Warning: SetThreadGroupAffinity failed
Post by marcatore » Tue Jul 23, 2019 10:43 am
I've these errors during the rendering phase.
I'm using OpenCL with "use CPUs" option ON and with Autodetect option enabled.
Anyone else?
Re: Warning: SetThreadGroupAffinity failed
Post by B.Y.O.B. » Tue Jul 23, 2019 12:08 pm
This warning comes from OIDN, you could try looking into their docs or opening an issue in their repository to ask about it.
Post by kintuX » Tue Jul 23, 2019 2:39 pm
In my case, denoiser version didn't match (.exe & .dlls inside bin folder) to that which is specified in the code (exporter). Comes from mixing versions. You can disregard the message or make a new, fresh & clean install.
Post by Dade » Tue Jul 23, 2019 4:10 pm
It is likely to be a mismatch between Oidn DLL and TBB DLL.
Post by kintuX » Tue Jul 23, 2019 6:44 pm
Aha, most likely it is. Cuz I rember, before OIDN was updated to the latest 0.9.0 I already used it, but had only overwriten exe & dlls. And since there were no issue rendering wise, i didn't pay much attention to it. Anyways, thanks for the tip! Nice to know.
acasta69
Post by acasta69 » Wed Jul 24, 2019 9:17 am
Strange, the TBB DLLs in WindowsCompileDeps should also be updated to the same version used by OIDN:
https://github.com/LuxCoreRender/Window ... 45ceeb7dea
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
Post by Dade » Wed Jul 24, 2019 9:41 am
Not sure if it has any implication here but there is always the potential problem of Embree and Oidn being compiled for 2 different TBB versions.
Fox
Post by Fox » Wed Jul 24, 2019 10:35 am
But the TBB actually has more files than this 2 dll, it has around 120 files. :roll:
acasta69
Post by acasta69 » Wed Jul 24, 2019 2:35 pm
The full TBB is larger, but we use directly the Intel binaries for OIDN, and the distribution contains only the required TBB dlls + libs, total 4 files.
We need more stuff for Embree, however, and:
I also don't know how it could affect us. I'll try to investigate a bit deeper.
EDIT: BTW, an issue about this is already present in OIDN repo.
