pathOCL turning singlesided meshes transparent
Re: pathOCL turning singlesided meshes transparent
Post by B.Y.O.B. » Wed Sep 11, 2019 8:04 am
How big is the scene as-is?
It would be really great to have a testcase of this problem, to find the real bug.
Post by lacilaci » Wed Sep 11, 2019 8:06 am
So yes.. If I make all meshes of the table into a single one (so that the top isn't really open and singlesided) then everything works.
So... There is some issue with opencl and single sided flat meshes (I only saw this error on planar and open surfaces so far - even a single flat polygon) but it appears somewhat randomly so not sure what triggers it...
tables with meshes as separate parts
and merged into one
checked every single table, everything is fine now
Post by lacilaci » Wed Sep 11, 2019 8:08 am
Pretty much everything is linked so I have no idea, main folder is 25GB but many things and textures are linked outside the main folder (could be another 20GB)
Post by lacilaci » Wed Sep 11, 2019 8:17 am
ha..
got it...
here's a demoscene where opencl won't render the flat planes for me.
planes_bug.blend
(766.49 KiB) Downloaded 36 times
so it's set to render opencl and planes are invisible, if you switch to cpu they become visible
Post by marcatore » Wed Sep 11, 2019 8:30 am
something strange on it
OPENCL
added a solidify modifier to the first plane of the middle row
For an unknown reason the 4th plane of the middle row became visibile as well the third one row.
Screw modifier
Skin
Wireframe
Another attempt with Solidify after tried with the other modifier
Post by lacilaci » Wed Sep 11, 2019 8:36 am
Yes, to explain a bit further
meshes on the rightmost side are a single mesh consisting of multiple planes
in the middle there is a single plane as object and others in the row are instanced
and on the leftmost side all planes are individual copies of the first in the row
Egert_Kanep
Post by Egert_Kanep » Wed Sep 11, 2019 11:50 am
Tried your scene, none of the geometry is visible when rendering with gpu only. When using only cpu they are visible and when on both cpu ang gpu planes become semitransparent :D
gpu+cpu
gpu+cpu
Post by Dade » Wed Sep 11, 2019 1:22 pm
ha..
got it...
planes_bug.blend
Post by kintuX » Wed Sep 18, 2019 6:35 pm
Nice :)
