I've downloaded the latest daily BlendLuxCore build (24th of march) and installed on a daily Blender 2.83 Alpha released yesterday.
The viewport rendering using GPU in an "old" scene (as "old" I mean a saved scene build from scratch some versions ago and always updated until 2.3 with no problems) that seems have some problems: it's really slow compared to CPU (never be, I've a Quadro K5200 that was always at least 2 or 3 time faster) and the Blender interface is really laggish.
performance during viewport rendering
-CPU about 180k
-GPU about 40k
Just for info, if I open the default blender scene I've this performance
- CPU about 240k
- GPU about 3,2M
And if I start a standard rendering (as standard I mean no viewport rendering) GPU come back faster than CPU
CPU 250k
GPU 1M
what setting should affect the viewport rendering on GPU?
Viewport rendering: strange GPU slowness
Re: Viewport rendering: strange GPU slowness
I have the scene here and I can reproduce the problem, but can you post a link to the scene so others can test it?
Here's a video showing the problem: https://youtu.be/4mGIAl-AAtw
It is a pretty heavy scene, and for some reason RTPathOCL is worse at dealing with it than PathOCL.
Unfortunately, once a viewport render runs, the framerate of RTPathOCL and the Blender interface is coupled, so if the render performance is low and frames only trickle in, the whole interface stutters.
Side note, you should put your assets on a different view layer and make them invisible on the main scene view layer, in order to save a ton of geometry, lights etc. that are not visible from the camera, but present in the scene. But this is off-topic, in an ideal world it shouldn't matter how heavy the scene is.
Thank you for you suggestions.
Meanwhile I'll try it.
But do you think that it should be solved or i should live with it?
I think it should be solved, but I don't know how best to achieve it yet.
It would be interesting to know if RTPathOCL worked better in this scene before v2.4.
Can you double-check this with an older LuxCore version that worked for you, making sure that you are using OpenCL in viewport? Because in older BlendLuxCore versions, the viewport was using CPU by default even when the main engine was set to OpenCL.
I've good news for you (for us... )
Probably I've found what slow down everything.
Probably also in the heavy scene I've sent and that you checked before, there is a mesh with a particle system to make fur for a carpet.
It should have this shape It's near a cube with an empty object called "UV_Tappeto_Interface...."
If you remove the particles from the viewport render, it render fast as GPU can (1M samples/sec with out env cache, 2,2M with env cache on)
And, probably the standard rendering was faster with GPU cause the particle system was disabled on rendering (camera icon on particle system off)
I have tracked the problem down to one rug with a hair system.
It seems to be the sole object responsible for the slow rendering (when I hide it, the viewport runs fast).
It looks to me like there's a bug in our hair export, which causes the hairs to be generated from rug surface to world origin, creating very long strands. I created an issue for this: https://github.com/LuxCoreRender/BlendL ... issues/408
- Attachments
- marcatore_scene_isolated_rug.zip
- (556.65 KiB) Downloaded 159 times
So the slowdown can probably tracked back to BVH quality: it will be slow with normal PATHOCL too if rendering the same scene.B.Y.O.B. wrote: ↑Tue Mar 24, 2020 10:50 am It looks to me like there's a bug in our hair export, which causes the hairs to be generated from rug surface to world origin, creating very long strands. I created an issue for this: https://github.com/LuxCoreRender/BlendL ... issues/408
