Light intensities and matching Cycles
Re: Light intensities and matching Cycles
There’s a lot of multiplies by 4Pi flying around in that file. I guess it makes sense since they’re unitless so they just take whatever the input is and assume it’s isotropic radiant flux. Still, my head hurts a little when it comes to cross validation, how are comparing and so on? Mitsuba has a radiance meter but it might be painful to use.
I have a different experience here where UE4 point light brightness is darker than LuxCore pointlight by a Pi factor. Did you compare using identical exposure?polyrhythm wrote: Thu Feb 27, 2020 2:10 am As verification, if I set up the same exact scene in UE4 with a one candela light, I get exactly one lux of illuminance on the ground under the light.
EDIT: Pre-tonemap in UE4, the light brightness feels around a half Pi darker than in LuxCore, which would mean that they also calculate camera exposure differently...
EDIT: Setting up LuxCore with camera settings set to EV 0 (1 sec, F/2.8, ISO 800), which means that the render output should not be scaled.
- The render is brighter than when using a Tonemap Gain of 1.0, by a Pi factor. Shouldn't the two be identical?
- With EV 0, the results looks correct to me: 1 candela outputs a pixel brightness of 1 on a white plane placed at 1 meter (I won't dare to say 1 lux).
EDIT: Compared Cycles using Photographer, and UE4, and camera exposure and light brightness assuming a 683 lm/W efficacy, and they match without any problem (I am quite relieved!).
But that means that LuxCore is the odd one here.
There is a Pi factor on the local lights / distant light that make them darker than expected in the irradiance AOV and darker than world lights.
There is a Pi factor in the Camera Exposure that makes the output brighter than a Tonemap gain of 1.
These two Pi factors cancel each other on the Local Lights / Distant light, but will be wrong for rest.
UE4 has a visualize HDR setting that gives you lux, so I was using that to check values, but didn’t think of disabling the tonemapper to check visually too. I’m afraid my coworkers might start questioning my sanity once I have 10 renderers open with these boring point light tests.
Hi all,
Please keep in mind that a camera does only see luminance (neither illuminance nor irradiance).
Please refer this thread:
viewtopic.php?f=4&t=1067&p=15301&hilit=CIE#p15301
Previous version did right results if we assume that the value that is saved in (not tonemapped) exr file is a cd/m^2 (not lux (lm/m^2)). If we consider the result as a luminance then AOV irradiance has a wrong name should be radiance (or better luminance).
BR
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
In that case, it looks like right now our 4*pi lumen point light is right on. It results in ~0.318 luminance on a surface one meter below. To go from luminance to illuminance is a multiplication by pi. 0.318 * pi = 1.0 (lux)!
Unfortunately I am still seeing the discrepancy between that and a 1 candela light, which is only getting me around 0.25 or so on a surface. From a build released yesterday on Github. My source on the math is the following excerpt from UE4 HDR visualizer:
https://github.com/EpicGames/UnrealEngi ... R.usf#L170
I'm not sure if the multiply by pi is totally physically correct or assuming everything is lambertian, though.
float MaxLuminance = max(LuminanceAvg.r, max(LuminanceAvg.g, LuminanceAvg.b));
float MaxIlluminance = MaxLuminance * PI;
Please check you have that version of the file: https://github.com/LuxCoreRender/BlendL ... 7f9a8dc165polyrhythm wrote: Sun Mar 01, 2020 1:16 am Unfortunately I am still seeing the discrepancy between that and a 1 candela light, which is only getting me around 0.25 or so on a surface.
It is literally a 4 Pi multiplier now.
Hi lighting_freak, thanks for chiming in! This helps a lot. Did you try the new light units and did you notice any problem? Please report if you find anything.lighting_freak wrote: Sun Mar 01, 2020 1:07 am Please keep in mind that a camera does only see luminance (neither illuminance nor irradiance).
Sorry I didn't try exact renderings since there is no official release yet. The changes are to quick during the last days to be sure that I'm on the right daily built.
Generally I like the new scientific/artist separation.
I'm trying to follow this thread but you lost me during the discussion about the number of the photometric/radiometric equivalent and also with pi multipliers...
So if you have a point light source and this light source shall emit uniform amount of light in full sphere solid angle the formula is
Intensity (cd) = luminous flux (lm) / solid ange (sr)
Full sphere solid angle is 4*pi... so if you want to reach 1cd intensity your luminous flux must be 4*pi lm.
The equivalent changes dependent on the light wavelength (colour) and the observer condition (day/ night).
BR
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
Ah, I see. The latest Github builds aren't picking that change up as of today.chafouin wrote: Sun Mar 01, 2020 6:08 am Please check you have that version of the file: https://github.com/LuxCoreRender/BlendL ... 7f9a8dc165
It should be all done like this, I understand that you wanted to wait for more stable builds. The first Release Candidate should be coming soonlighting_freak wrote: Sun Mar 01, 2020 9:36 pm So if you have a point light source and this light source shall emit uniform amount of light in full sphere solid angle the formula is
The daily builds should be working again, thanks to acasta69.
Dade and I would like to wrap this topic up before releasing the RC1.
