Dark volume with glass problem
JoeDDD
Post by JoeDDD » Mon Oct 21, 2019 1:39 pm
This is glass material with ior = 1, opacity = 0 with homogenous volume
And this is glass material with ior=1 (air) and opacity = 100% and with the same volume setup.
Both pictures should look the same but when using glass with ior 1 volume turns dark
Re: Dark volume with glass problem
Post by Dade » Mon Oct 21, 2019 2:02 pm
Air IOR is 1 not 0 :?:
IOR is the ratio between light speed in vacuum and light speed in your volume. Air has a light traversal speed very near to vacuum so IOR air is about 1: https://en.wikipedia.org/wiki/Refractive_index
A IOR of 0 can not exist by definition of IOR (it would require a volume with an infinite light speed). Just any value < 1 is not possible aside in Start Trek (it requires to have light traveling faster then itself :D ).
JoeDDD
Post by JoeDDD » Mon Oct 21, 2019 2:14 pm
sorry my mistake. ior is set to 1 in both cases
Post by Dade » Mon Oct 21, 2019 2:23 pm
It depends on what you are trying to achieve but you may want to use NULL material, not glass material: in your case, a path tracer can not render the light received by the inside volume (because it is going trough a specular material like glass). While it can render the amount of light received trough transparency.
The other option is to use new shadow transparency: viewtopic.php?f=5&t=1474
Or render real SDS paths: viewtopic.php?f=5&t=1449
Egert_Kanep
Post by Egert_Kanep » Mon Oct 21, 2019 2:45 pm
So if I was rendering a sea I could also benefit from transparent shadows?
Post by Dade » Mon Oct 21, 2019 2:58 pm
Only if you are looking for lighting some under water object. In your case, you need to use glass because of water refraction (NULL material is similar to a glass with IOR = 1 without the problem of specular materials and path tracing).
I think the best solution for you would be to use an OpenVDB to describe the heterogeneous volume and PhotonGI caustic cache to render under water light. But I have no idea if there is out there a tool to model such volume. I have seen this kind of stuff over time so I assume some one has looked into the topic but I'm not sure if there is a general available tool.
I think most people are just faking water by using some colored texture for the surface.
Post by Dade » Mon Oct 21, 2019 3:35 pm
This kind of stuff: https://80.lv/articles/beach-rendering- ... a-houdini/
JoeDDD
Post by JoeDDD » Mon Oct 21, 2019 3:46 pm
I dont know why but when I use shadow color option specular highlights disappear:
This is black shadow color (0,0,0)
And this is white shadow color
Even if I use mirror material with dark gray shadow color lights in the reflection will turn black.
here is a picture:
Post by Dade » Mon Oct 21, 2019 5:13 pm
That is a MIS (Multiple Importance Sampling) bug, can you post the test scene ?
JoeDDD
Post by JoeDDD » Mon Oct 21, 2019 5:31 pm
That picture is just a material preview screenshot of a mirror material and nothing else really.
