Light Groups (Noob)
Gobo
Light Groups (Noob)
Post by Gobo » Fri Oct 25, 2019 4:38 pm
Hello,
Is there any way to calculate the specific indirect components into a Light Group element?
Cheers,
Axel
Re: Light Groups (Noob)
Post by Dade » Fri Oct 25, 2019 5:22 pm
A light group always includes both Direct+Indirect: you have to render the image with only the light(s) you are interested and, at that point, you can use indirect light AOV.
Gobo
Post by Gobo » Mon Oct 28, 2019 4:08 pm
Then i am doing it wrong in Blender:
- Specify Light Groups in Blender View Layers
- Add lights to Groups
- The Light Groups appear as AOVs in the Compositor Render Layers
- Looking at one of them they are direct only
How can i approach it in a better way?
Thanks!
Post by B.Y.O.B. » Mon Oct 28, 2019 10:21 pm
Can you show images?
Gobo
Post by Gobo » Tue Oct 29, 2019 8:07 am
Original render
Original render
Lightgroup channel (Looks like direct only)
Default channel (Ha, indirect hangs around here - If i render all Lightgroups *all* indirects are mixed in here)
Post by Dade » Tue Oct 29, 2019 8:23 am
Ah, but are you using PhotonGI indirect cache ? It doesn't support light groups at the moment :idea:
Gobo
Post by Gobo » Tue Oct 29, 2019 8:49 am
I see. Ok, i used Photons, so that was it. Is that planned somewhen in the future, or is it technically not possible? Kind of tricky to render scenes like the ones attached with a pure path tracer at all.
Thanks for helping, Axel
Post by Dade » Tue Oct 29, 2019 10:10 am
It is possible, it requires some work and it is not hard to do. But it is likely to have a separate cache for each light group so it can be quite expansive from memory usage point of view. It has also a little cost even if you use a single light group.
This is why you can do multiple renderings, one for each light group, enabling only the lights in the light group, mixing the results in post-processing and get the same result (aka light groups "by hand").
Gobo
Post by Gobo » Tue Oct 29, 2019 10:37 am
