HDRI Manipulation (scaling)
Posted: Mon Jan 13, 2020 12:47 am
by PDRA
Hi there again!
I was wondering this time if there is a way to manipulate the HDRI I'm using.
Particularly, what I would like to do is to scale it to adjust the reflection of the object. Is there any way to do it? I know that i can adjust the rotation but I don't see it for the scale.
There is a message that says "For free transformation use a hemi lamp" but, if I'm not wrong, they removed it in the latest releases.
I've tried doing it with a sphere but it isn't working.
Regards, saludos
Pablo
Re: HDRI Manipulation (scaling)
Posted: Mon Jan 13, 2020 5:53 am
by Fox
The scale won't change reflection size, i don't think there is option for it.
Posted: Mon Jan 13, 2020 10:29 am
This was moved to the sun light, this description should be updated.
What you ask for is not really possible: The HDRI is mapped to fit on a sphere surrounding the scene at infinite distance. Scaling the whole thing would not change the look at all. Scaling just one region would distort everything else, something like this:
Posted: Mon Jan 13, 2020 2:49 pm
by PDRA
I upload a video to better explain what I would like to achieve.
I'm trying to find if there is a way to fine tune the HDRI like with the tools that Keyshot offers.
Regards, saludos
Pablo
Posted: Mon Jan 13, 2020 5:00 pm
I'm trying to understand what it is: it looks like some kind of field view angle that work only for HDR (a bit strange).
Posted: Mon Jan 13, 2020 6:27 pm
Hi there again!
Regards, saludos
Pablo
You can apply HDRI tex to the sphere (making it an emitter) with UV spherical mapping. Then manipulate sphere scale/rot/pos to your liking.
Here's a simple scene to check
Posted: Mon Jan 13, 2020 7:31 pm
by PDRA
Thanks kintuX! That is what I've tried with the sphere but I couldn't solve two things:
- It looked very "dull" when I applied it in comparison to the result I got using the HDRI slot in the world tab (even after playing a bit with the gamma and brightness) I might solve this one fine tunning it a bit more.
- The second thing I couldn't work out is how to make the sphere not appear in the camera but only in the reflections (also avoid self casting shadows). This is mainly to get a correct Alpha channel to later use for the composition. As I remember this feature will be released in the next version, right? Or is there a way to do it with the current one?
It is working as kintuX showed. It seems to be projected over a sphere that you can control its size, Z position and rotation. You can see in the very first seconds when it gets really small that it has the shape of a sphere.
Regards, saludos
Pablo
