Meshlight intensity problem
- Odilkhan Yakubov
I used one mesh for emitter, but when i change every settings in Emitter node nothing changed on mesh intensity. What is my mistake?
Re: Meshlight intensity problem
Are you using tone mapping auto-linear or something similar ? You need to use a linear tone mapper or the auto-linear tone mapper will scale down the general image light intensity every time you scale up the light intensity.Odilkhan Yakubov wrote: ↑Wed Mar 28, 2018 1:22 pm I used one mesh for emitter, but when i change every settings in Emitter node nothing changed on mesh intensity. What is my mistake?
Maybe you are using an automatic tonemapper?
See "when I change the brightness of my lamp, nothing happens"
The tonemapper settings are in the camera tab, imagepipeline panel.
- Odilkhan Yakubov
I used always Filmic LUT and Base contrast on the preset.
That has nothing to do with your problem.
Look into the camera settings, disable the automatic tonemapping.
If you need it I can post a screenshot.
The wiki section on this topic is not yet written unfortunately.
- Odilkhan Yakubov
Ok, ill check
- Odilkhan Yakubov
Thank you guys. Solved!
