Luxrender vs Cycles NOISE
c3kkos
Re: Luxrender vs Cycles NOISE
Post by c3kkos » Thu Nov 21, 2019 12:56 pm
And a BIG BIG thank you for your help!
So far, so good. I'll treasure this advices, and asap, i'll try those!
Thank you again
- do more with less -
c3kkos
Post by c3kkos » Thu Nov 21, 2019 3:51 pm
Sharly, i understood all but this:
4__ always use thicked walls. will save you a lot headache.
Not sure about thicked walls meaning.
Are u referring to faces with solidify modifier? to add thickness?
Or simply to have joined faces?
Thank you.
Post by Dade » Thu Nov 21, 2019 4:02 pm
Do not use a flat rectangle to model a wall but use a box (so the wall has some real thickness/depth like a real wall).
