subdivision shape
lacilaci
subdivision shape
Post by lacilaci »
Anyone else noticed that using subdivision shape is a looot slower and takes a lot more vram than pre-subdividing mesh in blender?
when I did like max 4 subdivision on a mesh using shape node I got very slow startup and about 4gb Vram usage
when I did max 2 subdivisions on node and a mesh that was 2x pre-subdivided I got a lot faster startup and just 1.5GB vram usage
I could maybe understand slower startup if the subdivision is adaptive, but why so much more vram?
Re: subdivision shape
Was the total amount of triangles the same at the end ? There may be a (large) difference if you are using quads inside Blender :idea:
lacilaci
Post by lacilaci »
Dade wrote: Mon Jan 06, 2020 10:00 am Was the total amount of triangles the same at the end ? There may be a (large) difference if you are using quads inside Blender :idea:
will look into that, but... if max value is 2 then it should be at most the same as blender which was set to 2 anyways, no?
