Page 1 of 2
Can't get any volumetric light
Posted: Mon Sep 09, 2019 9:25 pm
by FrancisJ
Hi there,
I'm new to LuxCoreRender,
I try it for a 6-7 hours already and I'm having a lot of fun.
I wanted to make a volumetric light. I have search on the net, read the doc etc... But I still can't get any volumetric light in my render.
For my final scene, I would like to have something like that...
Here my test scene, as you can see, I'm having no volumetric light in my render.
Any idea ?
Thx a lot !
http://img.zeden.net/voir/2bb8b3dffd077 ... 87f7b95270
Re: Can't get any volumetric light
Posted: Tue Sep 10, 2019 3:42 am
Can you upload your testscene?
Posted: Tue Sep 10, 2019 5:44 am
by FrancisJ
Sure, sorry I should have done that first.
I'm using Blender 2.8 base version,
I'm using BlendLuxCore-v2.2beta4-blender2.80-win64
I have a generic I5 + Gtx 1060
Posted: Wed Sep 11, 2019 1:56 pm
FrancisJ wrote: ↑Tue Sep 10, 2019 5:44 am
Ok, you have not declared correctly inside/outside volumes for the objects so the scene is rendered like if there was not volume at all.
The simpler solution is to delete the NULL volume box in your scene and just set the world volume. This will tell LuxCore that the volume where the camera is (aka "air"), the one with scattering. The result will be:
To fix your scene set up, you need to set outside volume of the sphere: your scene relay on camera auto-volume detection, it will trace a ray, hit the sphere and set the volume (after the fix, it is currently not set).
Posted: Thu Sep 12, 2019 9:53 pm
by FrancisJ
Hello !
I have try a bit more (1 hour) to get any volumetric light in a simple scene.
I tried to have volumetric light with the world setting as you told me (luxrender).
In Cycle, it work easily, I just set a Principled Volume to the word, reduce the density and voila !
In Luxrender, I can't get any volumetric light with the world setting, as you see in the picture below...Is that a bug ?
Posted: Sat Sep 14, 2019 2:29 pm
@B.Y.O.B.: is there a problem in BlendLuxCore for V2.8 ? The world volume property is not exported (and the referenced volume too). It may be a problem in the FILESAVER engine (but I think it was working in v2.79).
Posted: Sat Sep 14, 2019 3:26 pm
I fixed a bug in world volume export three days ago:
https://github.com/LuxCoreRender/BlendL ... fbd8b39d3b
Do you have the latest sources?
Posted: Sat Sep 14, 2019 7:20 pm
I don't but I assume FrancisJ doesn't too because he is using beta4.
@FrancisJ, you need to update to the latest BlendLuxCore that, thanks to Acasta69 works, it is now available here:
https://github.com/LuxCoreRender/BlendL ... tag/latest
Posted: Sat Sep 14, 2019 11:13 pm
by FrancisJ
Great, the world volumetric is working now !
I have try to understand volumetric light for like 6 hours, so I think I found another bug...
Here is another bug...With the world setting the caustic is behaving as I think it should, as I just try it
But when I make a box with a volumetric inside volume, it's behaviour is really weird...
The volume setting are the same, as I just copy/paste it
As you can see, there is no volumetric caustic whatsoever... And I always got that, so matter how hard I try to tweak the setting.
There is a box with volume (same one)...But without the floor.
It has some kind of caustic, but not as good as with the world setting.
I don't think I need to link my scene, as it's really easy and fast to build one yourself and see if you have the bug
Cheers,
Francis
Posted: Sat Sep 14, 2019 11:17 pm
The images don't load at my end, can you attach them to the post?
