tiled rendering for 8k,4k image
PetrT
Post by PetrT »
Hi
Can be tiled rendering be more effective?
Some times using tiled render render stops with not enouph memory error (GTX1070 8gb)
Re: tiled rendering for 8k,4k image
PetrT wrote: Mon Mar 23, 2020 8:30 am Can be tiled rendering be more effective?
Do you have a scene that render fine at low resolution but goes out of memory at 4/8K with tile rendering ?
PetrT
Post by PetrT »
this one does not rendered in 1080 with 256 px and 16.shows black screen.It is not too complex
Can not find exact example maybe later
16 AA samples with such a big tile size is a lot. Using more AA samples requires more memory, if I remember correctly.
PetrT wrote: Mon Mar 23, 2020 4:16 pm this one does not rendered in 1080 with 256 px and 16.shows black screen.It is not too complex
In LuxCore, rendering a tile at 256x256x16 AA is like rendering an image with 256x256x16 pixels so it is like rendering an image at 1K resolution. Plus Lux is also rendering multiple tiles at the same time so you are probably using a LOT of ram for the image.
Just use the default tile size, something like 64x64x16 or even smaller. It should solve your problem.
PetrT
Post by PetrT »
Thanks
Some test examples
32 px AA 25
625 samples time=2 min 45sek
No tiles
625 samples time=2 min 30sek
256 px AA 2
625 samples time=2 min 56sek
Dez!
Post by Dez! »
Why are these artifacts occurring?
https://prnt.sc/vzvhin
Dez! wrote: Thu Dec 10, 2020 3:40 pm Why are these artifacts occurring?
Are you using tile rendering ? Mixing CPU and GPU rendering ? What version are you using ?
Dez!
Post by Dez! »
Win 10, Blender 2.83/9, CPU+GPU, Lux 2.5
file sent in PM
Dez!
Post by Dez! »
The problem turned out to be in AMD drivers not working with the ColorRamp node in the materials. This led to the crash.
