HDRI issue in a scene
Oscar9531
Post by Oscar9531 »
Hi guys, Im having a problem with HDRI ilumintion in a project scene, the colors are inverted and it generates wrong ilumination... In a new scene it is fine. I dont know what I've done! :oops:
Wrong Ilumination in my project scene:
Correct ilumination in a new scene:
Re: HDRI issue in a scene
Can you upload the broken scene?
Oscar9531
Post by Oscar9531 »
B.Y.O.B. wrote: Mon Mar 16, 2020 10:54 pm Can you upload the broken scene?
Sure! but not the project cause I can't share it, just the file with the HDRI from hdri haven and the chair that I modeled to fill hahaha... But the file is still broken, so I think it works for this! thanks so much!
https://drive.google.com/open?id=1IM2uh ... RdykCkLXRP
Sorry, I couldnt upload it here :oops:
The clamping value is way too low. It is set to 0.1, while the recommended value is 417.
Oscar9531
Post by Oscar9531 »
B.Y.O.B. wrote: Tue Mar 17, 2020 2:12 am The clamping value is way too low. It is set to 0.1, while the recommended value is 417.
Thanks!, it fixed it, but I was using it really well and rendered some images before with that value, thats even the suggested value
Sin título.png (4.93 KiB) Viewed 2990 times
But anyways, thank you!
The suggested value can only be calculated if clamping is disabled,
You probably calculated it once, then rendered with it, then changed something in the lighting setup and didn't render without clamping since.
Disable the clamping and start a render to get an updated suggested value.
Oscar9531
Post by Oscar9531 »
B.Y.O.B. wrote: Tue Mar 17, 2020 2:30 am The suggested value can only be calculated if clamping is disabled,
oh! ok, that was the suggested value from the beginning, my bad :mrgreen:
