mix material and velvet have broken bump
Post by lacilaci » Sat Jan 04, 2020 10:26 am
seems when you were fixing bump mapping you missed mx material..
disney
mix material(set 100% to use only second slot which is the same disney as example before)
Velvet gets also ruined by bump mapping....
Re: mix material and velvet have broken bump
Post by Dade » Thu Jan 23, 2020 3:21 pm
This is likely to be the same problem described here https://github.com/LuxCoreRender/LuxCore/issues/198 and I fixed the problem today.
