clBuildProgram
arescet
Re: clBuildProgram
Post by arescet » Sat Apr 11, 2020 7:48 pm
Dade wrote:
Sat Apr 11, 2020 9:42 am
Dade wrote:
Fri Apr 10, 2020 11:24 pm
The problem is here:
<kernel>:1320:20: error: use of undeclared identifier 'MBVH_NODES_PAGE_SIZE'
        if (*nodeIndex >= MBVH_NODES_PAGE_SIZE) {
Going to check tomorrow what it is.
I should have fixed this problem: it was caused by a limitation on your GPU (i.e. the maximum size of contiguous memory allocable) and the very large count of vertices and triangles in your scene.
It is a bit hard to test the fix for me because my GPU doesn't have this limit but it should work now.
Hi Dade,
i downloaded the newest version earlier and now it just crashes on me after "creating render session".
i appreciate you looking into it, i probably will do it on CPU once i figure out how i want the entire thing to look.
i have the time to render it on CPU anyways, was just curious if that error was on user side.
thanks so much
