LuxCore and Animation
dimitripaiva
Post by dimitripaiva » Sun Feb 02, 2020 6:25 pm
Hello, guys. I'm a new user of LuxCore and I would like to do a couple of questions. I'm a motion designer and animator, so I would like to know about LuxCore and Animation, specially regarding its performance. Is it a good render engine for animations? I did some quick testing and find a lot of noise on each frame, which the denoiser doesn't solve at all. It would be nice to have some advise in order to know how to proper configure the settings for animation works.
Cheers!
Re: LuxCore and Animation
Post by Sharlybg » Mon Feb 03, 2020 8:09 am
Try to reduce your clamping value to something like 5. avoid 100 % white or black shader (80% max).
Noah_
Post by Noah_ » Sat Feb 15, 2020 10:09 am
Does it work in all render cases?
Full Hybrid Back/Forward path tracing - I don't like clamping - Bidir it's great but very slow - I have 4096 MiB de Vram and I want to cry.
Post by Dade » Sat Feb 15, 2020 12:31 pm
Clamping value is very dependent on the light sources types. You have mostly 2 cases: indoor Vs. outdoor (area/point/etc. lights Vs. Sun/Sky/HDR/etc.).
Noah_
Post by Noah_ » Sat Feb 15, 2020 2:14 pm
And with set suggested value is it unfeasible for animation?
Post by Dade » Sat Feb 15, 2020 3:21 pm
I mean, you can not have a clamp value good for all animations but it shouldn't be hard to find one for a specific animation (it will be just a very different value between indoor and outdoor animations).
