Bump / Normal map not seen in final render
Noah_
Post by Noah_ »
I wanted to do a test with the anvil of the Blenderguru tutorial but in luxcore and I have this problem
Anyone know why this may be happening?
Full Hybrid Back/Forward path tracing - I don't like clamping - Bidir it's great but very slow - I have 4096 MiB de Vram and I want to cry.
Re: Bump / Normal map not seen in final render
You should post a test scene and some information about the version you are using :?:
Noah_
Post by Noah_ »
The file is heavy
https://www.mediafire.com/file/ess2ow1p ... l.zip/file
Blender 2.82/Luxcore2.3beta2
I'm not going to download this file for 3 hours.
Can you strip it down so it is smaller, but still shows the problem?
Noah_
Post by Noah_ »
B.Y.O.B. wrote: Fri Feb 28, 2020 11:16 pm I'm not going to download this file for 3 hours.
Three hours? BYOB I live in a third world country with 10 megabytes I download it in 20 minutes
B.Y.O.B. wrote: Fri Feb 28, 2020 11:16 pm Can you strip it down so it is smaller, but still shows the problem?
I will try, if the problem remains
I guess the hoster throttles the download rate?
Noah_
Post by Noah_ »
Test.zip
You can replicate the problem with a plane
Noah_ wrote: Sat Feb 29, 2020 1:31 am Test.zipYou can replicate the problem with a plane
This is a known limitation/difference between CPU and OpenCL rendering: you need to connect the the bump mapping to the root Mix node, not to the 2 Disney sub-nodes. Just mix the bump map textures and connect the result to the bump socket of the root node, you will have the same result between CPU and OpenCL.
Noah_
Post by Noah_ »
Dade wrote: Sat Feb 29, 2020 2:49 pm
Wow thanks Dade but ...
Do you have an example image of this?
Edit:
I understood, connect the relief map in the input bump of the material mix.
Works. Thank you
