][55.219] Total BVH memory usage: 15Kbytes
[LuxRays][55.219] Total BVH memory usage: 14Kbytes
[LuxRays][55.234] BVH Dataset preprocessing time: 0ms
[LuxRays][55.234] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.234] BVH build hierarchy time: 0ms
[LuxRays][55.234] BVH total build time: 0ms
[LuxRays][55.234] Total BVH memory usage: 109Kbytes
[LuxRays][55.234] Total BVH memory usage: 139Kbytes
[LuxRays][55.234] Total BVH memory usage: 261Kbytes
[LuxRays][55.250] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.250] BVH build hierarchy time: 0ms
[LuxRays][55.250] BVH total build time: 16ms
[LuxRays][55.250] Total BVH memory usage: 89Kbytes
[LuxRays][55.250] BVH Dataset preprocessing time: 0ms
[LuxRays][55.266] BVH build hierarchy time: 16ms
[LuxRays][55.266] BVH total build time: 16ms
[LuxRays][55.266] Total BVH memory usage: 3494Kbytes
[LuxRays][55.266] BVH Dataset preprocessing time: 0ms
[LuxRays][55.266] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.281] BVH build hierarchy time: 15ms
[LuxRays][55.281] BVH total build time: 15ms
[LuxRays][55.281] Total BVH memory usage: 1087Kbytes
[LuxRays][55.281] BVH Dataset preprocessing time: 0ms
[LuxRays][55.281] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.281] BVH build hierarchy time: 0ms
[LuxRays][55.281] BVH total build time: 0ms
[LuxRays][55.281] Total BVH memory usage: 392Kbytes
[LuxRays][55.281] Total BVH memory usage: 393Kbytes
[LuxRays][55.297] BVH Dataset preprocessing time: 0ms
[LuxRays][55.297] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.297] BVH build hierarchy time: 0ms
[LuxRays][55.297] BVH total build time: 0ms
[LuxRays][55.297] Total BVH memory usage: 392Kbytes
[LuxRays][55.312] BVH build hierarchy time: 15ms
[LuxRays][55.312] BVH total build time: 15ms
[LuxRays][55.312] Total BVH memory usage: 2218Kbytes
[LuxRays][55.312] BVH Dataset preprocessing time: 0ms
[LuxRays][55.312] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.328] BVH build hierarchy time: 16ms
[LuxRays][55.328] BVH total build time: 16ms
[LuxRays][55.328] Total BVH memory usage: 2226Kbytes
[LuxRays][55.328] BVH Dataset preprocessing time: 0ms
[LuxRays][55.328] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.344] BVH build hierarchy time: 16ms
[LuxRays][55.344] BVH total build time: 16ms
[LuxRays][55.344] Total BVH memory usage: 2224Kbytes
[LuxRays][55.344] BVH Dataset preprocessing time: 0ms
[LuxRays][55.344] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.359] BVH build hierarchy time: 14ms
[LuxRays][55.359] BVH total build time: 14ms
[LuxRays][55.359] Total BVH memory usage: 2221Kbytes
[LuxRays][55.375] BVH Dataset preprocessing time: 16ms
[LuxRays][55.375] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.453] BVH build hierarchy time: 78ms
[LuxRays][55.453] BVH total build time: 94ms
[LuxRays][55.453] Total BVH memory usage: 16252Kbytes
[LuxRays][55.453] BVH Dataset preprocessing time: 0ms
[LuxRays][55.453] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.469] BVH build hierarchy time: 16ms
[LuxRays][55.469] BVH total build time: 16ms
[LuxRays][55.469] Total BVH memory usage: 164Kbytes
[LuxRays][55.500] BVH Dataset preprocessing time: 30ms
[LuxRays][55.500] BVH builder: EMBREE_BINNED_SAH
[LuxRays][55.859] BVH build hierarchy time: 358ms
[LuxRays][55.859] BVH total build time: 389ms
[LuxRays][55.859] Total BVH memory usage: 71216Kbytes
[LuxRays][55.922] BVH Dataset preprocessing time: 46ms
[LuxRays][55.922] BVH builder: EMBREE_BINNED_SAH
[LuxRays][56.328] BVH build hierarchy time: 406ms
[LuxRays][56.328] BVH total build time: 453ms
[LuxRays][56.344] Total BVH memory usage: 81300Kbytes
[LuxRays][56.422] BVH Dataset preprocessing time: 77ms
[LuxRays][56.422] BVH builder: EMBREE_BINNED_SAH
[LuxRays][56.969] BVH build hierarchy time: 547ms
[LuxRays][56.969] BVH total build time: 625ms
[LuxRays][56.969] Total BVH memory usage: 108707Kbytes
[LuxRays][56.984] Building BVH for MBVH leaf: 230/474
[LuxRays][57.078] BVH Dataset preprocessing time: 94ms
[LuxRays][57.078] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.766] BVH build hierarchy time: 687ms
[LuxRays][57.766] BVH total build time: 782ms
[LuxRays][57.766] Total BVH memory usage: 142280Kbytes
[LuxRays][57.781] BVH Dataset preprocessing time: 0ms
[LuxRays][57.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.781] BVH build hierarchy time: 0ms
[LuxRays][57.781] BVH total build time: 0ms
[LuxRays][57.781] Total BVH memory usage: 766Kbytes
[LuxRays][57.797] BVH build hierarchy time: 15ms
[LuxRays][57.797] BVH total build time: 15ms
[LuxRays][57.797] Total BVH memory usage: 765Kbytes
[LuxRays][57.797] BVH Dataset preprocessing time: 0ms
[LuxRays][57.797] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.797] BVH build hierarchy time: 0ms
[LuxRays][57.797] BVH total build time: 0ms
[LuxRays][57.797] Total BVH memory usage: 764Kbytes
[LuxRays][57.797] Total BVH memory usage: 767Kbytes
[LuxRays][57.812] BVH Dataset preprocessing time: 15ms
[LuxRays][57.812] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.875] BVH build hierarchy time: 62ms
[LuxRays][57.875] BVH total build time: 78ms
[LuxRays][57.875] Total BVH memory usage: 11264Kbytes
[LuxRays][57.875] BVH Dataset preprocessing time: 0ms
[LuxRays][57.875] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.906] BVH build hierarchy time: 31ms
[LuxRays][57.906] BVH total build time: 31ms
[LuxRays][57.906] Total BVH memory usage: 5831Kbytes
[LuxRays][57.906] BVH Dataset preprocessing time: 0ms
[LuxRays][57.906] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.937] BVH build hierarchy time: 30ms
[LuxRays][57.937] BVH total build time: 30ms
[LuxRays][57.937] Total BVH memory usage: 5938Kbytes
[LuxRays][57.953] BVH Dataset preprocessing time: 0ms
[LuxRays][57.953] BVH builder: EMBREE_BINNED_SAH
[LuxRays][57.984] BVH build hierarchy time: 30ms
[LuxRays][57.984] BVH total build time: 30ms
[LuxRays][57.984] Total BVH memory usage: 5920Kbytes
[LuxRays][57.984] BVH Dataset preprocessing time: 0ms
[LuxRays][57.984] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.016] BVH build hierarchy time: 32ms
[LuxRays][58.016] BVH total build time: 32ms
[LuxRays][58.016] Total BVH memory usage: 5840Kbytes
[LuxRays][58.016] BVH Dataset preprocessing time: 0ms
[LuxRays][58.016] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.047] BVH build hierarchy time: 30ms
[LuxRays][58.047] BVH total build time: 30ms
[LuxRays][58.047] Total BVH memory usage: 2619Kbytes
[LuxRays][58.047] BVH Dataset preprocessing time: 0ms
[LuxRays][58.047] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.062] BVH build hierarchy time: 15ms
[LuxRays][58.062] BVH total build time: 15ms
[LuxRays][58.062] Total BVH memory usage: 2628Kbytes
[LuxRays][58.094] BVH Dataset preprocessing time: 32ms
[LuxRays][58.094] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.328] BVH build hierarchy time: 233ms
[LuxRays][58.328] BVH total build time: 266ms
[LuxRays][58.344] Total BVH memory usage: 46480Kbytes
[LuxRays][58.344] BVH Dataset preprocessing time: 0ms
[LuxRays][58.344] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.375] BVH build hierarchy time: 30ms
[LuxRays][58.375] BVH total build time: 30ms
[LuxRays][58.375] Total BVH memory usage: 4849Kbytes
[LuxRays][58.375] BVH Dataset preprocessing time: 0ms
[LuxRays][58.375] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.375] BVH build hierarchy time: 0ms
[LuxRays][58.375] BVH total build time: 0ms
[LuxRays][58.375] Total BVH memory usage: 101Kbytes
[LuxRays][58.391] BVH build hierarchy time: 16ms
[LuxRays][58.391] BVH total build time: 16ms
[LuxRays][58.391] Total BVH memory usage: 101Kbytes
[LuxRays][58.391] BVH Dataset preprocessing time: 0ms
[LuxRays][58.391] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.391] BVH build hierarchy time: 0ms
[LuxRays][58.391] BVH total build time: 0ms
[LuxRays][58.406] Total BVH memory usage: 101Kbytes
[LuxRays][58.406] BVH Dataset preprocessing time: 0ms
[LuxRays][58.406] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.406] BVH build hierarchy time: 0ms
[LuxRays][58.406] BVH total build time: 0ms
[LuxRays][58.406] Total BVH memory usage: 100Kbytes
[LuxRays][58.422] BVH Dataset preprocessing time: 15ms
[LuxRays][58.422] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.484] BVH build hierarchy time: 62ms
[LuxRays][58.484] BVH total build time: 77ms
[LuxRays][58.484] Total BVH memory usage: 12662Kbytes
[LuxRays][58.500] BVH Dataset preprocessing time: 16ms
[LuxRays][58.500] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.562] BVH build hierarchy time: 62ms
[LuxRays][58.562] BVH total build time: 78ms
[LuxRays][58.562] Total BVH memory usage: 12662Kbytes
[LuxRays][58.578] BVH Dataset preprocessing time: 0ms
[LuxRays][58.578] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.641] BVH build hierarchy time: 62ms
[LuxRays][58.641] BVH total build time: 62ms
[LuxRays][58.656] Total BVH memory usage: 12662Kbytes
[LuxRays][58.656] BVH Dataset preprocessing time: 0ms
[LuxRays][58.656] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.734] BVH build hierarchy time: 77ms
[LuxRays][58.734] BVH total build time: 77ms
[LuxRays][58.734] Total BVH memory usage: 12662Kbytes
[LuxRays][58.734] BVH Dataset preprocessing time: 0ms
[LuxRays][58.734] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.734] BVH build hierarchy time: 0ms
[LuxRays][58.734] BVH total build time: 0ms
[LuxRays][58.734] Total BVH memory usage: 101Kbytes
[LuxRays][58.750] BVH Dataset preprocessing time: 0ms
[LuxRays][58.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.750] BVH build hierarchy time: 0ms
[LuxRays][58.750] BVH total build time: 0ms
[LuxRays][58.750] Total BVH memory usage: 101Kbytes
[LuxRays][58.766] BVH Dataset preprocessing time: 0ms
[LuxRays][58.766] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.766] BVH build hierarchy time: 0ms
[LuxRays][58.766] BVH total build time: 0ms
[LuxRays][58.766] Total BVH memory usage: 102Kbytes
[LuxRays][58.766] Total BVH memory usage: 100Kbytes
[LuxRays][58.766] Total BVH memory usage: 101Kbytes
[LuxRays][58.781] Total BVH memory usage: 101Kbytes
[LuxRays][58.781] BVH Dataset preprocessing time: 0ms
[LuxRays][58.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.781] BVH build hierarchy time: 0ms
[LuxRays][58.781] BVH total build time: 0ms
[LuxRays][58.797] BVH build hierarchy time: 15ms
[LuxRays][58.797] BVH total build time: 15ms
[LuxRays][58.797] Total BVH memory usage: 101Kbytes
[LuxRays][58.797] BVH Dataset preprocessing time: 0ms
[LuxRays][58.797] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.812] BVH build hierarchy time: 15ms
[LuxRays][58.812] BVH total build time: 15ms
[LuxRays][58.812] Total BVH memory usage: 4259Kbytes
[LuxRays][58.812] BVH Dataset preprocessing time: 0ms
[LuxRays][58.812] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.828] BVH build hierarchy time: 16ms
[LuxRays][58.828] BVH total build time: 16ms
[LuxRays][58.828] Total BVH memory usage: 97Kbytes
[LuxRays][58.828] BVH Dataset preprocessing time: 0ms
[LuxRays][58.828] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.828] BVH build hierarchy time: 0ms
[LuxRays][58.828] BVH total build time: 0ms
[LuxRays][58.828] Total BVH memory usage: 165Kbytes
[LuxRays][58.844] BVH build hierarchy time: 16ms
[LuxRays][58.844] BVH total build time: 16ms
[LuxRays][58.844] Total BVH memory usage: 1997Kbytes
[LuxRays][58.844] BVH Dataset preprocessing time: 0ms
[LuxRays][58.844] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.859] BVH build hierarchy time: 14ms
[LuxRays][58.859] BVH total build time: 14ms
[LuxRays][58.859] Total BVH memory usage: 1999Kbytes
[LuxRays][58.859] BVH Dataset preprocessing time: 0ms
[LuxRays][58.859] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.859] BVH build hierarchy time: 0ms
[LuxRays][58.859] BVH total build time: 0ms
[LuxRays][58.859] Total BVH memory usage: 1Kbytes
[LuxRays][58.859] Total BVH memory usage: 17Kbytes
[LuxRays][58.875] BVH build hierarchy time: 16ms
[LuxRays][58.875] BVH total build time: 16ms
[LuxRays][58.875] Total BVH memory usage: 123Kbytes
[LuxRays][58.875] BVH Dataset preprocessing time: 0ms
[LuxRays][58.875] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.875] BVH build hierarchy time: 0ms
[LuxRays][58.875] BVH total build time: 0ms
[LuxRays][58.875] Total BVH memory usage: 1403Kbytes
[LuxRays][58.891] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.891] BVH build hierarchy time: 0ms
[LuxRays][58.891] BVH total build time: 16ms
[LuxRays][58.891] Total BVH memory usage: 14Kbytes
[LuxRays][58.891] BVH Dataset preprocessing time: 0ms
[LuxRays][58.891] BVH total build time: 0ms
[LuxRays][58.891] Total BVH memory usage: 110Kbytes
[LuxRays][58.891] Total BVH memory usage: 139Kbytes
[LuxRays][58.906] BVH Dataset preprocessing time: 0ms
[LuxRays][58.906] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.906] BVH build hierarchy time: 0ms
[LuxRays][58.906] BVH total build time: 0ms
[LuxRays][58.906] Total BVH memory usage: 250Kbytes
[LuxRays][58.906] Total BVH memory usage: 93Kbytes
[LuxRays][58.922] BVH build hierarchy time: 15ms
[LuxRays][58.922] BVH total build time: 15ms
[LuxRays][58.922] Total BVH memory usage: 3477Kbytes
[LuxRays][58.937] BVH Dataset preprocessing time: 0ms
[LuxRays][58.937] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.937] BVH build hierarchy time: 0ms
[LuxRays][58.937] BVH total build time: 0ms
[LuxRays][58.937] Total BVH memory usage: 1080Kbytes
[LuxRays][58.937] Total BVH memory usage: 390Kbytes
[LuxRays][58.953] BVH Dataset preprocessing time: 0ms
[LuxRays][58.953] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.953] BVH build hierarchy time: 0ms
[LuxRays][58.953] BVH total build time: 0ms
[LuxRays][58.953] Total BVH memory usage: 389Kbytes
Re: clBuildProgram
by arescet
[LuxRays][58.953] Total BVH memory usage: 390Kbytes
[LuxRays][58.969] BVH build hierarchy time: 16ms
[LuxRays][58.969] BVH total build time: 16ms
[LuxRays][58.969] Total BVH memory usage: 388Kbytes
[LuxRays][58.969] BVH Dataset preprocessing time: 0ms
[LuxRays][58.969] BVH builder: EMBREE_BINNED_SAH
[LuxRays][58.984] BVH build hierarchy time: 14ms
[LuxRays][58.984] BVH total build time: 14ms
[LuxRays][58.984] Total BVH memory usage: 2213Kbytes
[LuxRays][58.984] BVH Dataset preprocessing time: 0ms
[LuxRays][58.984] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.000] BVH build hierarchy time: 16ms
[LuxRays][59.000] BVH total build time: 16ms
[LuxRays][59.000] Total BVH memory usage: 2216Kbytes
[LuxRays][59.000] Building BVH for MBVH leaf: 316/474
[LuxRays][59.000] BVH Dataset preprocessing time: 0ms
[LuxRays][59.000] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.016] BVH build hierarchy time: 16ms
[LuxRays][59.016] BVH total build time: 16ms
[LuxRays][59.016] Total BVH memory usage: 2215Kbytes
[LuxRays][59.016] BVH Dataset preprocessing time: 0ms
[LuxRays][59.016] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.031] BVH build hierarchy time: 15ms
[LuxRays][59.031] BVH total build time: 15ms
[LuxRays][59.031] Total BVH memory usage: 2212Kbytes
[LuxRays][59.047] BVH Dataset preprocessing time: 15ms
[LuxRays][59.047] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.125] BVH build hierarchy time: 78ms
[LuxRays][59.125] BVH total build time: 93ms
[LuxRays][59.125] Total BVH memory usage: 16210Kbytes
[LuxRays][59.125] BVH Dataset preprocessing time: 0ms
[LuxRays][59.125] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.125] BVH build hierarchy time: 0ms
[LuxRays][59.125] BVH total build time: 0ms
[LuxRays][59.125] Total BVH memory usage: 165Kbytes
[LuxRays][59.172] BVH Dataset preprocessing time: 30ms
[LuxRays][59.172] BVH builder: EMBREE_BINNED_SAH
[LuxRays][59.531] BVH build hierarchy time: 359ms
[LuxRays][59.531] BVH total build time: 390ms
[LuxRays][59.531] Total BVH memory usage: 71319Kbytes
[LuxRays][59.594] BVH Dataset preprocessing time: 47ms
[LuxRays][59.594] BVH builder: EMBREE_BINNED_SAH
[LuxRays][60.000] BVH build hierarchy time: 405ms
[LuxRays][60.000] BVH total build time: 453ms
[LuxRays][60.000] Total BVH memory usage: 81110Kbytes
[LuxRays][60.078] BVH Dataset preprocessing time: 62ms
[LuxRays][60.078] BVH builder: EMBREE_BINNED_SAH
[LuxRays][60.625] BVH build hierarchy time: 546ms
[LuxRays][60.625] BVH total build time: 608ms
[LuxRays][60.625] Total BVH memory usage: 108571Kbytes
[LuxRays][60.734] BVH Dataset preprocessing time: 92ms
[LuxRays][60.734] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.437] BVH build hierarchy time: 703ms
[LuxRays][61.437] BVH total build time: 796ms
[LuxRays][61.437] Total BVH memory usage: 142217Kbytes
[LuxRays][61.453] Building BVH for MBVH leaf: 324/474
[LuxRays][61.453] BVH Dataset preprocessing time: 0ms
[LuxRays][61.453] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.469] BVH build hierarchy time: 16ms
[LuxRays][61.469] BVH total build time: 16ms
[LuxRays][61.469] Total BVH memory usage: 767Kbytes
[LuxRays][61.469] BVH Dataset preprocessing time: 0ms
[LuxRays][61.469] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.469] BVH build hierarchy time: 0ms
[LuxRays][61.469] BVH total build time: 0ms
[LuxRays][61.469] Total BVH memory usage: 766Kbytes
[LuxRays][61.484] BVH build hierarchy time: 14ms
[LuxRays][61.484] BVH total build time: 14ms
[LuxRays][61.484] Total BVH memory usage: 764Kbytes
[LuxRays][61.484] BVH Dataset preprocessing time: 0ms
[LuxRays][61.484] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.484] BVH build hierarchy time: 0ms
[LuxRays][61.484] BVH total build time: 0ms
[LuxRays][61.484] Total BVH memory usage: 767Kbytes
[LuxRays][61.500] BVH Dataset preprocessing time: 16ms
[LuxRays][61.500] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.562] BVH build hierarchy time: 62ms
[LuxRays][61.562] BVH total build time: 78ms
[LuxRays][61.562] Total BVH memory usage: 11223Kbytes
[LuxRays][61.562] BVH Dataset preprocessing time: 0ms
[LuxRays][61.562] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.594] BVH build hierarchy time: 32ms
[LuxRays][61.594] BVH total build time: 32ms
[LuxRays][61.594] Total BVH memory usage: 5819Kbytes
[LuxRays][61.609] BVH Dataset preprocessing time: 14ms
[LuxRays][61.609] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.641] BVH build hierarchy time: 32ms
[LuxRays][61.641] BVH total build time: 46ms
[LuxRays][61.641] Total BVH memory usage: 5943Kbytes
[LuxRays][61.641] BVH Dataset preprocessing time: 0ms
[LuxRays][61.641] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.672] BVH build hierarchy time: 30ms
[LuxRays][61.672] BVH total build time: 30ms
[LuxRays][61.672] Total BVH memory usage: 5909Kbytes
[LuxRays][61.672] BVH Dataset preprocessing time: 0ms
[LuxRays][61.672] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.703] BVH build hierarchy time: 31ms
[LuxRays][61.703] BVH total build time: 31ms
[LuxRays][61.703] Total BVH memory usage: 5817Kbytes
[LuxRays][61.719] BVH Dataset preprocessing time: 0ms
[LuxRays][61.719] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.734] BVH build hierarchy time: 14ms
[LuxRays][61.734] BVH total build time: 14ms
[LuxRays][61.734] Total BVH memory usage: 2629Kbytes
[LuxRays][61.734] BVH Dataset preprocessing time: 0ms
[LuxRays][61.734] BVH builder: EMBREE_BINNED_SAH
[LuxRays][61.750] BVH build hierarchy time: 16ms
[LuxRays][61.750] BVH total build time: 16ms
[LuxRays][61.750] Total BVH memory usage: 2623Kbytes
[LuxRays][61.781] BVH Dataset preprocessing time: 31ms
[LuxRays][61.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.031] BVH build hierarchy time: 250ms
[LuxRays][62.031] BVH total build time: 281ms
[LuxRays][62.031] Total BVH memory usage: 46411Kbytes
[LuxRays][62.047] BVH Dataset preprocessing time: 0ms
[LuxRays][62.047] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.078] BVH build hierarchy time: 31ms
[LuxRays][62.078] BVH total build time: 31ms
[LuxRays][62.078] Total BVH memory usage: 4818Kbytes
[LuxRays][62.078] BVH Dataset preprocessing time: 0ms
[LuxRays][62.078] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.078] BVH build hierarchy time: 0ms
[LuxRays][62.078] BVH total build time: 0ms
[LuxRays][62.078] Total BVH memory usage: 100Kbytes
[LuxRays][62.078] Total BVH memory usage: 101Kbytes
[LuxRays][62.094] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.094] BVH build hierarchy time: 0ms
[LuxRays][62.094] BVH total build time: 16ms
[LuxRays][62.094] Total BVH memory usage: 100Kbytes
[LuxRays][62.094] BVH Dataset preprocessing time: 0ms
[LuxRays][62.094] BVH total build time: 0ms
[LuxRays][62.109] BVH Dataset preprocessing time: 0ms
[LuxRays][62.109] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.109] BVH build hierarchy time: 0ms
[LuxRays][62.109] BVH total build time: 0ms
[LuxRays][62.109] Total BVH memory usage: 101Kbytes
[LuxRays][62.109] Total BVH memory usage: 100Kbytes
[LuxRays][62.125] BVH Dataset preprocessing time: 16ms
[LuxRays][62.125] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.187] BVH build hierarchy time: 62ms
[LuxRays][62.187] BVH total build time: 78ms
[LuxRays][62.187] Total BVH memory usage: 12663Kbytes
[LuxRays][62.203] BVH Dataset preprocessing time: 16ms
[LuxRays][62.203] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.266] BVH build hierarchy time: 62ms
[LuxRays][62.266] BVH total build time: 78ms
[LuxRays][62.266] Total BVH memory usage: 12663Kbytes
[LuxRays][62.281] BVH Dataset preprocessing time: 15ms
[LuxRays][62.281] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.344] BVH build hierarchy time: 62ms
[LuxRays][62.344] BVH total build time: 78ms
[LuxRays][62.344] Total BVH memory usage: 12663Kbytes
[LuxRays][62.359] BVH Dataset preprocessing time: 14ms
[LuxRays][62.359] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.422] BVH build hierarchy time: 62ms
[LuxRays][62.422] BVH total build time: 77ms
[LuxRays][62.422] Total BVH memory usage: 12663Kbytes
[LuxRays][62.437] BVH Dataset preprocessing time: 0ms
[LuxRays][62.437] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.437] BVH build hierarchy time: 0ms
[LuxRays][62.437] BVH total build time: 0ms
[LuxRays][62.437] Total BVH memory usage: 100Kbytes
[LuxRays][62.437] Total BVH memory usage: 101Kbytes
[LuxRays][62.453] BVH build hierarchy time: 16ms
[LuxRays][62.453] BVH total build time: 16ms
[LuxRays][62.453] Total BVH memory usage: 100Kbytes
[LuxRays][62.453] BVH Dataset preprocessing time: 0ms
[LuxRays][62.453] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.453] BVH build hierarchy time: 0ms
[LuxRays][62.453] BVH total build time: 0ms
[LuxRays][62.453] Total BVH memory usage: 101Kbytes
[LuxRays][62.469] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.469] BVH build hierarchy time: 0ms
[LuxRays][62.469] BVH total build time: 16ms
[LuxRays][62.469] Total BVH memory usage: 101Kbytes
[LuxRays][62.469] BVH Dataset preprocessing time: 0ms
[LuxRays][62.469] BVH total build time: 0ms
[LuxRays][62.469] Total BVH memory usage: 100Kbytes
[LuxRays][62.484] BVH Dataset preprocessing time: 0ms
[LuxRays][62.484] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.484] BVH build hierarchy time: 0ms
[LuxRays][62.484] BVH total build time: 0ms
[LuxRays][62.484] Total BVH memory usage: 100Kbytes
[LuxRays][62.484] Total BVH memory usage: 101Kbytes
[LuxRays][62.500] BVH build hierarchy time: 16ms
[LuxRays][62.500] BVH total build time: 16ms
[LuxRays][62.500] Total BVH memory usage: 100Kbytes
[LuxRays][62.500] BVH Dataset preprocessing time: 0ms
[LuxRays][62.500] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.516] BVH build hierarchy time: 16ms
[LuxRays][62.516] BVH total build time: 16ms
[LuxRays][62.516] Total BVH memory usage: 4251Kbytes
[LuxRays][62.516] BVH Dataset preprocessing time: 0ms
[LuxRays][62.516] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.531] BVH build hierarchy time: 15ms
[LuxRays][62.531] BVH total build time: 15ms
[LuxRays][62.531] Total BVH memory usage: 99Kbytes
[LuxRays][62.531] BVH Dataset preprocessing time: 0ms
[LuxRays][62.531] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.531] BVH build hierarchy time: 0ms
[LuxRays][62.531] BVH total build time: 0ms
[LuxRays][62.531] Total BVH memory usage: 165Kbytes
[LuxRays][62.547] BVH build hierarchy time: 15ms
[LuxRays][62.547] BVH total build time: 15ms
[LuxRays][62.547] Total BVH memory usage: 1960Kbytes
[LuxRays][62.547] BVH Dataset preprocessing time: 0ms
[LuxRays][62.547] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.562] BVH build hierarchy time: 15ms
[LuxRays][62.562] BVH total build time: 15ms
[LuxRays][62.562] Total BVH memory usage: 1964Kbytes
[LuxRays][62.562] BVH Dataset preprocessing time: 0ms
[LuxRays][62.562] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.562] BVH build hierarchy time: 0ms
[LuxRays][62.562] BVH total build time: 0ms
[LuxRays][62.562] Total BVH memory usage: 1Kbytes
[LuxRays][62.562] Total BVH memory usage: 17Kbytes
[LuxRays][62.578] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.578] BVH build hierarchy time: 0ms
[LuxRays][62.578] BVH total build time: 16ms
[LuxRays][62.578] Total BVH memory usage: 123Kbytes
[LuxRays][62.578] BVH Dataset preprocessing time: 0ms
[LuxRays][62.578] BVH total build time: 0ms
[LuxRays][62.578] Total BVH memory usage: 1403Kbytes
[LuxRays][62.594] BVH build hierarchy time: 16ms
[LuxRays][62.594] BVH total build time: 16ms
[LuxRays][62.594] Total BVH memory usage: 15Kbytes
[LuxRays][62.594] BVH Dataset preprocessing time: 0ms
[LuxRays][62.594] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.594] BVH build hierarchy time: 0ms
[LuxRays][62.594] BVH total build time: 0ms
[LuxRays][62.594] Total BVH memory usage: 14Kbytes
[LuxRays][62.594] Total BVH memory usage: 109Kbytes
[LuxRays][62.594] Total BVH memory usage: 139Kbytes
[LuxRays][62.609] BVH build hierarchy time: 14ms
[LuxRays][62.609] BVH total build time: 14ms
[LuxRays][62.609] Total BVH memory usage: 262Kbytes
[LuxRays][62.609] BVH Dataset preprocessing time: 0ms
[LuxRays][62.609] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.609] BVH build hierarchy time: 0ms
[LuxRays][62.609] BVH total build time: 0ms
[LuxRays][62.609] Total BVH memory usage: 89Kbytes
[LuxRays][62.625] BVH build hierarchy time: 16ms
[LuxRays][62.625] BVH total build time: 16ms
[LuxRays][62.641] Total BVH memory usage: 3487Kbytes
[LuxRays][62.641] BVH Dataset preprocessing time: 0ms
[LuxRays][62.641] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.641] BVH build hierarchy time: 0ms
[LuxRays][62.641] BVH total build time: 0ms
[LuxRays][62.641] Total BVH memory usage: 1089Kbytes
[LuxRays][62.656] BVH build hierarchy time: 15ms
[LuxRays][62.656] BVH total build time: 15ms
[LuxRays][62.656] Total BVH memory usage: 392Kbytes
[LuxRays][62.656] BVH Dataset preprocessing time: 0ms
[LuxRays][62.656] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.656] BVH build hierarchy time: 0ms
[LuxRays][62.656] BVH total build time: 0ms
[LuxRays][62.672] BVH build hierarchy time: 15ms
[LuxRays][62.672] BVH total build time: 15ms
[LuxRays][62.672] Total BVH memory usage: 393Kbytes
[LuxRays][62.672] BVH Dataset preprocessing time: 0ms
[LuxRays][62.672] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.687] BVH build hierarchy time: 15ms
[LuxRays][62.687] BVH total build time: 15ms
[LuxRays][62.687] Total BVH memory usage: 2220Kbytes
[LuxRays][62.687] BVH Dataset preprocessing time: 0ms
[LuxRays][62.687] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.703] BVH build hierarchy time: 16ms
[LuxRays][62.703] BVH total build time: 16ms
[LuxRays][62.703] Total BVH memory usage: 2220Kbytes
[LuxRays][62.703] BVH Dataset preprocessing time: 0ms
[LuxRays][62.703] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.719] BVH build hierarchy time: 16ms
[LuxRays][62.719] BVH total build time: 16ms
[LuxRays][62.719] Total BVH memory usage: 2223Kbytes
[LuxRays][62.719] BVH Dataset preprocessing time: 0ms
[LuxRays][62.719] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.734] BVH build hierarchy time: 14ms
[LuxRays][62.734] BVH total build time: 14ms
[LuxRays][62.734] Total BVH memory usage: 2223Kbytes
[LuxRays][62.750] BVH Dataset preprocessing time: 16ms
[LuxRays][62.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.828] BVH build hierarchy time: 78ms
[LuxRays][62.828] BVH total build time: 94ms
[LuxRays][62.828] Total BVH memory usage: 16258Kbytes
[LuxRays][62.828] BVH Dataset preprocessing time: 0ms
[LuxRays][62.828] BVH builder: EMBREE_BINNED_SAH
[LuxRays][62.828] BVH build hierarchy time: 0ms
[LuxRays][62.828] BVH total build time: 0ms
[LuxRays][62.828] Total BVH memory usage: 164Kbytes
[LuxRays][62.875] BVH Dataset preprocessing time: 46ms
[LuxRays][62.875] BVH builder: EMBREE_BINNED_SAH
[LuxRays][63.250] BVH build hierarchy time: 375ms
[LuxRays][63.250] BVH total build time: 421ms
[LuxRays][63.250] Total BVH memory usage: 71218Kbytes
[LuxRays][63.312] BVH Dataset preprocessing time: 62ms
[LuxRays][63.312] BVH builder: EMBREE_BINNED_SAH
[LuxRays][63.703] BVH build hierarchy time: 391ms
[LuxRays][63.703] BVH total build time: 453ms
[LuxRays][63.703] Total BVH memory usage: 81300Kbytes
[LuxRays][63.703] Building BVH for MBVH leaf: 415/474
[LuxRays][63.781] BVH Dataset preprocessing time: 78ms
[LuxRays][63.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][64.297] BVH build hierarchy time: 515ms
[LuxRays][64.297] BVH total build time: 593ms
[LuxRays][64.297] Total BVH memory usage: 108704Kbytes
[LuxRays][64.406] BVH Dataset preprocessing time: 94ms
[LuxRays][64.406] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.109] BVH build hierarchy time: 702ms
[LuxRays][65.109] BVH total build time: 796ms
[LuxRays][65.109] Total BVH memory usage: 142166Kbytes
[LuxRays][65.125] BVH Dataset preprocessing time: 0ms
[LuxRays][65.125] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.141] BVH build hierarchy time: 16ms
[LuxRays][65.141] BVH total build time: 16ms
[LuxRays][65.141] Total BVH memory usage: 767Kbytes
[LuxRays][65.141] BVH Dataset preprocessing time: 0ms
[LuxRays][65.141] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.141] BVH build hierarchy time: 0ms
[LuxRays][65.141] BVH total build time: 0ms
[LuxRays][65.141] Total BVH memory usage: 769Kbytes
[LuxRays][65.156] BVH build hierarchy time: 15ms
[LuxRays][65.156] BVH total build time: 15ms
[LuxRays][65.156] Total BVH memory usage: 764Kbytes
[LuxRays][65.156] BVH Dataset preprocessing time: 0ms
[LuxRays][65.156] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.156] BVH build hierarchy time: 0ms
[LuxRays][65.156] BVH total build time: 0ms
[LuxRays][65.156] Total BVH memory usage: 766Kbytes
[LuxRays][65.172] BVH build hierarchy time: 15ms
[LuxRays][65.172] BVH total build time: 15ms
[LuxRays][65.172] Total BVH memory usage: 395Kbytes
[LuxRays][65.172] BVH Dataset preprocessing time: 0ms
[LuxRays][65.172] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.172] BVH build hierarchy time: 0ms
[LuxRays][65.172] BVH total build time: 0ms
[LuxRays][65.172] Total BVH memory usage: 393Kbytes
[LuxRays][65.172] Total BVH memory usage: 394Kbytes
[LuxRays][65.187] BVH build hierarchy time: 15ms
[LuxRays][65.187] BVH total build time: 15ms
[LuxRays][65.187] Total BVH memory usage: 392Kbytes
[LuxRays][65.187] BVH Dataset preprocessing time: 0ms
[LuxRays][65.187] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.250] BVH build hierarchy time: 62ms
[LuxRays][65.250] BVH total build time: 62ms
[LuxRays][65.250] Total BVH memory usage: 11262Kbytes
[LuxRays][65.250] BVH Dataset preprocessing time: 0ms
[LuxRays][65.250] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.281] BVH build hierarchy time: 31ms
[LuxRays][65.281] BVH total build time: 31ms
[LuxRays][65.297] Total BVH memory usage: 5836Kbytes
[LuxRays][65.297] BVH Dataset preprocessing time: 0ms
[LuxRays][65.297] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.328] BVH build hierarchy time: 31ms
[LuxRays][65.328] BVH total build time: 31ms
[LuxRays][65.328] Total BVH memory usage: 5942Kbytes
[LuxRays][65.328] BVH Dataset preprocessing time: 0ms
[LuxRays][65.328] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.359] BVH build hierarchy time: 30ms
[LuxRays][65.359] BVH total build time: 30ms
[LuxRays][65.359] Total BVH memory usage: 5922Kbytes
[LuxRays][65.375] BVH Dataset preprocessing time: 0ms
[LuxRays][65.375] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.406] BVH build hierarchy time: 31ms
[LuxRays][65.406] BVH total build time: 31ms
[LuxRays][65.406] Total BVH memory usage: 5843Kbytes
[LuxRays][65.406] BVH Dataset preprocessing time: 0ms
[LuxRays][65.406] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.422] BVH build hierarchy time: 15ms
[LuxRays][65.422] BVH total build time: 15ms
[LuxRays][65.422] Total BVH memory usage: 2627Kbytes
[LuxRays][65.437] BVH Dataset preprocessing time: 15ms
[LuxRays][65.437] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.453] BVH build hierarchy time: 16ms
[LuxRays][65.453] BVH total build time: 31ms
[LuxRays][65.453] Total BVH memory usage: 2622Kbytes
[LuxRays][65.484] BVH Dataset preprocessing time: 30ms
[LuxRays][65.484] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.750] BVH build hierarchy time: 266ms
[LuxRays][65.750] BVH total build time: 296ms
[LuxRays][65.750] Total BVH memory usage: 46460Kbytes
[LuxRays][65.750] Building BVH for MBVH leaf: 433/474
[LuxRays][65.750] BVH Dataset preprocessing time: 0ms
[LuxRays][65.750] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.781] BVH build hierarchy time: 31ms
[LuxRays][65.781] BVH total build time: 31ms
[LuxRays][65.781] Total BVH memory usage: 4848Kbytes
[LuxRays][65.781] BVH Dataset preprocessing time: 0ms
[LuxRays][65.781] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.781] BVH build hierarchy time: 0ms
[LuxRays][65.781] BVH total build time: 0ms
[LuxRays][65.781] Total BVH memory usage: 101Kbytes
[LuxRays][65.797] BVH build hierarchy time: 15ms
[LuxRays][65.797] BVH total build time: 15ms
[LuxRays][65.797] Total BVH memory usage: 101Kbytes
[LuxRays][65.797] BVH Dataset preprocessing time: 0ms
[LuxRays][65.797] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.797] BVH build hierarchy time: 0ms
[LuxRays][65.797] BVH total build time: 0ms
[LuxRays][65.812] BVH build hierarchy time: 15ms
[LuxRays][65.812] BVH total build time: 15ms
[LuxRays][65.812] Total BVH memory usage: 101Kbytes
[LuxRays][65.812] BVH Dataset preprocessing time: 0ms
[LuxRays][65.812] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.812] BVH build hierarchy time: 0ms
[LuxRays][65.812] BVH total build time: 0ms
[LuxRays][65.812] Total BVH memory usage: 102Kbytes
[LuxRays][65.828] BVH Dataset preprocessing time: 0ms
[LuxRays][65.828] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.891] BVH build hierarchy time: 62ms
[LuxRays][65.891] BVH total build time: 62ms
[LuxRays][65.891] Total BVH memory usage: 12660Kbytes
[LuxRays][65.906] BVH Dataset preprocessing time: 15ms
[LuxRays][65.906] BVH builder: EMBREE_BINNED_SAH
[LuxRays][65.969] BVH build hierarchy time: 62ms
[LuxRays][65.969] BVH total build time: 78ms
[LuxRays][65.969] Total BVH memory usage: 12658Kbytes
[LuxRays][65.984] BVH Dataset preprocessing time: 0ms
[LuxRays][65.984] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.047] BVH build hierarchy time: 62ms
[LuxRays][66.047] BVH total build time: 62ms
[LuxRays][66.047] Total BVH memory usage: 12660Kbytes
[LuxRays][66.062] BVH Dataset preprocessing time: 0ms
[LuxRays][66.062] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.125] BVH build hierarchy time: 62ms
[LuxRays][66.125] BVH total build time: 62ms
[LuxRays][66.125] Total BVH memory usage: 12660Kbytes
[LuxRays][66.141] BVH Dataset preprocessing time: 0ms
[LuxRays][66.141] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.141] BVH build hierarchy time: 0ms
[LuxRays][66.141] BVH total build time: 0ms
[LuxRays][66.141] Total BVH memory usage: 101Kbytes
[LuxRays][66.156] BVH build hierarchy time: 15ms
[LuxRays][66.156] BVH total build time: 15ms
[LuxRays][66.156] Total BVH memory usage: 101Kbytes
[LuxRays][66.156] BVH Dataset preprocessing time: 0ms
[LuxRays][66.156] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.156] BVH build hierarchy time: 0ms
[LuxRays][66.156] BVH total build time: 0ms
[LuxRays][66.172] BVH build hierarchy time: 15ms
[LuxRays][66.172] BVH total build time: 15ms
[LuxRays][66.172] Total BVH memory usage: 101Kbytes
[LuxRays][66.172] BVH Dataset preprocessing time: 0ms
[LuxRays][66.172] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.172] BVH build hierarchy time: 0ms
[LuxRays][66.172] BVH total build time: 0ms
[LuxRays][66.172] Total BVH memory usage: 100Kbytes
[LuxRays][66.172] Total BVH memory usage: 102Kbytes
[LuxRays][66.187] BVH build hierarchy time: 15ms
[LuxRays][66.187] BVH total build time: 15ms
[LuxRays][66.187] Total BVH memory usage: 101Kbytes
[LuxRays][66.187] BVH Dataset preprocessing time: 0ms
[LuxRays][66.187] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.187] BVH build hierarchy time: 0ms
[LuxRays][66.187] BVH total build time: 0ms
[LuxRays][66.203] BVH Dataset preprocessing time: 0ms
[LuxRays][66.203] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.203] BVH build hierarchy time: 0ms
[LuxRays][66.203] BVH total build time: 0ms
[LuxRays][66.203] Total BVH memory usage: 101Kbytes
[LuxRays][66.219] BVH build hierarchy time: 16ms
[LuxRays][66.219] BVH total build time: 16ms
[LuxRays][66.219] Total BVH memory usage: 101Kbytes
[LuxRays][66.219] BVH Dataset preprocessing time: 0ms
[LuxRays][66.219] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.234] BVH build hierarchy time: 14ms
[LuxRays][66.234] BVH total build time: 14ms
[LuxRays][66.234] Total BVH memory usage: 4252Kbytes
[LuxRays][66.234] BVH Dataset preprocessing time: 0ms
[LuxRays][66.234] BVH builder: EMBREE_BINNED_SAH
[LuxRays][66.250] BVH build hierarchy time: 16ms
[LuxRays][66.250] BVH total build time: 16ms
[LuxRays][66.250] Total BVH memory usage: 0Kbytes
[LuxRays][66.250] Building Multilevel Bounding Volume Hierarchy root tree
[LuxRays][66.250] MBVH root tree builder: EMBREE_BINNED_SAH
[LuxRays][66.250] MBVH build time: 18516ms
[LuxRays][66.250] Total Multilevel BVH memory usage: 2967471Kbytes
[LuxRays][66.250] Adding DataSet accelerator: EMBREE
[LuxRays][66.250] Total vertex count: 37072199
[LuxRays][66.250] Total triangle count: 63751084
[LuxRays][70.016] EmbreeAccel build time: 3766ms
[LuxRays][70.391] [Device GeForce GTX 1660 Ti Intersect] MBVH mesh vertices buffer size: 431805Kbytes
[LuxRays][71.641] [Device GeForce GTX 1660 Ti Intersect] MBVH nodes buffer size: 1572864Kbytes
[LuxRays][72.625] [Device GeForce GTX 1660 Ti Intersect] MBVH nodes buffer size: 1394607Kbytes
[LuxRays][73.203] [Device GeForce GTX 1660 Ti Intersect] MBVH leaf transformations buffer size: 6400bytes
[LuxRays][73.234] [OpenCL device::GeForce GTX 1660 Ti Intersect] MBVH compilation error:
<kernel>:1320:20: error: use of undeclared identifier 'MBVH_NODES_PAGE_SIZE'
if (*nodeIndex >= MBVH_NODES_PAGE_SIZE) {
<kernel>:1619:37: warning: initializing '__global BVHArrayNode *restrict __attribute__((address_space(16776963)))' with an expression of type 'const __global BVHArrayNode *restrict __attribute__((address_space(16776963)))' discards qualifiers
__global BVHArrayNode* restrict stopaccelNodePage = accelNodePages[currentPage];
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\base.py", line 82, in render_final
final.render(self, depsgraph)
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 49, in render
_render_layer(engine, depsgraph, statistics, layer)
File "C:\Users\user\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 73, in _render_layer
engine.session.Start()
RuntimeError: clBuildProgram
ERROR: clBuildProgram
[LuxRays][73.234] WARNING: there is a memory leak in LuxRays HardwareDevice GeForce GTX 1660 Ti Intersect: 3480866680bytes
Re: clBuildProgram
Posted: Fri Apr 10, 2020 11:24 pm
The problem is here:
Going to check tomorrow what it is.
Re: clBuildProgram
Posted: Sat Apr 11, 2020 9:42 am
Dade wrote: ↑Fri Apr 10, 2020 11:24 pm
I should have fixed this problem: it was caused by a limitation on your GPU (i.e. the maximum size of contiguous memory allocable) and the very large count of vertices and triangles in your scene.
It is a bit hard to test the fix for me because my GPU doesn't have this limit but it should work now.
