Difference between CPU and OpenCL
Posted: Thu Mar 26, 2020 3:27 pm
sorry, one more thing: with this latest version and with OpenCL two normal map mixed togheter with the add node gives a black surface, with one normal is ok, with CPU is ok, with the latest stable version is ok both with CPU and GPU. And when I select the texurture in the node editor and the file explorer is closed the interface doesn't come back to the node editor but goes to the image editor I hope to be at least a good bug finder
