How to get rid of "tiles" on BiDir images?
Romaner
Post by Romaner » Fri Nov 22, 2019 6:24 pm
When I render with Path I get purple parts in the shadows and when i render with BiDir i get tiled output like this.
Re: How to get rid of "tiles" on BiDir images?
Post by Dade » Fri Nov 22, 2019 6:53 pm
I have never seen such thing, can you post a test scene ?
Romaner
Post by Romaner » Sat Nov 23, 2019 11:02 am
My scene
IG 88.blend
(2.32 MiB) Downloaded 19 times
Post by Dade » Sat Nov 23, 2019 11:56 am
You are using the "CONTOUR_LINES" image pipeline plugin. It requires IRRADIANCE AOV to work but BiDir doesn't support that type of AOV so it is just zero (if you save the image you will see that the IRRADIANCE.exr is all black).
"CONTOUR_LINES" displays a grid over regions with zero values and this explain the strange tiles you are seeing.
You can disable the plugin if it isn't needed or switch to normal path tracing if it was needed and you want real irradiance values.
Romaner
Post by Romaner » Sat Nov 23, 2019 5:01 pm
Thanks!
