Air Dust
Posted: Wed Oct 23, 2019 1:43 pm
Just why it doesn't work if the "Cube" volume object totally surround the camera ?
Working
not Working
blendfile
Working
not Working
blendfile
http://forums.luxcorerender.org/
Thanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: ↑Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
You have to set the camera or world volume.Sharlybg wrote: ↑Wed Oct 23, 2019 2:53 pmThanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: ↑Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
So now why my initial method is working ? i don't know
What is the limitation if it is a bad method ? don't know .
Set as same as my cube volume or a new volume ("air") ? anyway i've done both and it doesn't work.You have to set the camera or world volume.
No because that way it will be just replicating your working method. What i want to understand before Dade answer is why my first method work. ( No need to define room and camera volume. just put camera a bit outside of the volume).
Given the fact that your a very experienced user, your question should weigh a lot more.Sharlybg wrote: ↑Wed Oct 23, 2019 4:03 pmNo because that way it will be just replicating your working method. What i want to understand before Dade answer is why my first method work. ( No need to define room and camera volume. just put camera a bit outside of the volume).
Want to know why this one work.
Camera volume does not work.Dade wrote: ↑Wed Oct 23, 2019 3:17 pmYou have to set the camera or world volume.Sharlybg wrote: ↑Wed Oct 23, 2019 2:53 pmThanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: ↑Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
