Post
by FarbigeWelt »
Dade wrote: ↑Fri Jun 14, 2019 9:04 am
Dade wrote: ↑Thu Jun 13, 2019 11:24 am
I will try to find a workaround but it may be not even possible.
I have found a ways to workaround the problem and now the scene should work fine on AMD GPUs too.
Great! It is fantastic how creative you solve issues.
I will check the solution this evening if latest build includes your workaround.
Light and Word designing Creator -
www.farbigewelt.ch - aka quantenkristall || #luxcorerender
MacBook Air with M1
Post
by FarbigeWelt »
Perfect, it works now on AMD GPUs too, as you can see here. (LuxCoreRender 2.2 beta 1, build 29e0582)
- Organic Figurine, openCL, indir and caustic cache, tone map linear fixed. 774 samples
- Organic Figurine, openCL, without cache, tone map linear fixed. 758 samples
The images have indeed the same brightness now. Thanks a lot.
MacBook Air with M1
