Huge RAM usage during kernel compilation
Re: Huge RAM usage during kernel compilation
A screenshot of the node tree would be nice, maybe it can be optimized.
For future reference, also procedural textures sometime make OpenCL compilers mad.
It was related to the nodes attached to that material. The material itself is a matte one...so nothing problematic.
The "problem" arise cause attached to the material there are 30 image nodes + 30 "greater than" nodes + 30 mix RGB nodes and 1 raw object node.
At the moment I've split it into 4 different materials with just the 4 textures I need.
Now, I've questions for Dade.
1 - When you speak about "features" of a material to compile...are you referecing to the quality&quantity or just quality? I mean, if I have 30 mix nodes in a material, during the kernel compilation, the compiler "sees" 30 mix nodes or just "a mix node" ?
2 - In my opinion, and for my daily experience and workflow, I consider really useful and timesaver to have a node that can handle multi textures with an assignment driven by faceID or Object ID. I'm referring to this Vray texture . It's useful because you can reduce the materials number and you can switch quickly to another texture just changing the ID number. In my project I have often some sets that differ just for a graphic or a color. In this way I can create a pool of textures I add to a single material and then, following the design needs, I go to switch just the ID and it's done. Or , for example, with the color of the shoes (or apparel) I can use a random script to change the object IDs and I'm fine with a reduced time spent.
If I use materials, I have to naming them one by one and spent more time for random assignments
About kernel compiling
Ok, now I know that Nvidia needs a complete recompiling for every new render, at least everytime I add a single new feature...but I really hope you'll find a way for a onetime kernel compilation like Vray did. It's super annoying and time consuming to have it everytime you press render...and I think that this block users to use the viewport render GPU accelerated for the same reason and it's a pity cause it will be useful to have a fast less noiser preview.
30 different mix nodes.marcatore wrote: ↑Wed Aug 07, 2019 11:54 am Now, I've questions for Dade.
It is something to do statically at export time by BlendLuxCore, doing it at runtime, during the rendering, for every single sample, is very very wrong and a performance killer.marcatore wrote: ↑Wed Aug 07, 2019 11:54 am 2 - In my opinion, and for my daily experience and workflow, I consider really useful and timesaver to have a node that can handle multi textures with an assignment driven by faceID or Object ID. I'm referring to this Vray texture . It's useful because you can reduce the materials number and you can switch quickly to another texture just changing the ID number. In my project I have often some sets that differ just for a graphic or a color. In this way I can create a pool of textures I add to a single material and then, following the design needs, I go to switch just the ID and it's done. Or , for example, with the color of the shoes (or apparel) I can use a random script to change the object IDs and I'm fine with a reduced time spent.
This kind of stuff must be resolved statically.
This is planned for v2.3.marcatore wrote: ↑Wed Aug 07, 2019 11:54 am About kernel compiling
1. Ok. Understood. Now it's more clearDade wrote: ↑Wed Aug 07, 2019 12:52 pm
2. Yes... runtime it seems really useless, I hope that will be done statically. What do you think BYOB?
3. Nice. It will be a great step for users.
Thank you
I can't look into it right now, can you create a github issue about it to remind me in the future?
