Falloff?
Racleborg
Falloff?
Post by Racleborg »
Hi All
Is this how to create a type of falloff :?: (attached)
Thanks
Luximage
Re: Falloff?
Post by Luximage »
Also you can use a combination of these factors with the mix color or the band node.
falloff factors.blend
(577.51 KiB) Downloaded 224 times
Racleborg
Re: Falloff?
Post by Racleborg »
by Luximage » Sun Feb 02, 2020 3:30 pm
(577.51 KiB) Downloaded 2 times
Many thanks. This info will be really helpful! :D
SlowHand
Re: Falloff?
Post by SlowHand »
You should calculate dot product between (shading normal vector) and normalized(camera_position - shading position).
I hard-coded the position of a camera.
It would be great if we could get the camera position and calculate a normalized vector from nodes.
Racleborg
Re: Falloff?
Post by Racleborg »
Hi SlowHand
I will create the setup and play around with it quite a bit to try and get an understanding of what the nodes are actually doing. I'm a bit out of my depth at the moment. :oops:
Many thanks :D
PetrT
Re: Falloff?
Post by PetrT »
Falloff become more close to Luxcore ;)
Yes it must be faced to camera always and camera position is needed
