Glass with image texture on it
madcat117
Post by madcat117 » Fri Jun 07, 2019 5:53 pm
How can I make a glass flat 2d plane have a image texture over it that is visible and not all blacked out sort of like church stained glass
madcat117
Re: Glass with image texture on it
Post by madcat117 » Fri Jun 07, 2019 6:11 pm
also getting weird effect on my glass window where the back wall is reflecting on to it
madcat117
Post by madcat117 » Fri Jun 07, 2019 6:13 pm
WTF
Post by B.Y.O.B. » Fri Jun 07, 2019 7:33 pm
You can texture the transmission color. (should only be used on thin sheets of glass because this method doesn't create correct volumetric absorption).
The mesh should have a bit of thickness, though (e.g. use solidify modifier).
For thin sheets of glass you can enable the "Architectural" option for faster rendering.
madcat117
Post by madcat117 » Fri Jun 07, 2019 7:47 pm
BYOB why the back wall reflected on the glass though?
madcat117
Post by madcat117 » Fri Jun 07, 2019 8:05 pm
BYOB i textured the glass plane with uv map and image texture but you cant see anything its dark still even with sun lamp hitting it directly
Post by B.Y.O.B. » Fri Jun 07, 2019 8:17 pm
The sun will shine right through perfect glass - try using e.g. sky as background light.
If you want the sun to be visible on the glass, you need to add imperfections, e.g. mix with matte translucent to simulate dust, or scatter some small particles over the surface.
madcat117
Post by madcat117 » Fri Jun 07, 2019 8:48 pm
BYOB you have saved the day once again I LOVE YOU
