Advance Lamp properties
1. Are Blackbody Temp., Irregular Data & Lamp Spectrum planned to be supported by Lamps?
2. Could Lamps be node based as are materials now or ase are Lamps in Cycles?
3. Is Projector (with Spot Lamp) also going to be implemented?
TIA
Re: Advance Lamp properties
kintuX wrote: Fri Feb 16, 2018 9:43 pm 3. Is Projector (with Spot Lamp) also going to be implemented?
It is already implemented. Make a spot lamp and choose an image.
it's on autopilot :lol: great!
kintuX wrote: Fri Feb 16, 2018 9:43 pm 1. Are Blackbody Temp., Irregular Data & Lamp Spectrum planned to be supported by Lamps?
They are already supported by LuxCore, may be not yet by BlendLuxCore :?:
neo2068
Post by neo2068 »
Textures for lamps are not yet implemented in BlendLuxCore. It is only available for mesh emission, i.e. emission in material node, ATM.
If the lamp "color" property really supports textures, then I think the LuxCore manual is wrong: https://wiki.luxcorerender.org/LuxCore_ ... ype:_point
Because it says "spectrum", not "texture". Or is "spectrum" inherently texturable?
B.Y.O.B. wrote: Sat Feb 17, 2018 10:28 am If the lamp "color" property really supports textures, then I think the LuxCore manual is wrong: https://wiki.luxcorerender.org/LuxCore_ ... ype:_point
They are only for material emission like Neo wrote. Materials can evaluate textures, lamp-only can not.
Ok, so Blackbody Temp., Irregular Data & Lamp Spectrum can only be used on area lamps.
I created a github issue.
Note that it is already possible to use these textures if you use a plane with light emitting material in BlendLuxCore.
