i am trying to get my feet wet with resumable rendering in luxcore (got nostalgic about lux 1.x days)
i think i am doing something wrong, or am missing a step.
can anyone please point out where i am messing up?
in blender 2.8 i do the following:
-tick the checkbox "LuxCore Filesaver"
-set a directory
-select "text" from the dropdown then render(F12), and do the same with "binary"
now i have both .BCF and .CFG files
in luxcoreui v2.2 i do the following:
-select "rendering" menu then choose "load" option
-choose the .CFG file that was exported by blender
-let it render for about a minute
-click "rendering" menu then "pause" option
-click "film" menu then "save outputs" option (just to check if everything is going as intended)
for some reason, luxcoreui v2.2 does not seem to "know" that my scene was in 1920x1080 (or any other resolution i have set)
this leads to a smaller image than intended and this also is the case with using a .BCF file
i have tried to save the render state to a .RSM file to see if doing this would fix things but the same thing happens
what did i do wrong? what did i miss?
any help would be appreciated, thanks in advance you awesome people!
