Error in object material reference
marcatore
Post by marcatore »
Hi guys,
I've this problem.
Blender2.82, Daily build downloaded today (21st of Jan).
I'm using a scene that was always working but today not.
when I press render I have this error in the console (render stop and don't continue).
RuntimeError: Syntax error in object material reference: 3776276560
ERROR: Syntax error in object material reference: 3776276560
After some try&tests I've isolated some collections that have some objects with different materials.
is there a way to identify which material is causing this error using that code (3776276560)?
thanks in advance
Re: Error in object material reference
Can you upload the scene, or send it to me via PM?
marcatore
Post by marcatore »
Sent a PM
Thanks, I'll look into it once I am done with another issue I'm currently working on.
marcatore
Post by marcatore »
Thank you very much for your support.
marcatore
Post by marcatore »
meanwhile I've made other tests and I've found the reason.
I sent you a PM with some details.
I can't understand if I did something wrong or if it's a bug.
This kind of message indicates a bug. When there's an error in the way the scene is set up, you would get a nicer message with explanation and an entry in the error log.
I have fixed the bug.
marcatore
Post by marcatore »
Thank you very much.
It's working!
