Depth of Field
Posted: Mon Nov 11, 2019 11:21 pm
The depth of field tab in the camera settings is confusing me a little.
Under it is the F-Stop, an autofocus checkbox, a focus object tool, a distance for the focus, and the Aperture drop-down. This drop-down is what is confusing me, because the first item there is F-Stop again, and this doesn't seem to work at all. Neither do any of the other options under this tab (Blades, rotation, ratio) which I assume have not been added to Luxcore as of yet.
If this is the case then shouldn't this tab be hidden while Luxcore is the selected render engine? Or at least use the already existing F-Stop value to avoid confusion.
