lighttracing disables reflections on disney
when using disney material and lighttracing material reflections gets disabled when using glossiness bellow 0.05
to best illustrate the problem I've put metallic slider on disney to max but the problem is present even without it
disney at glossiness 0.05
disney at glossiness on anything bellow 0.05
this is not happening on glossy2 and metal material which work the same even when using lighttracing
the problem is not present when lighttracing is disabled
Re: lighttracing disables reflections on disney
I think that what you're observing, are light rays that don't get to the eye. And if IIRC, it's already mentioned couple of times.
Take notes & simply don't go under/over the threshold. ;)
kintuX wrote: Thu Aug 15, 2019 11:07 pm I think that what you're observing, are light rays that don't get to the eye. And if IIRC, it's already mentioned couple of times.
Not sure what you mean, and also why the different behavior between disney and others...
Dade wrote: Sun Aug 18, 2019 3:31 pm I should have fixed this problem.
Yes, it works now.
BTW, while we're dealing with Disney's reflections - where's its Fresnel/IOR setting?
kintuX wrote: Thu Aug 22, 2019 5:32 pm
Yes, it works now.
It is part of additional features introduced at SIGGRAPH 2015, we have only SIGGRAPH 2012 features at the moment.
Dade wrote: Thu Aug 22, 2019 6:08 pm
Yes, it works now.
A-OK. Thanks for the note.
