Page 5 of 14
Re: dark juice
Posted: Thu Aug 15, 2019 11:58 am
by provisory
lacilaci wrote: ↑Thu Aug 15, 2019 11:30 am
But now you changed condition and you're rendering with hdri, this isn't solving anything
Then what is the main issue?
Wasn't the problem that you can't make nice orange juice?
Re: dark juice
Posted: Thu Aug 15, 2019 12:18 pm
provisory wrote: ↑Thu Aug 15, 2019 11:58 am
Yes, I cannot make it cause light can't directly pass through it.
The settings you posted last don't change that. You cannot shuffle scene, camera and lights around to make it look almost like what it's supposed to and call that a solution.
here are your settings in the original scene
Your settings make weaker absorbtion and shifts colors in the volume, and using bidir+metro does nothing but slow rendering down
Re: dark juice
Posted: Thu Aug 15, 2019 12:24 pm
by wasd
provisory wrote: ↑Thu Aug 15, 2019 11:15 am
My latest juice volume:
Correct IOR for orange juice would be around 1.36. It doesn't really matter here, just fyi.
Re: dark juice
Posted: Thu Aug 15, 2019 12:29 pm
by wasd
Now I remember, when I tried to make human skin material I found that light doesn't pass through. If light goes through ear for example, it should be illuminating cheek, but it doesn't unless you make skin material a bit translucent.
Re: dark juice
Posted: Thu Aug 15, 2019 1:08 pm
by provisory
lacilaci wrote: ↑Thu Aug 15, 2019 12:18 pm
I didn't do that, just took two of my high quality, proven hdris, and put some nice material on the plane, and that's it.
(Oh, and I used a little DoF.)
...bidir+metro does nothing but slow rendering down
Here are comparisions illuminated by only Sun and sky.
BiDir, Metro
Path, Sobol + LightTrace
You can see difference in the shadow too, so the light does pass through it (at least with BiDir), even if it is a dense volume, so it's not so obvious.
Re: dark juice
Posted: Thu Aug 15, 2019 1:13 pm
I tested few hdris too and it's probably easier for the renderer to find lightsource than sun and sky..
But that's not changing anything about the issue itself
Re: dark juice
Posted: Thu Aug 15, 2019 1:23 pm
provisory wrote: ↑Thu Aug 15, 2019 1:08 pm
So you changed everything but the glass in other words
Your scene how has different and much simpler lightsource and dark ground...
But like I said, even if hdri makes it somewhat easier for metropolis to render things, it doesn't solve the issue at all
Re: dark juice
Posted: Thu Aug 15, 2019 1:51 pm
by provisory
Yes, I didn't "shuffle scene, camera and lights around to make it look almost like what it's supposed to and call that a solution."
I just tried simple, proven environment, and it looked good right away.
Re: dark juice
Posted: Thu Aug 15, 2019 1:56 pm
by provisory
lacilaci wrote: ↑Thu Aug 15, 2019 1:23 pm
You can see, that the Sun and sky versions look nice too.
And, indeed, dark ground does help, because orange juice can't really be brighter than white.
Re: dark juice
Posted: Thu Aug 15, 2019 2:02 pm
provisory wrote: ↑Thu Aug 15, 2019 1:56 pm
no, they don't look nice, it looks wrong.
Does this look like to you it would in real life?
Don't you think there might be a little problem right there?
